Feb 27, 2016, 10:52 AM
Always Building
TheMadCADer's Avatar
New Product
FsFly T-i8 2.4GHz 8CH DSM2 Compatible Transmitter
http://www.banggood.com/FsFly-T-i8-2...733432201408CW
Description:
FSFLY 2.4GHz 8CH T-i8 Transmitter is a brilliant, fully programmable 8 channel 2.4GHz transmitter that is loaded with features.Covering just about everything for both fixed wing and helicopters, it supports multiple wing types, multiple swashplate types, channel mixing, subtrim, exponential, dual rates, travel adjustment, servo monitor, graphic pitch/throttle curves, 20 model memory and so much more! This little gem even features an adjustable RF power output setting in the menu, allowing users to switch between US and EU power standards.
All of the programming functions are displayed on the large and easy to read backlit LCD display. You can easily navigate through the menus with the convenient scroll wheel, or by using the menu buttons. The menu system is very intuitive and easy to use, unlike some other transmitters on the market today that require studying of the manual to operate.
When it comes to powering your transmitter, the T-i8 has covered for just about any battery type. It can operate on 4 x AA size Alkaline, NiMH or NiCD cells, but also features an in-built JST plug in the battery compartment allowing you to use a 2 cell LiFE or LiPO pack as well! The transmitter's low voltage battery alarm is adjustable via the menu to suit whichever battery chemistry you choose.
Specification:
Brand Name: Fsfly
Item Name: T-i8 Transmitter
Frequency: 2.4GHz
Modulation: DSM2
No. of Channels: 8
Model Memory: 20
Stick Mode: Mode 2 (left stick throttle)
Features:
• Compatible with all DSM2 Receivers
• 8 Channel Operation
• 20-model memory.
• Model Match.
• Servo Sync.
• Roller/selector user interface.
• Attractive and ergonomic design.
• Airplane Programming Features: Flaps, P-mixes, Dual aileron, V-tail, Delta, Differential.
• Rudder dual-rate.
• Large LCD display.
• Integrated timer.
• Contrast Adjustment.
• Dual-speed trim scroll.
• Model name and type.
• Throttle cut.
• Trainer Mode.
• Model Copy.
• Travel adjustment.
• Sub-trim.
• Servo monitor.
• Dual rate and exponential.
• Heli Programming Features: Gyro adjust, Graphic throttle curve, Graphic pitch curve, P-mixes, Revo mix, Swash type (Normal ,CCPM 120, CCPM 135, CCPM 140, CCPM 180 ).
• Adjustable stick length.
• Direct trim access display
Required Parts:
2.4GHz DSM2 compatible receiver
4 x AA batteries or 2S transmitter battery w/JST plug
Note:
- This is not a Spektrum DSM2 product, nor is it a copy of a Spektrum DSM2 product.The Spektrum and DSM2 brand is a trademark of Horizon Hobbies USA.
- This is not an underground black market fake Spektrum product. FsFly quality is guaranteed.
Package Included:
1x FsFly T-i8 2.4GHz 6CH Transmitter
Feb 28, 2016, 11:58 AM
"1x FsFly T-i8 2.4GHz 6CH Transmitter"
So is 6 or 8 ch ? "confused"
The answer could be inbetween... a FlySky FS-i6 clone with the 8ch firmware that is already out for some months
Feb 28, 2016, 12:36 PM
IMO ( In My Opinion ) →
balsa or carbon's Avatar
Banggood also has the 6 channel "Orange TX" , looks just like the one from HobbyKing . But with Banggood's free shipping , the total cost may be less than HK .
Feb 28, 2016, 12:44 PM
That is obviously a typo on the Banggood web page .
And the brand is FsFly , not FlySky - similar enough to be confusing .
Feb 28, 2016, 01:46 PM
Aliexpress has them for less $ , including receiver , also with free shipping .
http://www.aliexpress.com/item/FSFLY...7-12f32a0b3c68
http://www.aliexpress.com/item/FSFLY...6-8c94ddb035e5
Feb 29, 2016, 01:17 PM
KD4KW
Kd4Kw's Avatar
mixes, mixes, what mixes ????
Not much information so far. I goggled for a manual but no joy.......
Wait and see I guess
Mar 28, 2016, 08:18 PM
Any reviews? I can't find any here on RCGroups.
Mar 28, 2016, 09:46 PM
KC
KC
Registered Loiterer.
KC's Avatar
Looks like someone from the US bought one on the 12th of March. (from aliexpress)
I think I see three, 3 pos D/R switches, one 3 pos F mode switch, and one 3 pos flap switch. And wow! It comes with a genuine AR8000 Rx with satellite for $7 more.
Mar 29, 2016, 01:54 AM
Are you sure it's genuine?I remember when a heap of cheap Spektrum satellite reciver knockoffs appeared, I think at just $7 more this could be one of them.
Mar 29, 2016, 05:57 AM
flypaper 2's Avatar
I see it also has Model Match, which is a big plus.
Gord.
Mar 29, 2016, 01:26 PM
KC
KC
KC's Avatar
There is no question, its absolutely a fake. I was being facetious.
Mar 29, 2016, 04:21 PM
Sorry, I don't have a sense of humour.
Mar 29, 2016, 04:26 PM
RC Warjet
Why would anyone buy this when you can get a 9XR Pro with module for about the same price?
Mar 29, 2016, 05:41 PM
KC
KC
KC's Avatar
Yeah, but that orange color is so lovely....
Under the attachment I wrote, "looks legit", but to be honest, I wasn't sure if people were going to catch the joke. My kids are always referring to shady dealings as, "looks legit". Its really funny when they do it. lol.
Mar 30, 2016, 06:46 PM
Hi, I checked the OrangeRx t-six firmware version and it says that the firmware comes from FSFLY!
I have a question: Where can I buy gimbals for that radio?
If you guys want to check as well just push the two trim button (yaw and roll) to the center and switch on the transmitter. You have to got all other switches at 0 position.
By this method you can also calibrate the gimbals. You just have to got the mode switch at 1 position.
And then you switch the rudder, aileron, flaps and elevator switches for minimum, middle and maximum position.
