Aug 07, 2004, 05:32 PM
Nyuk! Nyuk! Nyuk!
RMEFlyer's Avatar
Question
Motor Pulsating at Full Throttle
I was doing a bench test on my Python 60 outrunner, 8x6 prop, , Jeti 8a Advance ESC, 3s1p TP 830a battery ---at full power the motor began pulsating after a few seconds at full throttle.... My guess is this is because I'm pulling to many amps out of the battery for it's rating 8-10C? Sound about right? Just want your opinion to make sure I don't have a defective motor or esc...
At full power and fresh battery - I was initially pulling close to 9 amps but it also did it at the end of the test with a depleted battery at full throttle when I was pulling only 6 amps (voltage was dropping). THANKS!
HomeBrew
Aug 25, 2004, 07:24 AM
Repair Specialist
Ken-Ohki's Avatar
I noticed a similure problem with my python 200.
If I put to large a prop on it, it will loose power and pulse.. Try a smaller pitched prop.
Ken-Ohki
Aug 25, 2004, 10:05 AM
Dr Kiwi's Avatar
I don't know what the max draw for that motor is, but at 9A you are overtaxing the batteries and risking your 8A ESC. Even if you have a pack rated at 10C you must expect considerable voltage drop at any more than 6C or so. Example: I just did some test runs with a Kokam 340SHC pack (optimistically rated at 20C = 6.8A). With 2s (8.1v initial voltage), at 2.7A draw, pack voltage was 6.8v, but at 4A draw it was 6.0v. On 3s (12.2v initial voltage), at 4.3A draw, pack voltage was at 9.3v, but at 5.7A draw, pack voltage was down to 8.1v.
Cheers, Phil
Discussion Motor cuts out at full throttle? talehevvy Electric Power Systems 10 Aug 10, 2016 04:04 AM
Discussion motor at full throttle? 4005 Electric Power Systems 5 Apr 07, 2006 06:04 AM
Himax 2025-4200, CC Phx 22, 3S1p - 1500 Kokam - motor cutting out at full throttle? cadconversions Electric Power Systems 12 Oct 01, 2004 08:37 PM
Problems.pulsing motor at full throttle terjes Electric Ducted Fan Jet Talk 5 Feb 23, 2003 04:43 PM
ZAGI 400-X ; power cutting out to motor after flying at full throttle Joe-z Foamies (Kits) 29 Jul 15, 2001 10:51 PM
