This thread is privately moderated by Mad_angler1, who may elect to delete unwanted replies.
Feb 22, 2016, 07:06 PM
Bog Flusher Platinum Grade
Mad_angler1's Avatar
Build Log
DJI Inspire1 4 Pack Charger
I have decided to build a 4 Pack charger for the Inspire 1, after a lot of investigation and hunting around i settled on the spec that i can build for a reasonable price,
The Plan is
4 Battery charger - 150w per pack
Storage charge option to 50% capacity controlled by Ardunio
Voltage and Current readout on a single 16x2 display showing each packs status either scrolling through all at once(TBC)
I will be updating this build log as time goes on
The Start
Initial work started by sourcing 26V PSU's, this was not as easy as i thought it would be tbh, in the end i ended up finding a supplier that supplies them for LED drivers and they had a unit that was modified to go to 26v.
Unit is 22-28v 150w rated, Pot to set output
Only downside is its fairly large so having x4 of them is going to be a challenge.
Initial testing
All went well however found some interesting behaviour of the TB47 and TB48 batteries, I noted that even though the DJI adapter is rated at 26.3v not one of my three outputs more than 26.0, mostly hovering 25.9 unloaded, under charge conditions it never goes over 26.0v, when testing the new PSU i had set it to 26.3v as per there DJI adapter label, this went fine until about 10 minutes before completing the charge and the pack gave an over charge error, after investigation back and forth between the two it seems that at 26.3v the smart pack draws a little to much current in the final stages and produced an error.
With the DJI Adapter at this stage it draws about 800-1000mah
With the new PSU set to 26.3v its just over 1300mah and it throws the over charge error, by dropping the voltage to 26.0v draw is back in the 700-800mah range and the pack completed its charge as normal, interesting and unexpected behaviour, so 26.0v is the sweet spot it seems, this also means you not pushing the cells all the way to 4.35v so will help with longevity a little.
More to Follow
Mar 08, 2016, 05:31 PM
Progress being made
3D Printer Battery Carriers
2A USB Buck DC to DC Converter.
Initial Wireing Madness
Mar 17, 2016, 06:52 PM
Stage 1 Complete
4 Pack charger
Individual 150w Psu's
Storage charge mode, the switch on each pack chooses full charge or 50%
2A USB Port for charging Tablet
