8CC gas Evolution engine. - RC Groups
Feb 21, 2016, 07:51 PM
Hey people,
Bought hangar 9 8cc p51.
It asks for 20:1 ratio of gas/oil
All I can find in stores are 40:1 and 50:1.
What should I do?
Would it hurt to use 50:1 ratio?
Feb 21, 2016, 08:11 PM
Illegitimi non carborundum
grosbeak's Avatar
You can mix it yourself. Buy some good quality ethanol free gas. 20:1 means that for every litre you add 50 ml (or 6.4 fl oz per gal)
Feb 21, 2016, 08:54 PM
You might consider purchasing a "ratio rite" measuring cup.
It is designed for mixing 2 stroke oil, and has markings showing the correct amount of oil for different ratios and different amounts of gas (20:1 for 1 gallon, for example).
It makes life easier, and reduces the chances of making a mistake.
Feb 21, 2016, 09:58 PM
los36's Avatar
I like this one.
https://www.rockymountainatvmc.com/p...tle?term=ratio
Feb 22, 2016, 01:01 PM
Ok thanks, one more question, is 2 cycle oil the same things as 2 stroke oil?
Feb 22, 2016, 02:07 PM
los36's Avatar
Yes.
Feb 22, 2016, 03:17 PM
Note that not all 2 stroke/cycle oil is the same. Oils that are designed for oil injection systems and/or marine engines may not work as well for our airplane engines as say something that says "rated for air cooled " 2 stroke engines. If it says that, you're good to go.
Feb 22, 2016, 09:29 PM
Ditto. Sthil ultra synthetic or Redline synthetic are popular choices.
Feb 23, 2016, 12:02 PM
AMA 537620
ChillPhatCat's Avatar
Use twice as much "40:1"... That will make the mixture 20:1.
Mar 07, 2016, 12:29 AM
Is there a way to remove ethanol, all fuels in our place comes pre mixed with 10% ethanol
Mar 07, 2016, 12:49 AM
Mix the fuel with a bit of water and shake in a clear Glass container , the mix will seperate into 2 or more layers the top one will be your fuel .The bottom layers layer are ethanol and water .On the top is Pure fuel just siphon off the good stuff . The gas will have a slightly lowered octane content .Please use static precautions and use a glass container not plastic to seperate the fuel, as plastic can cause static explosions .
http://www.mcnews.com/mcn/technical/2012decethanol.pdf
Mar 07, 2016, 12:52 AM
Originally Posted by outbackkanga
Mix the fuel with a bit of water and shake in a clear Glass container , the mix will seperate into 2 layers one layer is ethanol and water the other is pure fuel just siphon off the good stuff . Please use static precautions and use a glass container not plastic to seperate the fuel, as plastic can cause static explosions .
Great info! Thanks. Btw, do you know what layer will be the good stuff? am I right in assuming that fuel will be on top?
Mar 07, 2016, 01:01 AM
Yes indeed .. just just edited the post with a link for you
Mar 07, 2016, 01:14 AM
Thanks again
Mar 07, 2016, 07:35 AM
Do as you like, but Ehanol won't affect that engine one bit.
