Feb 17, 2016, 03:19 AM
vgoodrones's Avatar
New Product
Free Testing-VGOODRC ARM 32bit ESC!
Sincerely inviting multi-drones enthusiast for testing!
Feb. 17th,2016 – Mar. 17th, 2016
V-GOOD RC Firefly ESC Beta testing is almost over! During the beta period, we got many many helps and great suggestions from the lovely people. They made our products much better and better.
We here thank you for your support and help!
Thank you for your hard working!
Now we release the VgoodRCv303_160406(multi-shot) FM to you for upgrade. Please kindly check the attached file. Thank you.
Notice:
The Beta ESCs were with V1.3bootloader. Since April 2016, the ESCs are with V1.4 boot loader and the hardware is a little different than before. So the V1.3 ESC will not have new features in future. The one who loves our products, please kindly get new hardware from our retailers.
Sorry for the inconvenience!
We will constantly improve and perfect our products to provide much more high quality ESCs to you.
Here below are some reviews, amazing flight videos and thrust test video links from our lovely testers. Please watch!
Flight videos:
Vgood Firefly 18A multishot first test 1 (5 min 36 sec)
More V GOODNESS (6 min 2 sec)
V-GOOD RC FIREFLY 20A LITE ESC 2-4S RACE TESTING (3 min 39 sec)
Rator 6inch 4S 6045 Vgood18A Naze32 BF v2 5 3 X4R Acro Taranis (1 min 37 sec)
Test ESC V-Good 10A ... on frame Lizard 150 ... 4S battery (4 min 4 sec)
"VGood" Friday (2 min 54 sec)
Much Boom - Wow // EpicRC (1 min 40 sec)
RaptorFPV5" bashing amongst the trees (1 min 59 sec)
Thrust test:
VGOOD 32bit ARM 30A 2-4s/Emax RS2205 2300Kv Thrust test 4S/4s HV (3 min 45 sec)
Eagle tree systerm data
https://static.rcgroups.net/forums/a.../a8780661-254-
https://static.rcgroups.net/forums/a...8/a8780662-87-
How to use V-Good prgrammer
Vgood // FireFly Programming Card // Tutorial (1 min 40 sec)
How to change rotation by finger. (Only for BL1.4 ESC)
vGood FireFly // Changing Motor Direction (0 min 27 sec)
Want to see more flight and thrust test videos? Please find the links on attathed file-"More flight and thrust test video links"
Available test models as below:
1. Firefly 10A OPTO LITE ESC with no external capacitor (Size: 11*20mm), 2-4S
2. Firefly 18A OPTO LITE ESC with no external capacitor (Size: 12*22mm), 2-4S
3. Firefly 30A OPTO LITE ESC with no external capacitor (Size: 14*27mm), 2-4S
4. Firefly 30A OPTO LITE ESC with no external capacitor (Size: 21*35mm), 2-6S
Products advantages:
1. High compatibility can be compatible with most of the motors. Compared to the other most famous firmware, our firmware can compatible more motor types, especially high KV value motors.
2. Fast throttle response, excellent linear. No jump from 0-100% throttle. The other most famous and widely used firmware will appear different degree of jump when the throttle at the position of 92.5% position.
3. Have very small size and light weight. No external electronic capacitor.
4. 32bit ARM chip, hardware PWM driver.
5. PMSM, gate driver IC
Main features:
1. Special designed for multi drones.
2. STM32F051 48MHZ ARM 32-bit micro-processor.
3. No external electrolytic capacitors.
4. Adaptive timing. It can compatible with much more motors.
5. Automatic detect if it is the ordinary remote control signal (PWM) 50-500Hz or One-Shot125 Signal. One-shot42
6. Having synchronous rectification technology to increase the working efficiency of ESC.
7. Regenerative braking, active brake. Motor deceleration response increased significantly.
8. Anti blocking protection. When motor or propeller is blocked by something, ESC will stop the rotating of motor immediately to avoid the damage of motor. The motor will automatic start to rotate when detect there is no blocking.
9. PWM output frequency is 24 KHz.
10. Throttle resolution is about 1480 steps.
11. Max. RPM: 450,000rolls (2 poles), 150,000rolls (6 poles), 75,000rolls (12 poles)
12. Support 2-4s Lipo battery.
Feb 17, 2016, 04:27 AM
The firmware will make or break these. If the hardware is better than the old 8 bit stuff but the firmware isn't as good as BLHeli people won't like them.
Feb 17, 2016, 08:52 PM
Feb 21, 2016, 08:18 PM
vgoodrones's Avatar
Feb 22, 2016, 05:25 AM
I've been right at least once.
Interesting. What will the price point of these be in the 10amp and 20 amp versions?
Feb 22, 2016, 09:40 AM
ufoDziner's Avatar
Hello,
These look interesting. All of the quads that I own are racers(250mm or less) and run on 6S (with up to 2000kv motors). Based on the specs you have listed, the 30A 6S version would be the version for my applications. If you would like to see results for higher voltage applications let me know, as I am interested in testing these. Thanks
Feb 22, 2016, 01:07 PM
JulianGoesPro's Avatar
Super interested
Would love to tests those, I have a 6s quad as well as several 4s quads so could test what ever size you are mostly interested in seeing an test
I am also running thurstests with different motor and ESCs on my thrust stand and could compare them to other ESCs like LittleBee / KISS / X-Rotor.
I do have a little FB side:
https://www.facebook.com/JulianGoesPro
...but mostly post my tests hier on RCGs (threads or blog posts) and link to my YT videos:
https://www.youtube.com/user/JulianGoesPro
e.g. a 6s Thrust Test
ThrustTest: 6s // CM2208 2000kv // HQ6045 CF // 2138g @ 56.92A (0 min 10 sec)
Feb 22, 2016, 01:16 PM
I'd rather be flying
QuadMcFly's Avatar
Are these what you guys are sending over for me?
Feb 24, 2016, 03:57 AM
vgoodrones's Avatar
Hello, guys! We chose some outstanding tester to be our free tester. We sent the invitation to the private inbox. Please kindly check it.
And the application deadline is early, we warmly welcome every enthusiast for sign up!
Thank you!
Feb 24, 2016, 02:20 PM
I'd love to have an opportunity to test out these ESCs, specifically the smaller (2-4s) 30a ESCs.
Feb 24, 2016, 03:12 PM
Hi team VGOOD-RC, I'd welcome a chance to test some of these. The 30A's, I think, ideally.
I'm part of the dRonin flight controller project development team and you can check out some examples of my flight @ https://www.youtube.com/user/fujinhachiroku/videos
I filmed this yesterday.
Thank you for considering my request.
Tester
I would love to test for you. I have a youtube channel that I post build videos on.
Feb 24, 2016, 03:20 PM
How do we go about getting a half priced 18a set? Thanks to the horrible weather here, I am fairly sure I couldn't deliver a satisfying in-depth test, but I'd like to give them a whirl on a 180 size copter nonetheless.
Just ordered some 30A to try out, seems good and the price at ~11$ each its not expensive.
http://j.mp/1S1O25h
The 18A seem good too: http://j.mp/1LGn6RX
Feb 24, 2016, 03:22 PM
I'd be very interested in testing any of the following ESC's:
I would be able to post test results across multiple motors, on 3S, 4S, FastPWM, OneShot125, and OneShot42.
