This thread is privately moderated by GottaZoom, who may elect to delete unwanted replies.
Feb 16, 2016, 04:26 PM
Up! Up! And Away!
GottaZoom's Avatar
Delta Ray receiver with ESC connections
Has anyone else ever wished they could connect traditional motor speed controls (ESCs) directly to the Delta Ray receiver?
My regular flying buddy has completed several Delta Ray projects, with and without the stock Delta Ray receiver. We've both dreamed of being able to connect regular ESCs to the receiver in order to keep all of the other nice features that we have enjoyed since we bought our Delta Rays.
The images below are of a once stock receiver board - resurrected from its untimely death- modified to allow connecting traditional speed controls (ESCs).
Front view - Output leads for throttle signals to ESCs replace the stock motor leads
Back view s - Mosfets removed with new leads attached
Note: large capacitor also upgraded to 16V to allow 3S power
This ESC started out stock, but one of the mosfets burned out from excess heat while running with brushed motors. Many thanks to RCG members who have inspired and/or directly contributed to this modification test:
- AJ.K., who documented the receiver board layout/components
- Imboeschi, who created a solution to run upgraded brushed motors
- EArHog, who donated this particular receiver board with its blown FET
- Anonymous for doing the modifications
- And many other Delta Ray thread participants for their ideas and encouragement.
The throttle signals have a nice linear flow from 0 to full throttle.
The amplitude of the pulses = 3.3V
The Frequency = 15kHz.
Motor tests will next help determine if ESCs will use this 3V signal to run the motors normally, or if a signal amplifier might be needed, or if a unique ESC solution will be needed.
See the next post below for motor tests using brushed and brushless ESCs, using 2 different motors for each ESC.
Up! Up! And Away!
GottaZoom's Avatar
Scenario #1: No common ground with 2 separate batteries, 1 for RX and another for ESC/motor
Results: ESC fails to arm (17 Feb)
Test #1 = HobbyWing brushed ESC with Pro180 motor
Test #2 = HK 10A brushless ESC with HK AD100L motor
Scenario #2: Common ground with 1 battery for RX and ESC/motor
Results: ESC fails to arm (18 Feb)
Test #3 = same as #1 & #2 above
Scenario #3: 32 bit ESC capable of fast duty cycle (OneShot42 firmware)
Results: ESC did not recognize the signal even though within range. ESC working confirmed by running 2S motor off alternate receiver.
Test #4 = VGood 18A ESC with 2S motor
Scenario #4: BLHeli with DR-specific firmware
Results: Success! ESCs recognized the signal, armed and ran motor very smoothly! A description of the first test run of motor and video with the flashed ESC can be found at the success link. On to a new build! (22 April)
Test #5 = Afro 20A Race Spec Mini ESCs with 2204 motor. ESC has Atmel MCU flashed with BLHeli Delta Ray Edition firmware.
Feb 16, 2016, 04:27 PM
Up! Up! And Away!
GottaZoom's Avatar
Wiring for ESCs going into wings. I love heat shrink, it covers my barely adequate soldering!
Blue EC2 connectors used to connect to ESCs. Eliminates soldering in plane and plugs in tight fuselage. Hopefully will make for easier ESC/motor/brush changes.
Red JST-RCY added to connect UBEC when there is no usable BEC from either of the ESCs.
(28 April Update) The Delta Ray receiver antenna managed to get weakened and broken off through handling but it was repaired and passed a low power range check today. It will get a couple little spots of hot glue to insulate and hold the thin soldered wires to the PCB.
The wire is connected by two parts. The center core wire is the active antenna only for the ~31mm section at the end of the wire and it is soldered to the radio section on the receiver. Because the metal shield or outer wire covers the center core, it significantly block radio reception for the larger portion of the wire. The outer wire is woven metal over an inner insulation between the two metal parts called the dielectric layer and the woven metal is tinned and soldered to the PCB as its ground plane.
Feb 19, 2016, 11:29 AM
Up! Up! And Away!
GottaZoom's Avatar
Brushless build log
Jul 01, 2016, 03:22 PM
SystemsGuy's Avatar
Stunning!!!
Latest blog entry: FrSky Long Range!
Jul 01, 2016, 03:41 PM
Up! Up! And Away!
GottaZoom's Avatar
Originally Posted by SystemsGuy View Post
Stunning!!!
Thanks! Sure glad to have had many helpers. Planning to have a brushless maiden next week.
Jul 01, 2016, 03:43 PM
SystemsGuy's Avatar
My wife was a bit peeved to see me digging the DR out of storage! :-)
Jul 01, 2016, 03:46 PM
Up! Up! And Away!
GottaZoom's Avatar
LOL, maybe when she flies it she'll want it for her own.
Jul 01, 2016, 04:17 PM
SystemsGuy's Avatar
She's big into gliders at the moment - and far be it for me to complain! BTW - feel free to clean these up when you want the spots.
Jul 01, 2016, 05:47 PM
Up! Up! And Away!
GottaZoom's Avatar
I love catching thermals with the DR and hanging around up there with the hawks - maybe use ESCs that brake and folding props?
Mar 19, 2017, 10:02 PM
Up! Up! And Away!
GottaZoom's Avatar
Link from Imboeschi where he explained a possible reason for a blown mosfet in a DR receiver.
