Legend Models - VQ SBD-5 Dauntless 30cc ARF - RCGroups Review
Very few planes have the character and history of WWII that the Dauntless has. RCGroups reviewer Jerry Festa takes this iconic warbird for a test dive!
Wingspan:81"
Weight: 14.5 lbs.
Length:57 "
Wing Area:1103 sq. in.
Wing Loading: 31 oz/sq. ft.
Servos:</b> 3 standard, 8 mini (10-11 servos)
Servos used:4 standard 7 mini
Transmitter: 8 channel
Transmitter Used:JR 9303
Receiver: JR AR8000
Flight Battery: HydriMax 2000 mAh
Engine:26- 30cc gas or 1.60 Glow
Engine Used:DLE35RA
Motor:3000 Watt brushless DC motor
Manufacturer: VQ
Available From: JB Hobbies and Model Aviation, LLC
Webpage:https://www.jb-hobbies.com/
Price: $459.99
Many WWII aircraft had their 'day in the sun' as they say but few can be credited with turning the war around. The SBD Dauntless was such a plane and between June 3 and 7 1942 the United States not only found but sank four of Japan's large aircraft carriers—Akagi, Kaga, Soryu and Hiryu all of which were part of the six-carrier force that had just attacked Pearl Harbor six months earlier—and they also lost a heavy cruiser. The U.S. lost only the carrier Yorktown and a destroyer. The final verdict was that the USA was NOT neutralized at Pearl Harbor and tide of the war was turning in their favor. A lot of credit for sinking those four carriers was due to dive bombing from the Dauntless.
The most characteristic feature of the Dauntless is the split flap/dive brakes. As the dive brakes go up and the flaps go down the airplane will not keep gaining speed in a dive as much as 70 degrees. In fact to enhance accuracy, the SBD’s big perforated dive flaps slowed the aircraft’s descent speed to only about 276 mph (240 knots) and would drop their bomb at altitude between 1500' to 2000' followed then by a pull out stressing the plane and pilot to approximately 6G's! Needless to say all this time the plane was the center of attention from anti-aircraft fire. That took some well trained brave pilots to say the least.
VQ decided to add to the history of the Dauntless by releasing their 81" ARF that was designed around three types of power plants...1.60 two-cycle; 30cc gas engine; or a 3000 Watt brushless DC motor. For this review the DLE 35RA was selected. You cannot get the stunning effects of dive brakes without additional servos and this plane requires 10 or 11 servos depending on your power choice.
The kit is very complete and almost everything needed was supplied. The scale appearance is quite attractive and appropriate for the time frame when this plane played its role in WWII Pacific Theater. This ARF features many scale features such as functional dive brakes and flaps, pre-painted pilot AND a rear gunner, fiberglass cowl, radial engine facade, scale guns and sling bomb. And to aid in realism, the rear gunner gets to sit behind a plywood dual 50-caliber guns!
Kit Contents:
Here is what you get:
What you need to complete this ARF
Radio (recommend 7 channels or greater)
10-11 servo extensions of various sizes depending on radio
Flight battery/Ignition if using gas
Thick and Thin CA; "RC 56" glue for canopy
Center Wing Section
Things got off to a somewhat awkward start with page 2 of the manual (page 1 was installing the supplied fixed landing gear). Not many words can be found in this manual, just pictures throughout which is fine but only if you are an experienced modeler. Sadly this one lacked more than it should. Nothing serious, just lack of communication.
Page two (first picture) shows the electric retract unit being installed but its leads are directed toward a center servo. For the inexperience it would be assumed those two connect – the servo to the retract unit…(but you should ask where and why). Those retracts being diagrammed are electric and the leads are directed toward the center of the TOP of the wing where there is an exit hole! The retracts are totally separate from the servo!
Placing the optional electric retracts in the wing posed another concern…the units did not lie flat on the mounting blocks. They rock fore/aft! My buddy George and his critical fighter pilot eyes figures the triangle mounting reinforcements on the bottom of the retracts unit are striking the mounting blocks and if four little spots of wood could be removed from the blocks the units should lie flat – and they did! What a guy!!!
Some trimming of the plastic liner was necessary to clear the unit and permit an exit for the extension wires to snake around various ribs, formers, stringers and what have you to reach that center 'exit' hole. The toughest one was naturally the unit furthest from the hole. I would NOT recommend using those plastic clips that hold the retract unit's connector wire to the extension as they only complicate the procedure in reaching that center exit hole. I would recommend you use either heat shrink or some dental floss to secure that connection.
When installing the axles it was noticed they are just a bit too long so for atheistic reasons, about 1/4" was removed making the axle flush with both the wheel and the strut. Also some flat spots were created so the strut will hold the axle better.
One of the landing gears aligned perfectly straight ahead while the other had a little bit of toe-out. Two adjustment screws at the very bottom of the strut were loosened and the wheel realigned. Maybe I should add some toe-in but for the first flights I thought I would try straight and true.
Landing Gear Doors
Next question concerns the landing gear doors. The actual landing gear strut sits just about flush with the bottom of the wing and any doors added will extend into the air stream. So the dilemma will continue – the guys at the field at 75% leaving the doors off and 25% putting them on. Full scale had'em...and yes they are supplied BUT (don't ya just hate it when someone says that?) if you follow the instructions, you will end up with gear doors that sit about 1/4" above the wing when retracted and are upside down! Therefore place the curved part of the door next to the wheel - which is sadly mounted to the inside of the center line instead of facing outward like the full scale. After a dry run, the struts stick way too high off the wing and personally I think they do not look good, so another option will have to be tried.
The spacers for the doors were just too long resulting in the door being too far from the strut, so the spacers were cut down so they almost touched the strut itself.
To resolve the landing gear situation, the inside piece of the door (the one with the holes in it) was cut down so that part could fit inside the plastic liner and the outer door could thereby lie on the bottom of the wing.
The doors where then glued to the spacers with epoxy mixed with Micro-Balloons to give a nice finished look.
Center Wing Flap
The servo shown on page 2 is the center FLAP servo and if you look closely at the inside of the flap, you will see a control horn neatly hidden between the top of the flap and bottom of the wing, totally out of sight! Putting two and two together, a ball link that had already been connected to a push rod fits the bill and can be found in the hardware bag! Low and behold, that set up fits perfectly on the pre-installed control horn.
When setting up the flap servo (mini size) don't get too carried away just yet - as you will have to install two more flap servos - one in each outer wing panel and their orientation should all look exactlyalike. At this point it is fine just to have a push rod connected to the servo.
Both electric retracts required a 12” extension to reach the center of the wing panel and extend about 9”-11” outside the wing. At this point l changed to a long “Y” connector and removed the 12” extensions on the retract lessening one connector. So back to the drawing board, remove the 12" extensions and connect the "Y" extension (it would be nice if I could think ahead once in a while!). The flap servo did not need an extension and exits the wing with about 7” left over- long enough to reach 'somewhere' in the fuselage (a 6" extension from the receiver was used to simplify field assembly).
Outer Wing Panels
For the aileron servos, another “King Max” servo was selected and was installed without any difficulty. It was decided at this time to use a 24” extension as this would permit the connector to extend out to and exit the center section. At this point both aileron connectors would connect with a 'quick' disconnect.
Push rods and Clevis
The two aileron servos were standard size and were attached to a hatch that was secured to the wing with four screws. The push rods were 2mm and the clevises didn't seem to fit well as I could pull a clevis off the threaded portion of the push rod unless the clevis was threaded about 1/2 up the threads AND a lock nut was used to hold the clevis tight. I could substitute 2-56 push rods and appropriate clevis and probably would if this was not a product review but it is so I used all their hardware. If it fails, I'll let you know...better I lose one plane than MANY of you out there in R/C world:)
The next step was to install another mini servo to move those beautiful “porous” dive brakes. Installation of the servos was no problem but remember both servo connections have to move in concert with each other.
The next challenge was to get the three flap servos to play together and only trial and error can resolve the issue of one flap moving more than another or not enough. Take some time and adjust the push rods and/or servo arms so all three flaps move the same amount - especially the two outer ones!!! Likewise the two dive brakes should move the same amount and if that is accomplished but they don't move as much as the flaps, no problem - just make certain they move the same amount in relation to each other.
As a programming note, the dive brakes have to be connected to a separate channel and act as a master when deploying the ‘dive brakes’ which will include the flaps, but the option to use only the flaps has to be made available.
VQ Dauntless dive brakes / flaps (0 min 21 sec)
Putting this all together can be intimidating if you don't have a plan...I used some servo labels from "unclegeorge" ([email protected]) so connections can be made without errors.
Tail
The elevator servos (mini) were installed inside the stabilizer and used a short push rod to connect to the elevator. The elevators were already hinged and appeared well glued into place. The hinges were of the nylon-pinned type similar to the type Du-Bro produces. I took the extra precaution of 'painting' the inside of the elevator servo hatch with 30-minute epoxy securing the mounting blocks a bit more than hopefully needed. Some may also add a small wood screw through the hatch and into the mounting blocks to give an added insurance against failure - don't forget this plane will be powered by a gas engine and gas engines are known for their vibrations!
Tail Wheel
VQ did a very nice job of locating the tail wheel in a very scale-like location, but that meant some additional work was required. The tail wheel bracket was fitted with the wire and secured to the back of a former with four screws. Then it was discovered the steering arm lined right up with a threaded connector but the actual tail wheel arm would connect with a wire with a "Z" bend in it! I felt the size of the tail wheel was not scale and replaced with a smaller one.
The first activity of this entire project was to mount the engine after coating the firewall with 30-Minute Z-Poxy. The mounting was not difficult with the exception of tightening the lower two mounting standoffs. Once the engine was mounted a bit of wood had to be removed to clear the muffler and a hole was drilled for the throttle push rod.
The next agenda item was the installation of the elevator and rudder servos and to get 'sort-of' organized as the part list was few, the plane gaining weight and few pages left in the instruction manual. This is a time to get excited for sure. Cowl has to be mounted and some minor details worked out.
Some of the finer things in life that make a model appear more realistic are included in this VQ offering. For example there is in addition to the beautifully painted pilots a center line bomb to be build, a rear gun platform to assemble, a tail hook to create and a method of joining the outer wing panels to the center panel to create the illusion of a exterior joint. Because the Dauntless looks so cool with two crew members; they have to be out in the open, so the canopy has to be modified to let the fresh air circulate around them.
The CG was next on the list after finishing the 'cool' features and with both batteries mounted on the motor box the CG came out right at the aft end of the suggested range! What a relief - but that only happened when both the rear gunner and machine gun was removed (that's sad). Rather than add extra nose weight to compensate, the decision was made to make the first dozen or so flights without the guns and gunner. Mine balances around 6.25" back from the leading edge! It still flies slightly nose heavy, but I like it that way.
Bomb
Gun Platform
Wing Joint
Tail Hook
Engine
Spending my tax refund on a new DLE 35RA was a pleasure - at least Uncle Sam didn't get it, but Tower did. Being brand new one morning was spent getting familiar with the engine. Trouble at first - it wouldn't run without fuel. Turned out the fuel line to the carb was plugged with probably flux when the barbs were soldered on the brass lines.
Once that was cleaned out we got that puppy running and run it did. Right out of the box the new DLE 35RA idled right at 1800 rpm and top end near 8800 rpm with a Xoar 19/8. Kept the 30:1 Redline flowing just enough to drink about 2/3's of a tank at 2500-3000 with breaks of going from idle to 3000 and back again. After running for 5 minutes, we took a break and when we tried starting the engine again, it started on the 4th flip! I'm a happy camper!
What exactly does SBD stand for anyway? The Navy called it a "Scout Dive Bomber" (shouldn't that have been SDB instead of SBD?) Anyway, the full scale was nicknamed "Slow But Deadly" for a good reason, as the top speed wasn't that fast compared to many of other warbirds at that time. And the same goes with this model...it isn't a rocket ship and even in a dive that large radial cowl and dive brakes keeps the speed nice and scale like. Due to the CG requirements, both the rear gunner and machine gun are removed for flying and reinserted for static situations. Everyone agrees the engine/plane combination is right on.
The Dauntless will do the 'normal' warbird maneuvers - loops, rolls, stall/spin, and hammerheads. Recovery from a spin is surprisingly quick and stable. Of course the best of the best maneuvers is the low, fast fly-by. Sadly in order to do a good 'dive bomb' you have to be pretty high and you really can't see the dive brakes/flaps because in order to not pile-drive the plane into the ground, two switches (dive brakes first, then flaps) have to be activated but yet have time to control (elevator) the pull-out. That was later changed to activate both dive brakes and flaps at the same time, on one switch! Both the dive brakes and flaps have a slight delay so after the switch is activated, it takes a bit of time for those control surfaces to return to their normal position. Be extra careful matching the flaps degree of deployment as mine was just slightly off and the effect was pronounced!
Our first take off was aborted when the Dauntless decided to make a strong left turn just as it was about to fly resulting in a bent landing gear on the right side. The strut didn't bend, the retract unit didn't come out of the wing but the short piece of 5mm steel that fits inside the strut bent. Not to be denied an opportunity to see this bird fly, Shane got a hammer and straightened that piece out in no time! Note to self: replace those pieces with something harder!
The second attempt at taking off was more successful but the plane seemed out of trim, wanting to climb and turn left. So a couple of trips around the circuit resulted in a relatively fast plane flying straight and level. Whereas George was filming this adventure, he called out for a low pass so he could capture the Dauntless in all its glory. With the DLE35RA sounding good, I throttled down a bit so we could get a nice slow fly-by and when about 3/4th of the way down the runway I powered up and the engine quit!
Knowing what would lie ahead if I tried to stretch the glide (not knowing if this was even possible), some quick down elevator brought the Dauntless down quickly and by misjudging the flair I 'planted' her firmly on the runway. The damage was relatively minor: two bent landing gears and a lose cowl. Yep, the same 5mm (soft) steel inner strut was bent again. In the video the part that flies off was the pilot trying to bail out, but he also misjudged the flair!
The steel insert was replaced with some 3/16" landing gear wire from a previous plane. Ron astutely said, "Yes those original inserts bent but the units themselves remained unscathed in the wing. If they had not bent, maybe your WING would have needed repair!" Good point Ron, I just have to remember to grease those landings, and by the way, the prop wasn't broken so it must have been a good landing (ha ha).
The most spectacular maneuver was the dive bomb and as explained earlier, is not for the slight of heart, as you need a 70-degree or more angles and a set of quick fingers. So we decided to 'dive' at a 45-degree angle just for fun and there you can see the dive brakes/flaps at work.
Sorry but this bird is not for the novice due to its complex assembly and warbird characteristics on landings and take offs.
Legend Models/VQ 81" SBD-5 Dauntless 30cc ARF - RCGroups Review (14 min 21 sec)
You want a warbird that will catch everyone's eye along the flight line? How about an 'everyday' fun flying giant scale warbird? If the answer to both questions is yes, consider this sized VQ Dauntless! The 35cc engine was (IMHO) the right choice and in spite of the Arizona's heat, pulled the Dauntless around with authority. I'm very happy with this airplane. After beating this bird up for almost 3 months, the only problems I have come across are related to the landing gear - not the retract unit itself, but the steel strut between the actual shock absorbing strut and the retract unit. Once that was upgraded to a stronger steel, the gear held up VERY well. The landing gear blocks could use some additional glue as they are only glued to the ribs and some sheeting. Other than that, this bird is a keeper!!!
Pluses
Very Complete kit!
"Extras" included two pilots, bomb, tail hook, landing gear doors, etc.
Functional Dive Brakes.
Flaps and dive brakes linkage all hidden.
Great color scheme.
Laser-cut parts.
Fixed gear option.
Minuses
Landing gear has wheels mounted on wrong side of strut (for scale).
Landing gear mounting blocks could use additional reinforcement.
Manual needs improvement.
Tail wheel too large.
Main strut's inner metal strut too soft.
Tail gunner and machine gun weigh a lot (5.5oz) and they are behind the CG!
Jul 14, 2016, 02:24 PM
DFC~ We Do Flyin' Right
Vapor Trails's Avatar
nice review... love the SBD
Jul 14, 2016, 02:35 PM
tailskid2's Avatar
Thank you Vapor Trails......
Jul 14, 2016, 02:43 PM
unclegeorge's Avatar
Most complete review on this plane, Now I want one. Great use of Servo Plug labels too. Let me know if you want to order some for only $2.99 for 5 planes. [email protected].
Keep em flyiun!
Jul 14, 2016, 05:23 PM
Arrowhead
Nice review!
Btw, "SBD" stands for Scout Bomber, Douglas. Last letter in USN aircraft designations in that time were the manufacturer. Avenger TBF's were made by Ford; the ones produced by GM were TBM's.
Jul 14, 2016, 08:50 PM
Technica's Avatar
Nice review.
What's a "Lazar"?
Jul 14, 2016, 08:57 PM
tailskid2's Avatar
Typo....LASER.....sorry about that....good catch!
Jul 14, 2016, 09:03 PM
If it's R/C, I LIKE IT!
Nikolei Zinsli's Avatar
Nice looking plane! Nice flying despite your gear troubles.
Latest blog entry: 93" AJ Laser 230z
Jul 15, 2016, 05:10 AM
Ldm
Ldm
Ldm
Ldm's Avatar
Great review . I love my kit still gathering parts and will be my first built this winter. Not sure if I will use a 4stroke 180 or fly epower.
I am really struggling with the retracts . The plane seems so nice to have the wheels going to wrong way.
Found a few options
1) Sierra gear, I think Uncle Joe went that direction, not sure of the gear length and how the plane sits because the Sierra gear is made for the 71" ESM Dauntless not an 81" model.
2) Found ourward electric powered retracts on the RCAreodyne but they have no contact info, don't answer email so I won't shell out $200 for retracts to a company that is a stealth of any customer servace. You can buy from the site but you can't ask questions or get a real person.
3) Hobby King -they offer the same "looking" outward retraction units for $50, less aprox $150 in total. Problem is the site ratings show three stars because the control board has issues. However knowing how to remove the board and add a separate retract control unit is rather easy so this may be my pick.
When I say outward retract, the retract motor is on the far side of the retract strut. This allows the strut to sit lower in the wing. This would then allow a better chance for the wheel to sit properly in the well.
I am looking forward to the build but will proceed with extreme caution. My smaller VQ Dauntless is 100% assembled but as stated in the other thread some of my wing angles are off.
I am not happy with the final fit and these variance were created at the factory with hard points that are difficult to adjust.
I have to make some mods before the smaller Dauntless can take to the air.
On the larger Dauntless I am going to use two pilots but will make my own from lighter materials. The pilots in the kit are truely excellent and the Heavy medal warbird guys that don't mind weight will easily use them. As stated in the reveiw the gunner will create the need for more nose weight but some guys don't mind that, for me I with the reviewer I would rather leave the guy out or change the pilot.
I have to back the OP/Reviewer on anyone that is sitting on the fence about this plane. Out of the box it appears super cool, super quality and well worth the money.
One of the best values in RC considering the details and quality of the kit.
VQ use to be know for covering that was over-done , in the new model they really have the covering executed properly.
I plan on the getting the Bearcat as my next VQ , they keep stealing my money with all these great planes !
Jul 15, 2016, 02:53 PM
tailskid2's Avatar
Here are a couple of pics of UncleJoe's Dauntless sitting in the pits....and one with UncleJoe
The mfg's retracts work well and have been trouble free since I replaced the metal piece as explained in the article....by the way, UncleJoe's plane was electric powered and flew great!
And he used both the gunner AND machine guns in the back!
Jul 18, 2016, 10:54 PM
Denny the "Finger"
D_Wright's Avatar
Great review, Jerry. I think you covered it all very well.
What is your AUW?
Jul 18, 2016, 11:27 PM
tailskid2's Avatar
Final weight was 14 pounds 5 ounces and thanks for the kind words! Flew it again today....got to work on one of the flaps. It appears one of the pushrods is a bit soft and doesn't hold the flap in the air stream well.
Jerry
Jul 18, 2016, 11:34 PM
Denny the "Finger"
D_Wright's Avatar
I read 14.5 at the start but was hoping it was a typo, lol.
Jul 19, 2016, 02:50 AM
tailskid2's Avatar
I can add some weight if you wish
Jul 19, 2016, 05:43 AM
Ldm
Ldm
Ldm
Ldm's Avatar
How can there be a 4lb difference between the review model and another model in the thread ? (Almost 5lbs when CG weight will be added ) ?
Also Tailskid, was wondering why you did not make the servo block reinforcement mod discussed in the main thread ?
