This thread is privately moderated by cmdl, who may elect to delete unwanted replies.
Feb 10, 2016, 10:35 AM
http://www.sgvhumane.org/
cmdl's Avatar
FAQ
Useful resources
Motor/ESC/Prop/Servos
Pitch speed
Current increase with voltage increase
Extending lipo<->ESC wires
Keeping same pitch to convert between different bladed props
Keeping same load factor (using diameter squared gives more conservative estimate) to convert between different bladed props
Motor attributes
Prop attributes
JST connectors
95% travel adjust on micro servos
Motor wire gauge 1
Motor wire gauge 2
Servo wire gauge 1
Servo wire gauge 2
Lipos
Store in fridge 1
Store in fridge 2
Do not store long term fully charged (cell thermal runaway is unlikely to occur in a cell at a low SOC, < 50%) 1
Do not store long term fully charged (cell thermal runaway is unlikely to occur in a cell at a low SOC, < 50%) 2
Do not store long term fully charged (cell thermal runaway is unlikely to occur in a cell at a low SOC, < 50%) 3
Charge to 4.15 V/cell 1
Charge to 4.15 V/cell 2
Although optimal charge level is 3.92 V/cell
New lipo break-in
Capacity vs voltage 1
Capacity vs voltage 2
Performance tool
Supporting database for performance tool
Balance plug wiring
No negative impact from charging @ 2C, 3C
Paraboards and harnesses
IR 1
IR 2
Low temperature treatment 1
Low temperature treatment 2
Flight
Always check CG
Watts/lb
Static thrust
Read till post #30 - interaction of throttle & elevator
Wind affects aerodynamics 1
Wind affects aerodynamics 2
1s plane BL conversions
UMX B-25
UM P-51
Using X-Port on AR6400
AR6400 manual
XP-7A manual
Main thread
Current draw data
2s to power 1s brick
Don't use the Nano CP X BL
2s Spitfire
Glue
https://www.rcgroups.com/forums/show...2&postcount=11
Careful! Wasserman Schultz Sued By Opponent Tim Canova for Illegal Use of DNC Resources traceyl Life, The Universe, and Politics 3 Aug 10, 2016 10:12 AM
