RD210 Mini Quad - Page 4 - RC Groups
Feb 22, 2016, 12:48 PM
Originally Posted by trinco
To those who would like to use "Custom Motor Mixer" these are the codes.
It will fly like a true square X quad.
Multiwii
Code:
motor[0] = PIDMIX(-1,0.788,-1);
motor[1] = PIDMIX(-1,-0.788,1);
motor[2] = PIDMIX(1,0.788,1);
motor[3] = PIDMIX(1,-0.788,-1);
Baseflight/Cleanflight before 1.10
Code:
mixer custom
cmix reset
cmix 1 1 -1 0.788 -1
cmix 2 1 -1 -0.788 1
cmix 3 1 1 0.788 1
cmix 4 1 1 -0.788 -1
Cleanflight from 1.10 onwards
Code:
mixer custom
mmix reset
mmix 0 1 -1 0.788 -1
mmix 1 1 -1 -0.788 1
mmix 2 1 1 0.788 1
mmix 3 1 1 -0.788 -1
Awesome! saves me all the work of doing it myself. I absolutely cannot wait for this one lol. Still got a month left of snow until I can get out and fly but that will give me plenty of time to get what I need for the build.
So far i'm thinking LB30a RCX 2933 and run some quad blades on there. Should make for a good time.
Feb 22, 2016, 04:16 PM
Crash specialist
pFrancisco's Avatar
Thanks for the custom mix trinco. My frame should arrive this week hopefully.
Feb 25, 2016, 02:47 AM
Rd210
Something arrived .
Feb 25, 2016, 03:00 AM
Inside the plastic box . Really nice package !!
Feb 25, 2016, 04:47 AM
Hey sorry to interrupt.
Hoping you guys and gals could lend a hand in getting a dedicated micro multirotor thread started.
Simply post a quick reply HERE.
Please and thank you in advance.
Feb 25, 2016, 09:02 AM
Assembled RD210 !!
This frame is really small (see the picture - my hand is truly small) and light as well !!
Looking to build it soon.
P/s: Part 4 in manual is a bit tricky. You guys will know what I mean .
Feb 25, 2016, 05:12 PM
☢ ɴᴏᴏʙ ☢
trinco's Avatar
RD210 Build Log
Since all the edges are too sharp i had to sand down the edges to make it smooth. These were all the parts that i've chosen to sand down.
A closeup picture of the sanded edges. Pain in the ass job but worth it.
Sealing the edges of the carbon fiber with CA glue which further helps to prevent the separation (de-lamination).
For this build im going to be using Littlebee 30a ESCs all flashed with BLheli Rev.14.4.
X-Racer F303 flight controller and dual regs PDB ready for installation.
Also HS1177 (Top Connector) cam ready for installation.
All the ESCs has been soldered to the PDB and FPV cam installed.
Since everyone is talking about this motor i decided to grab a set. (EMAX RS2205 2300kv Red Base/Baboon )
Flight controller and motors installed. All the ESCs heat shrink tubed. So far im done with the lower part of the build.
Time to finish up the upper part of the build. Im going to be using Frsky X4R-SB (SBUS) 2.4ghz receiver and 5.8ghz video transmitter TS5828 modded.
For the final installation i use 3M double-sided tape to secure both RX and VTX on the top plate. Also im using the chinese clone SpiroNET antenna.
Finally all done! It came up at 369 grams without the gopro plate, almost 80 grams more heavier then my RD180 build.
S E X
Feb 25, 2016, 05:57 PM
lougedo's Avatar
S E X
KABOOOOOOOM!!! pretty nice photos master T.
I also have received mine! yuhuuu
Feb 26, 2016, 09:40 AM
☢ ɴᴏᴏʙ ☢
trinco's Avatar
Thanks lou
If you guys have a build log please do post them.
I will link your build log in the front page, under build log section.
Feb 26, 2016, 10:32 AM
Razip
tempting!
Feb 28, 2016, 11:50 PM
Crash specialist
pFrancisco's Avatar
Got my frame Trinco! You did an amazing job with the design. I will be doing a build log once I get some free time but for now, here is a teaser.
Feb 28, 2016, 11:53 PM
dry your eyes and go fly
joe559's Avatar
so beautiful, guess mine will be coming soon
Feb 29, 2016, 04:02 AM
☢ ɴᴏᴏʙ ☢
trinco's Avatar
Thanks!
Looks like we're using the same motor
Is that thug or birdseye's PDB?
Feb 29, 2016, 10:55 AM
ni9htfury's Avatar
trinco, any chance it might fit this prop?
http://www.hobbyking.com/hobbyking/s...CW_Orange.html
Feb 29, 2016, 11:19 AM
☢ ɴᴏᴏʙ ☢
trinco's Avatar
Unfortunately nope
The clearance/gap from the end tip 5" prop and front standoff is around 2mm, almost the same like QAV210.
