Feb 05, 2016, 10:20 PM
rctimer's Avatar
New Product
BeeRotorF3 AIO (BRF3) Flight Controller (integrated OSD) Discussion Thread
Rctimer just released the new BeerotorF3 (BRF3) all-in-one (AIO) flight controller
BeeRotorF3 Manual: http://www.rctimer.com/download/BeeRotorF3Manual.pdf
BeeRotorF3 Firmware: https://www.dropbox.com/sh/jx9ur2isk..._vLa8K13a?dl=0
Check out the full review and guide here: https://nathan.vertile.com/blog/2016...ht-controller/
BRF3 OSD set, http://rctimer.com/download/BEEROTORF3OSDSet.pdf
Buying Options
Australia
buzzhobbies
http://buzzhobbies.com.au/index.php?...product_id=960
China
Rctimer
http://www.rctimer.com/product-1592.html
USA:
Diyquadcopters
Inspectorflyuav
Visaliahobbies
Features
Optimization for Cleanflight/Betaflight firmware
ARM Cortex-M4 core STM32F303CC with 32bit/72MHz/256K Flash/40K SRAM and hardware floating point unit
MPU6050 and BMP180 / BMP280 Sensors
Build-in 8MB flash for black box log recorder
On board OSD with absolutely original MAX7456EUI+ and standard FTDI debug port
Receiver connector with PPM/SBUS/SumD/DSM2/DSMX and RSSI input
Up to 3 serial ports and 8 PWM outputs
Multifunction connectors with SWD/UART2~3/Soft-serial/Buzzer/LED trip/Voltage detection
Multifunction OSD connectors with video_IN/ video_OUT/ICSP/debug port (UART1)
PDB connector with 5V input/Current and Voltage detection
Power input reverse polarity protection
Specification
Power input: 5.0~5.5V
Dimension: 35x35x9mm
Fixing hole spacing: 30mm
Weight: 7.3g
PPM/RSSI/SBUS/SumD Receiver Cable
Camera/video-TX cable
Buzzer/LED strip/voltage detect cable
OSD debug port to FTDI adapter cable
BR-PDB: www.rctimer.com/product-1593.html
which carries a shunt resistor current sensor and 28v (6s) compatible MP1593DN voltage regulator.
If BR-PDB work with BRF3, you need reset the Voltage scale to "210":
Default OSD
File: http://rctimer.com/download/BRF3.rar
BeeRotor FC Airplane Setup with Cleanflight Part 1 (Introduction):
BeeRotor FC Airplane Setup with Cleanflight Part 1 (Introduction) (12 min 49 sec)
BeeRotor FC Airplane OSD Setup with Cleanflight Part 2
BeeRotor FC Airplane OSD Setup with Cleanflight Part 2 (19 min 37 sec)
BeeRotor FC Airplane Setup with Cleanflight Part 3 (D4R PPM, ESC Cal, Servos)
BeeRotor FC Airplane Setup with Cleanflight Part 3 (D4R PPM, ESC Cal, Servos) (13 min 9 sec)
BeeRotor FC Airplane Setup with Cleanflight Part 4 (Install in Plane, Configure, LC Filter, Flight)
BeeRotor FC Airplane Setup with Cleanflight Part 4 (Install in Plane, Configure, LC Filter, Flight) (9 min 37 sec)
BeeRotor FC Airplane Setup with Cleanflight Part 5 (OSD FPV Test Flight)
BeeRotor FC Airplane Setup with Cleanflight Part 5 (OSD FPV Test Flight) (4 min 20 sec)
BeeRotor FC Airplane Setup with Cleanflight Part 6.0 (Flight Modes Setup)
BeeRotor FC Airplane Setup with Cleanflight Part 6.0 (Flight Modes Setup) (12 min 39 sec)
BeeRotor FC Airplane Setup with Cleanflight Part 6.1 (Flight Modes Test Flight)
BeeRotor FC Airplane Setup with Cleanflight Part 6.1 (Flight Modes Test Flight) (4 min 53 sec)
BeeRotor Airplane Setup with Cleanflight Part 7.0 (Installing Micro GPS)
BeeRotor Airplane Setup with Cleanflight Part 7.0 (Installing Micro GPS) (13 min 1 sec)
BeeRotor Airplane Setup with Cleanflight Part 7.1 (Micro M8N GPS Flight Testing)
BeeRotor Airplane Setup with Cleanflight Part 7.1 (Micro M8N GPS Flight Testing) (10 min 7 sec)
Feb 05, 2016, 11:01 PM
subbed
Feb 06, 2016, 10:41 AM
Multirotor Promotor
RaymondM's Avatar
subscribed
Feb 07, 2016, 09:03 AM
Looks good but I hesitate to try it after trying the OZE32 and getting one of the early ones that was faulty out the packet.
Feb 07, 2016, 10:21 PM
Subbed
Feb 09, 2016, 06:57 AM
How much of a risk am I taking buying this flight controller? I went through 2 of the OZE32's, both were faulty out the packet, RCTimer will only offer me a $10 refund. I don't want to be ripped off by rctimer again!
Feb 09, 2016, 07:49 AM
This is starting to cost money
I'm hopefully going to pick one of these up from my local Aussie supplier tomorrow so I can let you know how I go
Feb 09, 2016, 09:23 AM
Australian Supplier
buzzhobbies's Avatar
i have been playing with one on the bench today and it is great so far - will hopefully be in a quad by the weekend. nice clean layout compared to the all in one - the split between the flight controller and the pdb is nice.
Feb 09, 2016, 10:28 PM
Annnnd there is my local Aussie supplier
Feb 11, 2016, 12:48 PM
Fly Now.
Buzzhobbies, do you know if this will fit into an Indy250FPV? As I'm sure you know, the Indy has the ESC pins embedded to the PDB which is all designed for the CC3D. If this fits, it could be a great upgrade for Indy250 flyers.
Edit: Looking now at the picts, I can see that the pins are located in different locations. I imagine with some right-angle pins you could use some jumpers to make it work. Any thoughts would still be appreciated.
Feb 12, 2016, 01:08 AM
rctimer's Avatar
Hi Parke,
You can remove the slot on PDB, it can work with BRF3.
Thanks.
Frank
Latest blog entry: BeeRotor BLS20A used DSHOT
Feb 12, 2016, 08:32 AM
If the flight control FrSky SBus Compatible?
Feb 12, 2016, 06:06 PM
rctimer's Avatar
Yes, compatible.
Feb 13, 2016, 09:24 AM
This looks great! About time someone incorporate open source OSD. Well done!
Feb 13, 2016, 12:46 PM
Quadaholic
How do you program the OSD?
