Feb 05, 2016, 01:52 PM
Using TGY i6 to get 6 switch modes w/ original firmware
I am not usually one to post this type of stuff, but I had such a difficult time trying to find the info on the net, I decided to post my solution here. I have a TGY i6 with original firmware and wanted to set up a 6 position switch mix for APM. Here is my solution for anyone else struggling.
First I changed the end points for CH 5 to 67% and 72%.
I left the end points of CH 6 at 100% and 100%.
I then set channel 5 to the three position switch (SW C) and channel 6 to SW D.
I then set up two mixes
Both mixes set up channel 5 as a slave and 6 is the master.
For mix 1 I set up a positive mix of 60%, neg mix of 0% and 0% offset
For mix 2 I set up a positive mix of 0%, neg mix of 68% and 0% offset.
It took me quite a bit of playing around with mission planner and my TX, but I got there. Hope this saves someone else the work. If anyone out there can set up an excel spreadsheet that mathematically figures this out, it would be very helpful as I really don't understand how it all works.
Feb 05, 2016, 06:28 PM
Jaketheone46
You should add this to the i6 thread as well..this will most likely be seen more there..I have the i6 and will be using it come summer along with the i10 as well and hope I can find this if needed..
