Feb 03, 2016, 05:19 PM
Your #1 Source for Quality FPV
EMAX Yin Yan's Avatar
New Product
EMAX Skyline32+OSD Flight Controller!
Emax Skyline32 + OSD Flight Controller (2 min 5 sec)
Description:
Skyline 32 Flight Controller + on board OSD to simplify your FPV build. No more complicated set up procedure. No more unreliable external OSD module. With a simple flick of a switch, the OSD can easily and quickly be turned ON or OFF. The OSD is integrated into the Flight Controller so setting up is simple.
Connect an fpv camera (Video-In) and video transmitter (Video-Out) directly to the Skyline 32 + OSD Flight Controller board. (Need separate power source for both camera and vtx).
With MW_OSD pre installed on the Skyline32+OSD, the pilot can change PID on the spot through OSD without having to connect to a computer. Simply use the transmitter’s stick commands and follow the OSD menu. Supports PPM signal via Channel 1 in RC_IN port (UART2), and supports SBUS signal via Channel 4 in RC_IN port (UART2).
OSD......Virtually no set up.
Preloaded MW_OSD firmware is tightly integrated with the rest of the flight controller.
Using nothing but the transmitter and video goggles, the user can access:
-PID, RC rate, expo, Roll/Pitch/Yaw Rate, TPA
-Voltage alarm, voltage values and option to turn on/off voltage display
-RSSI monitoring and management
-With an optional current sensor, one can keep track of amp draw.
-With optional GPS module, one can check GPS coordinates, speed, distance, altitude (altitude read out available on Advanced version)
-Overall Timer, Flight timer, Flight statistics, etc.
**For more info regarding MW_OSD, check this website: http://www.mwosd.com/
***PLEASE BE SURE TO TURN OFF THE OSD WHEN MICRO-USB IS IN USE***
Key Features:
Run Cleanflight, Betaflight, or Baseflight
Wire-to-Board micro connectors.
Built-in gyro/accelerometer, magnetometer (Advanced Version also includes barometer and magnetometer)
Blackbox ready.
Thin and ultra compact for clean/tight builds.
Uses top quality electronic components and high precision SMT.
32-bit ARM micro processor running at 3.3v / 72MHz.
Fly in Manual Mode, Angle Mode, Horizon Mode, Head-Holding Mode, Head-free Mode, and Altitude-Hold Mode (Altitude-Hold Mode is available in Advanced version).
Supports Quad-,Tri-,Hex, Octo-, various multirotors.
Flexible RC Input: PPM, Non-Inverted SBUS, PWM.
Flash to latest firmware through the Micro-USB (**NOTE: Please be sure to leave OSD switch OFF when using Micro-USB).
GPS Hold / Return-To-Home Feature supported (GPS module needed).
Specification:
Dimension: 35mm x 35 mm x 5 mm (30.5mm Mounting)
Weight: 4.8g (W/O wires)
Included:
1x SKYLINE32 +OSD (Acro of Advanced)
2x RC breakout cable
1x vBat cable
1x buzzer cable
2x UART cables
4x Nylon Standoffs and nuts
1x Header Pin Assortment (Straight and 90 Degree)
Pick up your Skyline32+OSD Flight Controller today!
Skyline32+OSD (Acro)
http://www.emaxmodel.com/emax-skylin...ller-acro.html
Skyline32+OSD (Advanced)
http://www.emaxmodel.com/emax-skylin...-advanced.html
Note: SKYLINE32+OSD hardware is compatible with NAZE32 firmware, including cleanflight, baseflight. Below are the links to the source codes:
https://github.com/cleanflight/cleanflight
https://github.com/multiwii/baseflight
screenshot windows 7
picture host
adult picture hosting
image post
free image host
pic upload
image hosting over 5mb
how to print screen on pc
screengrab
<iframe width="640" height="360" src="https://www.youtube.com/embed/rUmybcRZLYc?rel=0" frameborder="0" allowfullscreen></iframe>
Feb 03, 2016, 11:52 PM
Deleted.
Feb 05, 2016, 10:36 AM
Some call me the other guy!
DoctorAudio's Avatar
I would like to see some video of this working, setup menus look great.
Please post some videos of it all working together?
Thanks!
Feb 05, 2016, 05:24 PM
NoobRC.com
thatjoshguy's Avatar
Looking at that punout I'm guessing you need to update OSD software with an FTDI programmer?
Feb 05, 2016, 05:38 PM
It comes preloaded with MW_OSD, but if you want to update or flash with any other open source osd software, then you need an FTDI. Solder pads are available to directly access osd.
Feb 06, 2016, 01:04 AM
I like it, with one exception. The solder pads. These boards will take some impact. The pads need to be the perforated kind that help to prevent the pad from pulling loose.
Feb 06, 2016, 07:15 AM
not surprised.........
CaLviNx's Avatar
Pity people in Europe are being shafted on the price !! if you try to buy in dollars the price shows $37.99
Try to buy in sterling it shows £37.99 which equates to $53.00 !!!!
And try to buy in Euro it shows €37.99 which equates to $41.29
So something is seriously wrong with the ordering system
Feb 06, 2016, 08:19 AM
What's the difference between accro and advanced board ?
Feb 06, 2016, 11:08 AM
Too bad this is another F1 board and doesnt use the faster F3 processor series. (STM32F3)
How does it compare to other 'All In One' FC's like the FLIP32 AIO? Same price...
Feb 06, 2016, 04:13 PM
CaLviNx's Avatar
The Acro board has no barometer or magnetometer whereas the advanced board does.
Feb 09, 2016, 04:36 PM
Hello Calvinx,
The prices are all fixed. Thank you Calvinx for pointing that out. All exchange rate is now up to current.
-EMAX
Feb 09, 2016, 07:14 PM
JulianGoesPro's Avatar
Interesting!
What does "Blackbox ready" mean?
Feb 09, 2016, 07:46 PM
Originally Posted by JulianGoesPro
Interesting!
It has onboard flash so you can use the blackbox fumctionality of cleanflight (i.e data recorder). Do a flight while recording data, land, download data and analyze it.
Different PID values effects on Quadcopter performance - Blackbox Data Cleanflight Naze32 OpenLog (13 min 53 sec)
Feb 10, 2016, 02:56 AM
https://www.youtube.com/watch?v=0hJfJvDp16E
Haha thanks I am aware of BB recording I am just not sure what the word "ready" should tell me... do I still need the OpenLog, thanks for clearing that up!
Feb 10, 2016, 06:29 AM
following
Sold Emax Skyline32 + OSD flight controller flavien317 Aircraft - Electric - Multirotor (FS/W) 0 Oct 22, 2016 05:12 AM
