Moka Berserker/Build and discussion - RC Groups
Feb 03, 2016, 11:26 AM
Copter Design
New Product
Hi
we are proud to present the Moka Berserker race frame designed from the ground up to win. It features lightweight design and low surface area to maximise your forward kinetic energy.
http://mokaframe.com/berserker
The Moka Berserker
is a 210mm frame. It is designed specifically for the highest level of drone racing competition. Its design features make it faster and more agile than most of the frames on the market, yet making no compromise for strength and durability.
Place as much mass as possible close to the axes of roll and pitch rotation.
Keep AUW “all up weight” low as possible while allowing for high power output. Dry frame weight is 86 grams and 114 grams with all fasteners
Different mounting options for the arms, allowing for the center of thrust to be placed at the center of gravity.
Specification and Features:
Dry frame weight is 86 grams.
Assembled weight possible of 339 grams W/O HD camera or lipo.
Ideal center of gravity location.
Rigid bracket system for arms configuration.
Symmetric weight distribution front-rear and side-side.
Super low top fuselage deck keeps mass as low as possible
Durable robust design that is highly resilient to crashes.
210mm frame size optimized for 2204 to 2208 motors paired with 5″ props
Different arm options: 250mm (6″ props), 210mm (5″ props) and 180mm (4″ props), keeping the same base
High quality twill weave 3K matt carbon fiber construction.
High quality anodized aluminum frame brackets and standoffs.
Arms are 4mm thickness.
Key features are:
Symmetrical motor locations at 210mm (180mm, 250mm) diagonal spacing.
Low weight at ~86 grams.
Ultra low surface area for reduced wind resistance at high speed
Thick CF Arms 4mm and 1.5mm for bottom plate and 1.5mm for top plate
16mm wide arms
Extensive protection for camera
Lower deck 20mm profile for strength
Innovative structural system and component layout.
M3x20mm and M2.5x20mm aluminium fasteners to reduce weight.
Supports 2208 motors and 6in props
Up to 30 degrees camera tilt
Moka Berserker Quick intro (1 min 19 sec)
Moka Berserker snow bash - Crash Clean Fly Repeat (0 min 44 sec)
Feb 03, 2016, 05:01 PM
Here are a few pictures of my build. I'm really loving the sturdiness of the frame and the fact that I can have my center of gravity nice and close to the center of thrust.
Some other neat things, the mounting hardware for the fpv cam and the boards comes with it!
Rmrc seriously dodo flight controller
littlebees 20A esc
Rcx 2208 1800kv (on picture), changed now to 2205 2350kv
D4-r2 receiver
FT952 200mW vtx (on picture), now running readymaderc crickets
FPVFreak antenna
Fatshark 700tvl
Feb 03, 2016, 05:03 PM
Some more videos of my trip out to california with it:
Moka Berserker - California fpv trip freestyle Part 1 (1 min 57 sec)
Moka Berserker - fpv freestyle at the Trona Pinnacles (2 min 34 sec)
Feb 04, 2016, 10:52 AM
Copter Design
Review #002 : Moka Berserker | 210 FPV RACING FRAME
Review #002 : Moka Berserker | 210 FPV RACING FRAME (5 min 6 sec)
Feb 04, 2016, 11:59 AM
Copter Design
PDB coming soon
Feb 04, 2016, 01:24 PM
Price?
Feb 04, 2016, 01:34 PM
Copter Design
Originally Posted by downloader9
Price?
Feb 04, 2016, 01:39 PM
Originally Posted by rosiris3
Thanks, quite interesting.
Feb 04, 2016, 03:47 PM
bigboyneverleft's Avatar
This frame ticks all the boxes when it comes to bricks/coffins.
Just one question: why not to make shorter standofs towards the middle on top of FPV cam so the carbon plate is tilted and there is no need for a gopro/yi mount?
I really like that frame.
Feb 04, 2016, 05:07 PM
Copter Design
the frame is designed for all users. but nice idea you can costumize your frame by changing the standoff
Feb 04, 2016, 08:40 PM
bcc1955's Avatar
Ditto, love the Moka 210 but as is.
One can not easily mount carbon plates at an angle to a standoff.
Feb 04, 2016, 08:47 PM
Copter Design
yes no need mods
Feb 05, 2016, 09:36 AM
Interesting idea there, that would require maybe some tilted washers, but some people may prefer having their hd cam flat. I think the freestyle folks mount theirs flat
Feb 05, 2016, 09:37 AM
Moka berserker review and build
Moka berserker review and build (4 min 27 sec)
