Aug 03, 2004, 05:00 PM
JAS
JAS
JAS's Avatar
Composite-ARF Impact pictures
Hi all,
Here are some installation pics of the Impact I flew at the Nats.
Here is of the Futaba 9151 aileron servo (Du-Bro arm).
Aug 03, 2004, 05:01 PM
JAS
JAS
JAS's Avatar
Aileron linkage
Here is the 4-40 Du-Bro all-thread aileron linkage (actually Rhapsody aileron linkage)
Aug 03, 2004, 05:03 PM
JAS
JAS
JAS's Avatar
Rudder horn
Here is the rudder horn and the stab tube holes and cut-outs in the fuselage for the elevator servos to go into.
Aug 03, 2004, 05:09 PM
JAS
JAS
JAS's Avatar
Elevator servo set-up
Here is the elevator servo with linkage. I had to open the root rib to accept the Futaba 9650 servo's and open the skin to slide them in from the inside so they wouldn't hit inside the fuselage.
TeamZiering
enigmabomb's Avatar
Where'd you get the cool twisty control rod? Those look useful.
Joshua
Aug 03, 2004, 05:11 PM
JAS
JAS
JAS's Avatar
The other pic.
Aug 03, 2004, 05:14 PM
JAS
JAS
JAS's Avatar
The tail wheel
Here is a 1" Du-Bro park-flyer wheel on 1/16" music wire.
Aug 03, 2004, 05:18 PM
JAS
JAS
JAS's Avatar
Battery tray
The battery trap is 1/4" end-grain carbon/balsa from BVM. It is glued to the wing tube sleeve and the landing gear front former. The Mas-90-Acro is velcro'd to the fuselage. One side of the Y goes outside the fuselage as does one battery lead for final connection.
Aug 03, 2004, 05:22 PM
JAS
JAS
JAS's Avatar
Radio "compartment"
Here is the Futaba 9151 rudder servo, 148 DP Rx, TP 730 Rx battery and 6V Duralite regulator. The servo is mounted into the air exit tunnel and everything else is double sticky taped down.
Aug 03, 2004, 05:25 PM
JAS
JAS
JAS's Avatar
Front motor mount
Here is the front mount (Ric Fix mount) for the C-50 14XL 6.7. It is 1/8" carbon plate machined out with 4 rubber grommets.
Aug 03, 2004, 05:32 PM
JAS
JAS
JAS's Avatar
Rear motor mount
Here is the rear mount for the C-50. It is 1/8" aircraft plywood cut into a triangular shape (1/8" lite-ply doubler on backside of triangle on hole for motor). 4-40 screws hold it to the modified stock firewall.
Aug 03, 2004, 05:35 PM
JAS
JAS
JAS's Avatar
Air dams
Here are the pics of the air dams (3/32" balsa) in the chin on the right and the canopy on the left.
Aug 03, 2004, 05:45 PM
JAS
JAS
JAS's Avatar
Assembled and info
Here it is assembled...don't mind the guy.
Airplane: Composite-ARF Impact
Radio: Futaba 9ZAP
Servos: Futaba: Ail: 9151, Elv: 9650, Rud:9151
RX: Futaba 148 DP
Motor: Hacker C-50 14XL 6.7:1 Acro
Controller: Master-90-Acro
Prop: APC-E 22x12
Batteries: Thunder Power 10S3P 6000 mAh ($325 a half-pack, $650 for the 10S3P)
Duralite 6V reg with 730 2-cell
Kirby's Kustom (last minute) Graphics
Wt: 11lbs RTF
I would like to thank:
-Composite-ARF for listening to my suggestions on the mods
-Sean Plummer for the installation of the motor
-Scott Anderson for building and painting the plane
-Rix Fix for machining the motor mount
-Scott Todd for help on installing the radio gear (and hole in the top of the wing...LOL
-The Hacker Brushless/Aero-Model crew for understanding the time off of work
-Dave Stodart for calling for me and keeping me relaxed and focused
-My Dad was coming to see my first Pattern Nats win
-Kirby Kustom Graphics for the last minute stickers (ordered them on Monday before the Nats)
and of course, all of my sponsors:
Futaba
Thunder Power
Hobbico/Great Planes
Du-Bro
Kirby's Kustom Graphics
Vel-Tye
APC Props
Duralite
Tru-Turn
Composite-ARF (Rep too)
Shulman Aviation
OS Engines
ES Composites
Hyde Mounts
RC Showcase
Graph Tech RC
J'Tec
BVM
Jason
Aug 03, 2004, 08:23 PM
kmashima's Avatar
Jason
thanks for the post. How did you manage to get the screws in the wing servo?
-- Kyle
Aug 03, 2004, 10:29 PM
Bill Mixon's Avatar
Jason,
What is the deal with the spacer between the front mounting plate and the gearbox? (post # 10) I'm seeing this on more and more setups but haven't figured out what it's for.
Composite ARF P-51? EagleFlyer Fuel Warbirds 4 Jan 03, 2008 07:42 PM
Gift certificate for 50% off Composite-ARF 2.3m Extra 330L Jinker Aircraft - Fuel - Airplanes (FS/W) 3 Dec 23, 2004 03:13 PM
Discussion Composite-Arf Revolution Pro E-Conversion JAS Sport Planes 29 Aug 06, 2004 10:46 AM
nib kangke f3d-30 composite arf lurchrace43 Aircraft - Fuel - Airplanes (FS/W) 3 Feb 27, 2004 09:31 AM
