Feb 01, 2016, 10:33 AM
New Product
New BitEye FPV Low Latency Board Camera with 1080p Video Recorder
This is the new version 2 of the BitEye camera that came out in May 2016.
Comes with spare lens, USB cable, Voltage detect cable and Audio/Video wiring harness.
Files can now be downloaded straight from the camera to your PC.
New lens is now adjustable and replaceable plus an extra lens is provided in case the original gets damaged.
BitEye FPV V2 Low Latency Board Camera with 1080p Video Recorder (10 min 20 sec)
The is the original package which has been replaced by version 2 above.
New BitEye FPV Low Latency Board Camera with 1080p Video Recorder (8 min 23 sec)
How to upgrade firmware:
BitEye FPV Camera - How to Upgrade Firmware (8 min 19 sec)
How to make USB and Voltage Detect cables:
BitEye FPV Camera - How to Make USB Cable and Voltage Detect Cable (11 min 29 sec)
DIY USB Cable Wiring Diagram
Name: 2-4 My Modified Drawing.jpg
Description:
Feb 01, 2016, 10:35 AM
BitEye Low Latency FPV Camera, with Built-in 1080P Video Recorder,
2-in-1 Board Camera for Racing Mini-Quadcopters or small planes. Comes with spare lens, USB cable, Voltage detect cable and Audio/Video wiring harness.
*Records 1080P 30FPS full HD video to SD card while simultaneously outputting real-time CVBS video to your video transmitter. Anti-shake option available at 720p resolution.
*Less than 60 ms latency, top performance among HD cameras.
*Fast response to ambient light changes. Get clear video all the time when your drone moves quickly from a bright environment to a dark environment, or vice versa.
*Video record protection: Never lose the video recording when the battery gets disconnected due to a crash or other reason.
*Lens focus can be adjusted. Lens can be removed, changed or upgraded.
*Weight 19 g (0.68 oz), size 1.25*1.25.1.38 inches.
*Excellent video image quality, TI chipset provides robust cutting edge performance.
Amazon sale page:
http://www.amazon.com/dp/B018IJLTEU
Company website:
http://www.biteye.cn/
Firmware Download
https://drive.google.com/folderview?...&usp=drive_web
Manual:
User Manual for Biteye FP...
Configuration Guide:
User Configuration Guide ...
Feb 01, 2016, 10:37 AM
Specification
Chipset: TI
camera Size: 1.26*1.26*1.37 inch
vibration absorber size: 2.35*1.30*0.67 inch
overall Weight: 0.88 Ounce
FOV: 155 degree
focal length: 1 meter
video resolution: 1080P (1920*1080)
Video format: FLV (This is a FLASH format that may need converting for some movie editors.)
Support micro SD card up to 32G
Feature
Easy to use, power on and it will start to recording.
Vibration absorber makes the video more stable, assembled with screws, can be removed if you don't need it
Video protection, unexpected power-off will not damage video files when have already been recorded.
Wide input voltage range from 5V to 15V (up to a 3s LiPo).
Package
Camera + Vibration absorber 1 PCS
Video port cable 1PCS
User manual 1 PCS
Cable tie 3PCS
M2 *4 screw 3PCS
M2*4 + 3 copper column 4PCS
Feb 01, 2016, 11:20 PM
Biteye FPVCamera's Avatar
Nice review, it covers all critical aspect.
Feb 02, 2016, 12:05 PM
Ron_RC
Does anyone know what the light sensitivity for this camera is? Or has anyone done a low light check with it?
Feb 02, 2016, 04:02 PM
alexgorbatchev's Avatar
Thank you so much for taking time to do this! Could you please post recording samples and FPV flight footage?
Feb 04, 2016, 06:26 AM
You can see clear video in low light environment, and the camera adapt to light change quickly, you can check another review from this link: https://www.rcgroups.com/forums/show....php?t=2591161
The reviewer go from outdoor to indoor, then under his son's bunk bed, he said "I had full, clear video the whole time".
Feb 04, 2016, 01:57 PM
lucafedechen's Avatar
Any data about UHF noise??
Feb 04, 2016, 10:53 PM
It's just launched around 2 weeks ago, other customers will post flight footage soon, and there will be more and more video from more customer
Feb 11, 2016, 04:50 AM
Any HDMI output, to feed a Rasp based HD transmitter ?
Feb 12, 2016, 02:39 AM
With less than 60ms latency analog video output. our camera has the fastest response on the market resulting in quicker reaction time, making for faster and safer flying.
You say 60ms analog latency is the best we could get?
Haha you must be kidding. All the normal pcb cams (without recording) have much less latency. The TBS ZeroZero has less than 1ms from lense to screen (at least thats what they say). And thats the latency normal PCB cams always have.
Even 60ms for HD video out wouldnt be that new as the GoPro can do that already. But wait, no HD out on your cam???
Feb 12, 2016, 03:07 AM
That's overstated and untrue Rangarid, granted 60ms isn't particularly fast but...
One of the best cameras around for low latency has always been the PZ0420/CC1333 Sony Superhad II CCD at 30ms, the 800tvl Effio-V CCD camera as an example is around 75ms
CMOS board cams are often worse than CCD, inparticular HD cams such as the GoPro/Mobius etc, so for an HD cam 60ms isn't bad though very fast FPV mini quad racers might find it a bit too much
Feb 12, 2016, 03:28 AM
I agree that if compared to the mobius or other HD recording cams it is faster, but it is not compared to analog cams. That is what i wanted to say, as they say their analog output is the fastest. And that is just not true.
Feb 12, 2016, 09:37 PM
_Milo_'s Avatar
Other customers huh?
I ordered one several days ago on Amazon, and today i got notice that my order was cancelled, no stock!
Great
Feb 19, 2016, 01:32 AM
It's fastest among HD camera.
If anything we said wrong, welcome to correct us, we don't mean to talk big.
We did compare test with those camera we know, it's possible we made mistake.
