Jan 31, 2016, 09:05 AM
AJ_Aircraft's Avatar
AJ Aircraft 60" AJ Laser 230z
Official thread for the 60" AJ Laser 230z.
Purchase here.
Build manual coming soon.
The 411:
Wing Span - 60"
Wing Area- 740 Sq. In.
Length - 57" (Without spinner)
AOW - 5 - 6 lbs.
Power - Hacker A50-14XS, 90amp ESC (5s 3700-4400mah)/(6s 3000-4000mah) 1400-1600 watts
Radio - 5 channel with 4 high torque mini servos
What's in the box:
Carbon reinforced landing gear mount
Complete hardware package
Wing bags
Pre-hinged control surfaces
Carbon main gear
G-10 control horns
Dual ball links with turnbuckles
Carbon wing tube
Optional SFGs included
Genuine Oracover covering in 2 color scheme choices including the new Patriot scheme.
AJ flies this airframe with the following equipment:
Hacker A50-14XS
Xoar 15x8 or 16x8 prop
Castle Talon 90 ESC
5s 3700-4400mah or 6s 3000-4000mah
4 Hitec 7245 or MKS 737
Also needed to complete:
2x 6" extensions for the ailerons
1x 12" extension for the ESC
1x 18" extensions to the elevator
2-1/4" or 57mm spinner
Jan 31, 2016, 09:06 AM
Reserved
Jan 31, 2016, 10:05 AM
I like the violent stuff!
I saw it last weekend at a charity event. I love my 56". And bigger is better! Thanks again for a wonderful line up of aircraft!
Jan 31, 2016, 12:27 PM
Altitude is my friend...
Depronicus's Avatar
Why a new thread with exactly the same name? What was wrong with this one?
https://www.rcgroups.com/forums/show....php?t=2576997
Feb 01, 2016, 12:42 PM
Aj Aircraft
Scottyb313's Avatar
Depron
Were looking into it I think it was just an oversight. we will see if we can delete one.
Discussion AJ Aircraft 60" AJ Laser 230z Scottyb313 3D Flying 305 Dec 27, 2019 07:41 PM
