This thread is privately moderated by blckmn, who may elect to delete unwanted replies.
Jan 30, 2016, 02:42 AM
Did you see that....
blckmn's Avatar
New Product
BlueJayF4 - STM32F4 based FC
SHIPPING NOW:
BlueJayF4 is shipping now at the following retailers:
http://boltrc.com
The rev4 is released, and includes only minor cosmetic changes from the rev3, but does move to using the ICM-20602 gyro (soft mounting still recommended).
RETAILERS PLEASE NOTE:
The BlueJayF4 is now available from BattRC in wholesale quantities. Please place your orders directly with them. They are also present on Alibaba. These are not clones, and are legitimate.
Please PM me if you want to have your shop added here, and on the https://bluejayrc.com site.
SPECIFICATIONS:
The BlueJayF4 is a cheerful STM32F405 based Flight Controller.
Why a new controller? There was no simple F4 based board out there at the time to replace my F1s. This is the FC designed for those wanting F4 performance but maintaining the F1/3 simplicity - i.e. it comes with non of the extra trimmings - it's bare bones - it's acro you might say .
Keeping it as simple as the basic F1/3 boards to just get out and fly was the intention.
Features / Specification
  • Runs Betaflight & iNAV (note there is currently no support in Raceflight)
  • 3s-6s Lipo battery input - using a piggy backed POLOLU (500ma or 1a)
  • Buzzer output
  • Voltage Sensor (off battery input)
  • Has outputs for up to 6 ESCs
  • Serial or PPM input (does not support individual PWM channel input)
  • MicroSD Card support for BlackBox
  • Three available hardware UART ports
  • Built in inverter for SBUS input (UART6)
  • Tactile button for booting to STM boot loader
  • Standard pin headers for the majority of connections
  • SWD via JST (on the base of the board - connector not fitted)
  • i2c available via through hole micro pin header
  • AD via through hole micro pin header for sensor e.g. current
  • STM32F405 32-bit processor at 168MHz, 1Mb flash, 192kb ram
  • ICM-20602 MPU connected via SPI (Rev1 and 2 used 9250, and rev 3 used ICM-20608-G all still connected via SPI)
  • MS5611 Barometer (optional extra on bottom of board - can be fitted by oneself)
  • Micro USB connectivity using STM Virtual Communications Port
  • 36mm x 36mm (standard 30.5mm square mounting holes - to centre of hole)
Wiring Diagram:
Description:
Description:
Description: Name: 4e11abfa-cf38-11e6-9fb7-0153eaf0ff61.jpg
Description:
Mini:
Description:
Pololu Attached:
Description:
Last edited by blckmn; Feb 01, 2017 at 05:56 PM. Reason: updated retail information
Jan 30, 2016, 06:34 AM
Chargerdude70's Avatar
Woot..woot
First to post....congrats to you..feel free to move lower if you need to reserved a couple post for further development.
Price point?
Says Baro optional? Added cost, DYI or made to order?
Jan 30, 2016, 06:47 AM
blckmn's Avatar
If you are having boot issues on Rev2, please remove the pull up resistor on the NRST line (as per image). This may solve your issue.
Description:
Only try this if you have a fine tip soldering iron (and a fine hand) or tweezers and hot air rework station.
Depending on the power supply (your BEC, batteries or such) the voltage rail is coming up slower than the reset timing (the cap charging) and the MCU comes out of reset too early.
This pull up will not be present in Rev3.
Jan 30, 2016, 06:49 AM
blckmn's Avatar
Swd output:
Description:
The pads represent (from top to bottom):
- 3v3,
- SW CLK
- GND
- SWD IO
- NRST
Essentially pin for pin for the ST-Link pins on STM32Fx discovery boards.
Jan 30, 2016, 10:19 AM
Woohoo!
RS2K's Avatar
"designed to run Raceflight. "
Very cool.
I don't think the baro is going to be used by very many people. You could always make an acro and full version if there's a demand for it.
Jan 31, 2016, 05:14 AM
formerly QuadsDestroyer
Count me in for the version without baro...
Feb 02, 2016, 07:23 AM
subbed and interested in a board too... non baro.
Feb 02, 2016, 07:32 AM
Originally Posted by gizmatron
subbed and interested in a board too... Non baro.
+1.....
Feb 04, 2016, 06:57 AM
-FPV it's a hell of a drug-
rotceh_dnih's Avatar
Wow homegrown aswell xD yes please !
Feb 05, 2016, 05:39 AM
which way is up?
PilotAir's Avatar
Interested in one with the baro.
Feb 07, 2016, 10:31 PM
JulianGoesPro's Avatar
Uh... I am part of the first page :-P
MicroSD Card support for BlackBox (FAT file system experimental in Raceflight
With the openLog module or how?
Feb 07, 2016, 10:35 PM
Quadaholic
--Oz--'s Avatar
Sub'ed!!! I am interested too, no baro for me.
Feb 07, 2016, 10:44 PM
It's good to be geek!
MrSatoV's Avatar
Acro for me too! Define "enough interest to warrant a high volume order"?
Check your PM! ;-)
Feb 07, 2016, 10:47 PM
MrSatoV's Avatar
Also, is it safe to assume this is a one sided board?
Feb 07, 2016, 10:55 PM
SystemsGuy's Avatar
Interesting board - if you can get it stateside sub $50, it could be a viable contender in what's getting to be a rather crowded playing field...
Latest blog entry: FrSky Long Range!
