Jul 18, 2019, 11:44 PM
Both boats are 36", and both are called Zelos. So, what makes the new Miss Gieco better than the older boat? Electronics, larger motors, better out drives, better drive shafts, etc...
Jul 26, 2019, 10:17 AM
Hey Guys,
Just bought the Zelo's twin and have a bunch of questions. I bought it spur of the moment when OSE mentioned the $399 sale on FB. I was headed off for a two week vacation at a lake house we rent and thought a new boat would be fun. I'm very familiar with RC, mostly planes and heli's but do have boats, just don't get the chance to use them much. I got the Zelos and assumed it was RTR, I'd get around to re-greasing shafts, motor alignment, strut tuning etc. after I tried it out......big mistake.
About three minutes into the first run it started making a horrible noise, I started to idle it back to the dock and noticed it was sinking. I took off the hatch and was greeted by a large amount of smoke and water. The port side lower motor mount that supports the copper tube had completely melted. The copper tube was then able to spin around breaking the seal with the hull and knocking the water hose off of the intake fitting. The copper tube and lower motor mount aren't available parts and are only sold as part of a replacement hull so essentially the boat was done. I called HH and of course they said to send it back and they'd repair, replace, refund...whatever. Normally that would be fine but I was on vacation and wanted a boat. If they fixed or replaced it I wouldn't be able to use it until next year. And if I got a refund I wouldn't be able to replace it with another $399 equivalent.
I quickly located another Zelos still on sale and ordered it. While waiting for my favorite UPS man to show up I reviewed the forums and discovered that this appears to be a common problem. When the new boat arrived the first thing I did was lubed the shafts and aligned the motors the best I could with the tools I had with me. I was only able to run the boat twice before vacation was over but it was still awesome. Nothing melted but something is still off. The stbd shaft gets hot, the ports shaft gets very hot. When I got it home I pulled the shafts again and fully aligned the motors. I also had to trim the inserts flush with the copper tubes in order to have enough clearance to remove the collets from the motors. I aligned the motors so that the shaft enters the collets perfectly centered but noticed that once it's inserted further you can feel the edge of the collet dragging across the wires. To me this indicated that the angle of the motor isn't perfectly aligned...problem is the angle isn't really adjustable. I got them as good as I could with the available adjustments. I'll likely replace the cables before running it again anyway. Considering I'm just a basher and looking for reliability over setting any speed records what would you guys suggest I upgrade or do to make this drive system trouble free? The stock speed was fine so I'll probably just sharpen, balance and polish the stock props.
I also wanted to ask about cooling. I'm aware of the 30 mph rule on the Zelos. The problem is where I run the boat is usually a little rough and hitting top speed is unlikely. The majority of my running will probably be 20-40 mph with occasional 50 + mph bursts. I'd thought about running a pump on boats in the past and now I'm thinking about it again for the Zelos. I'm curious why I never see it discussed or anybody doing it. I like the idea that I can slow down or sit for a minute while I wait for the water to calm and the motor and ESC's will cool right down with water being pumped through them......is this a bad idea for some reason?
Lastly is batteries and CG. I ran what I had for batteries that were close. I had a pair of 6S 3000's and a pair of 3S 5500's. Seemed to run fine with both. I don't have the boat in front of me to look at but if you run (4) 3S packs how do you strap down the front pair that far fwd? And I don't see any mention of CG. With planes we are provided a CG range. Why doesn't the same apply to boats? I understand that it will vary some depending on your strut angle and what characteristics you're looking for but shouldn't a basic range be accurate for most users? For example set your CG 100-110 mm from the transom with a strut angle of 4mm and tune to your liking / conditions from there? Again not that familiar with boats it just seems like randomly putting in your packs and tuning CG and strut angle from feel could be a long and subjective process. Especially for those not as experienced as others.
Thanks for any tips or suggestions you guys can share
Jul 29, 2019, 10:49 AM
Panhead5496's Avatar
Not sure where everyone is! I have only gotten one run in myself, so I'll try and help you out.
Joke in RC is RTR = Ready to Rebuild...always grease the shafts first thing, as I'm sure you know now
Sounds like it got too hot and melted it, probably due to little to no grease.
That is interesting about your alignment, mine seemed to be spot on. After a few runs I did not have any heat issues around the flexshafts. I believe OSE sells upgraded flexshafts, but not sure that's necessary for a stock boat.
I also run in somewhat choppy water, so full speed all the time isn't an option for me. I tried to go slow and go by my dock, and at slower speeds I saw water coming out both cooling lines, so not sure about the 30mph thing. A pump wouldn't hurt anything, but might be overkill.
I have no idea about CG on this one, nor about how to get the batteries all the way forward. ProBoat recommends running (4) 3s packs, which would be on the whole tray so I guess then CG is the same all the time.
Hope this helps! Sorry I don't know more.
Jul 29, 2019, 10:50 AM
Here is my maiden run!
ProBoat Zelos 36" Maiden on 4s and 6s (6 min 54 sec)
Aug 02, 2019, 07:44 PM
eroeder's Avatar
Tuning run on 4x 3S 6000 MAH and an octura prop and 4mm strut angle. Got to 74mph, so I still have some tuning to do. I wonder if two smaller MAH 6S batts would be lighter and faster. Hmmm.
Mid filming, there is a spectacular blow back and fish bobber maneuver which it fortunately lated right side up.
Zelos36 2 (1 min 57 sec)
