This thread is privately moderated by drunnells2, who may elect to delete unwanted replies.
Jan 21, 2016, 03:24 PM
Trader Rating: 138
$100.00 USD
Seller Pays Shipping
For Sale
Lot of Parts - crankcases - crankshafts - miscellaneous
Used parts for various engines. All show some wear, but nothing is broken except the two items that I mention below. Some of the parts do not carry any identifying marks. I have included the scales to help viewers identify some of the parts. Here is what I can identify:
OS Max 61 crankcase.
Super Tigre 61 crankcase.
OS Max 46 crankcase.
OS Max 45 crankcase with ringed piston.
Unidentified engine with broken exhaust port (looks like a 60).
Two 45 mm backplates.
One 33 mm backplate with gasket.
Two two-stroke heads for 21 mm cylinder (for either 45 or 46).
One two-stroke head for 24 mm cylinder.
One four-stroke head (springs are o.k.).
YS rocker cover.
One cylinder liner (23 or 24 mm ID).
Two pushrod tubes.
One small piston (32 or 33 mm diameter) with con rod.
Three exhaust tubes.
Crankshaft engraved with "45".
Crankshaft engraved wtih "1876".
Crankshaft engraved with "SF".
New bearing in box -- Precision Consolidated SKF 626-2.
One rear-mounted carburetor with gasket and with a broken plastic throttle lever, with a back plate that fits the carburetor (I think it is a YS).
One front housing with 35 mm outside diameter of the cylinder that goes into the engine and a 21 mm socket for the front bearing.
Two new-in-the-box NGK ME-8 spark plugs.
Four prop drivers.
$100 delivered in U.S.
