Jan 19, 2016, 10:11 AM
aero330's Avatar
Ki-43II
Hy guys,
I just finished my new homemade rc combat plane and I would like to share it with you!!
The warbird is the famous Japanese Ki-43 II used by the Imperial Japanese Army Air Force in WWII and I have decided to reproduce it because of its simplicity of construction.
Description:
Here are the 3 views:
Description:
Before the realization I like to create the 3D model with a software to verify the joints:
Description:
Description:
Description:
First of all I cut wings and the "shells" of the fuselage and then I assembled them on the drawing to ensure the right accommodation:
Description:
With the tape, temporarily, I attach the parts together and this is the result (rudder and elevator made of coroplast):
Description:
Description:
Now, a new way to reinforce the wings (instead of the two carbon rods):
Description:
Description:
Description:
Description:
Description:
Description:
Description:
In the end I cover wings and fuselage with wrapping paper:
Description:
and I paint with the airbrush:
Description:
Description:
Description:
Description:
I have to fix the wings with rubber bands, and create the canopy to definitively complete the airplane.
Andrea
Jan 19, 2016, 12:38 PM
WOW, that is so cool!
Jan 19, 2016, 04:20 PM
aero330's Avatar
Thanks YankeeSamurai
Jan 20, 2016, 01:41 PM
aero330's Avatar
Little update
I glued two carbon rods in proximity of leading edge and trailing edge to attach the rubber bands. A foam rubber strip will prevents damages due to air collisions:
Description:
I made three little holes in elevator, the midlle one for the screw and the others for the rudder:
Description:
Description:
I prepared the rudder with two carbon rods and hot glue so it will fit in the others two holes of the elevator:
Description:
Description:
Description:
And this is the result:
Description:
Description:
Jan 20, 2016, 06:30 PM
What are you using for power?
Jan 20, 2016, 06:48 PM
aero330's Avatar
I will use this electrical set up (like almost in all my rc combat planes):
Motor: turnigy D2830 -1000kv
Propeller: APC 8x6
Servos: 3x 9g (one for elevator and two for the wings)
ESC: 20-30A
Battery: 3s 1300mah
At full throttle, I usually fly for 5 minutes otherwise 7-8 minutes
Mar 22, 2016, 04:32 PM
aero330's Avatar
Update
I just finished two planes with different colors !!
Mar 22, 2016, 05:35 PM
Nice birds, I just love Oscar's!!!
Mar 26, 2016, 04:11 AM
aero330's Avatar
Thank you!
Mar 26, 2016, 11:00 AM
How do you cut the fuselage? Do you have some kind of template? Do you have a Feather Cut system. Can you post pic's of the process?
Mar 26, 2016, 04:12 PM
aero330's Avatar
As soon as possible I will show you the process. I use a little bow with hot wire to cut wings/fuselage.
Mar 26, 2016, 09:54 PM
Can't wait!
Mar 30, 2016, 10:59 AM
Great stuff, thanks for posting!!!
Mar 30, 2016, 12:01 PM
aero330's Avatar
Not at all !!
