May 07, 2017, 04:15 PM
Originally Posted by Quisil
The maximum range is about 1400 meters, I didnŽt try some more because of the battery. Maybe I will do the double battery mod to check the distance again.
Thanks Michael
Are you able to see the quad that far away?
May 07, 2017, 07:13 PM
re
No, it went out of sight at about 350 meters. IŽve chosen a path where nothing could be harmed, we have a lot open fields here. A friend of mine was waiting at 1000 meters. The 501C shows telemetry information on the transmitter, so I just had to stick on that course.
My friend phoned me that the quad passed near him, so I hit RTH at 9 mins flighttime.
At RTH the quad was facing backwards.
@bob_a_builder the transmitter of the 501S version can read out the firmware version.
Cheers
May 08, 2017, 01:42 AM
Think my one flys backwards when RTH is activated.
Do you have headless mode on the new one?
My previous one flew backwards in RTH too
No sign of headless mode ( in either one I've had)
May 08, 2017, 04:36 PM
I updated the firmware on my 501S to FC 1.1.36, RX 1.2.20 and TX 1.1.9. Today was the first time the quad was facing in the forward direction when rth, and now the circling mode is enabled. I wish there will be an update for the 501C as well, because the firmware is awesome and stable. I mailed Hubsan support if the 501C can run the 1.1.36 firmware as well. IŽkeep you updated on this.
The transmitter H907A lacks the headless mode. I can activate it using the 501S controller.
May 09, 2017, 01:20 PM
Circling mode? Is that orbit mode?
May 10, 2017, 05:33 AM
WI, USA
Yes.
May 11, 2017, 09:18 AM
Problem recording
Hello, I am new in the forum, wish you all the best! I have a H501C. When it records after some minutes the recording stops without my approval. When I look into the microsd card, two .mov files are produced, one playable .mov file and a smaller .mov file that is not playable.
What is wrong? Can you help me?
May 11, 2017, 09:29 AM
WI, USA
What is the brand name of the SD card are you using? And what class is it rated at?
May 13, 2017, 05:08 AM
Repair corrupted video
Hi Guys, found this on the web for the H501, how to repair corrupted video.
Hubsan H501 - Recovering corrupt (unfinalised) videos. (9 min 39 sec)
Not personally tested yet.
May 17, 2017, 05:01 PM
Atleast Class 10 and minium 8GB. I have MIXZA TOHAOLL 8GB 1U Micro SD Memory Card.
Any experiense H501C with gimbal? I just ordered 163g 2axis Brushless Gimbal 28,04€ (Free Shipping)
I think that flytime will be about 10min, but let see...
May 19, 2017, 07:20 PM
I use a 4gb Sandisk, don't think it's a class 10 either. Works well
May 20, 2017, 09:00 AM
I have a question, is the 501c the same as the 501s other than GPS? The reason I'm asking is would it be possible to flash the Russian hacked firmware to the 501c so that you would not have to calibrate the compass every time. I'm not interested in orbit mode or follow me modes.
May 20, 2017, 11:10 AM
The camera is the same without the transmitter module for FPV that the 501s has.
May 20, 2017, 11:49 AM
Yes they share many parts. But I don't know if the fc board is the same and if it could be flashed with the 501s firmware that only requires compass calibration once unless you fly from a different location.
May 22, 2017, 06:55 AM
Send a PM to Annegottagun to confirm. She is the Hubsan rep on these boards.
