This thread is privately moderated by burkefj, who may elect to delete unwanted replies.
Jan 16, 2016, 04:40 PM
burkefj's Avatar
Estes Interceptor E converted to RC Rocket glider 3 different ways
I was on the way home yesterday and was thinking about changing my IntR/Ceptor profile model into an elevon only model, instead of one with full flying tail surfaces. This would require moving the wing back and making it larger. I remembered that the hobby shop had an Interceptor E kit that had been sitting on the shelf for a long time. I did some quick checking and thought I could do a modification of this to keep the tube and nose cone and see if I could get it to fly ok. I did some quick wing planform checks and came out with something I thought would work.
I dumped the wingtip pods since they are heavy and will re-make those from foam. I enlarged the existing wing/tail slots to fit my depron surfaces and installed the wing. I made the forward tube section removable along with the strakes so that I can access the mid mounted rail button. It turned out for CG I did need to use the plastic tail piece. 7-8 ounces/sq foot, slightly more than my full profile version. The need for the tail cone for CG means the motor is inset about 3/4"
First flight was really good, slightly nose heavy, and a bit touchy on roll. I adjusted the cg rearward by adding 1/4 ounce to the tail and toning down the aileron. I later replaced the 1/4 ounce of tail weight with the plastic vertical stab antennae which weighed the same overall. I added some panel lines, accented the nose cone panels with a sharpie pen and added some trim vinyl. All up 12.5 ounces rtf now.
Here are videos of all three versions plus my kit profile version.
Four Variations of Interceptor RC Rocket gliders (5 min 15 sec)
Jan 24, 2016, 11:48 AM
burkefj's Avatar
I decided to get two of the Cosmic Interceptor kits from estes which use the same cone, since they were on closeout for $17 and do two other versions, one with a cranked delta wing and t tail and one with a full flying tail and see how they compared in looks and flight....all three fly quite well...
Frank
Mar 12, 2016, 07:26 PM
Rock-n-Aileron Roll!
Saxguy1000's Avatar
Loved watching the videos. Appeared that the V-tail seemed to fly better? Is that what you found? Were you using R/C or was that free glide?
Mar 12, 2016, 09:49 PM
burkefj's Avatar
They all flew about the same, all were rc, first two gave a longer glide due to slightly lighter weight.
