This thread is privately moderated by hadawayj, who may elect to delete unwanted replies.
Jan 16, 2016, 08:24 AM
Trader Rating: 216
hadawayj's Avatar
$80.00 USD
Will not ship
For Sale
E-flite® UMX™ AS3Xtra $80.00 NIB - Local Pickup Only Local Pickup Only Unless Buyer
Local Pickup Only Unless Buyer Pays Shipping (about $40.00)
Please NO offers, Price Is Firm
Clip From You Tube - UMX AS3Xtra BNF Basic by E flite YouTube 720p (2 min 57 sec)
https://www.youtube.com/watch?t=41&v=YCZRrJSa9ro
The E-flite® UMX™ AS3Xtra™ 3D aircraft takes Ultra Micro eXtreme to the next level. Constructed of laser-cut flat foam with carbon reinforcement and micro-thin film, this aircraft was specifically engineered to optimize a super-low wing loading, strength and durability plus AS3X® technology to provide outstanding 3D performance in tight flight spaces. Based on the ground breaking original UMX Extra 300 3D, the addition of AS3X technology makes it possible to be even more successful whether it’s performing the simplest loop or the latest extreme 3D moves. Even more appealing is that now AS3X technology offers flight mode flexibility so you can choose the level of stability performance you need instantly.
The UMX AS3Xtra is the perfect high-performance indoor ultra micro aircraft for the intermediate to advanced pilot. All you need to fly right away is your favorite DSM2®/DSMX® transmitter with dual rate options, a 25C or 45C 1S 3.7V 150mAh Li-Po battery and a 1S Li-Po charger.
Product Specifications
Wingspan: 16.8 in (426mm)
Overall Length: 19.8 in (503mm)
Wing Area: 74 sq. in. (472 sq. cm.)
Flying Weight: 1.25 oz (36.5 g)
Motor Size: 8.5mm x 23mm brushed
Radio: 4+ channel DSM2/DSMX transmitter (required)
Servos: (2) 2.3-Gram Performance Linear Long Throw servos (installed)
CG (center of gravity): 3.2 in (81mm) forward from the trailing edge of the aileron at the fuselage
Prop Size: 130mm x 70mm
Recommended Battery: 3.7V 1S 150mAh LiPo battery (required)
Approx. Flying Duration: 4-5 minutes
Minimum Age Recommendation: 14 years
Experience Level: Intermediate
Recommended Environment: Indoor
Is Assembly Required: No
Picture of Actual airplane being sold NIB.
SEE my other classified ads for:
FT012 Racing Boat - NEW IN BOX - #145.00
"SIX" Tarot 4006 620KV Brushless Motor TL68P02 $180.00
"FOUR" ZTW Black Widow 4108-390kv - $275.00
If you have questions PLEASE ask via PM. ..........
