Jan 12, 2016, 02:51 AM
SeByDocKy's Avatar
New Product
Eachine VR-007 & VR-007 Pro 5.8G 40CH HD FPV Goggles
Hi,
BG announced a cheap version of the Headplay...
http://www.banggood.com/Eachine-VR-007-5_8G-40CH-HD-FPV-Goggles-Video-Glasses-4_3-Inch-With-7_4V-800mAh-Battery-p-960761.html
Description:
Brand: Eachine
Dimension(mm): 148x176x102
Screen size: 4.3 inch
Screen resolution: 480x272
Working temperature: -20℃-80℃
Ultra-lightweight design: 256g(battery not included)
Battery weight: 24g
Power voltage: 800mah 7.4V standard configuration(2S smart lipo battery, with power display function, supports USB 5V charging)
Antenna: 5.8G 3dB
Power dissipation: 500mA
Frequency channel: built-in 40CH 5.8GHz A/V automatic search receiver
Language choice: multilinguals can be choosed in osd menu(English, French, Italian and so on).
Features:
Small size, light weight.
Designed according to ergonomic.
Settled three-point fillet can reduce the pressure of long-time wear to the head.
High softness, ventilate and environmental sponge fit the contours of the face, more comfortable, less ambient light.
Customized eyeglass, myopia below 400 needn't to wear glasses.
Built-in 40CH 5.8GHz A/V automatic search receiver.
Two groups of standard 800mAH 7.4V (2S) Lipo battery, with power display function, supports USB 5V charging, long life.
Package included:
1 x Eachine VR-007 video glasses
2 x 7.4V 800mAh Battery
1 x manual
The resolution is pretty low 480x272. In another hand it's very cheap
EACHINE VR-007 Pro
The Eachine VR-007 pro is now introduced: http://www.banggood.com/Eachine-VR-007-Pro-VR007-5_8G-40CH-HD-FPV-Goggles-4_3-Inch-Video-Headset-With-3_7V-1600mAh-Battery-p-1134154.html
Upgrades concerns the sensitivility of the builtin receivern now it's - 95dBm builtin model. The battery is also upgraded for a 1600mAh (twice more larger) and some OSD informations about the current Vfreq & Vbat are also added.
Description:
Brand: Eachine
Item Name : VR007 Pro
Dimension(mm): 151x177x103
Weight : 217g(battery not included)
Battery Weight: 24g
Specification :
Screen Size: 4.3 inch
Screen Resolution: 480x272
Frequency Channel: built-in 40CH 5.8GHz A/V automatic search receiver
Antenna: 5.8G 3dB, RP-SMA
Power Supply : 3.7V-4.2V
Battery : 1600mah 3.7V (1S smart lipo battery, with power display function, supports USB 5V charging)
Current Consumption: 350-450mA
Language Choice: multilinguals can be choosed in osd menu(English, French, Italian and so on).
Band and Channel selection
GROUP CH CH 1 CH 2 CH 3 CH 4 CH 5 CH 6 CH 7 CH 8
A 5865 MHZ 5845 MHZ 5825 MHZ 5805 MHZ 5785 MHZ 5765 MHZ 5745 MHZ 5725 MHZ
B 5733 MHZ 5752 MHZ 5771 MHZ 5790 MHZ 5809 MHZ 5828 MHZ 5847 MHZ 5866 MHZ
E 5705 MHZ 5685 MHZ 5665 MHZ 5645 MHZ 5885 MHZ 5905 MHZ 5925 MHZ 5945 MHZ
F 5740 MHZ 5760 MHZ 5780 MHZ 5800 MHZ 5820 MHZ 5840 MHZ 5860 MHZ 5880 MHZ
R 5658 MHZ 5695 MHZ 5732 MHZ 5769 MHZ 5806 MHZ 5843 MHZ 5880 MHZ 5917 MHZ
Features:
Upgraded receiver, with Power Indicator and Frequency Display.
Standard 1600mAH 3.7V (1S) Lipo battery, with power display function, supports USB 5V charging, long life.
Package Included:
1 x Eachine VR-007 Pro Goggles
1 x 3.7V 1600mAh Battery
1 x RP-SMA Antenna
1 x USB Charging Cable
2 x Alcohol Cloth
1 x Manual
Jan 12, 2016, 04:50 AM
TS Banggood RC's Avatar
Don't worry about the resolution .Many Resolution are false.We will make a video compare it with the best Goggles:Fatshark.
Jan 12, 2016, 09:47 AM
Your link doesn't work. This does:
http://www.banggood.com/Eachine-VR-0...-p-960761.html
$70. Might be nice for backup or ride alongs.
Jan 12, 2016, 03:34 PM
Wau, this looks interresting! I like the more finished look, compaerd to the quanum DIY FPV kit. If you need reviews, I'd be happy to make one.
-Tapio
Jan 12, 2016, 07:03 PM
When will they be available for order?
Jan 12, 2016, 07:04 PM
Very nice. I would love to test these against my fatshark HD2's
Jan 12, 2016, 08:36 PM
Quadaholic
now THAT looks like a winner!
Jan 12, 2016, 08:45 PM
Resolution looks a bit low, though..
Jan 13, 2016, 09:13 AM
Estimate arrival date.
I was going to buy HK Quanum goggle until I see this, please give me estimate arrival date so I can decide to wait for it or not.
Jan 13, 2016, 09:53 AM
It will be in stock at the end of this month
Jan 13, 2016, 11:55 AM
If its not 640x480 or 800x480 these are going to be horrible.
Jan 13, 2016, 01:01 PM
Is the antenna removable?
Only issue I can see (if the ress is incorrect) is that your limited to 5.8, looks like no way of plugging in a 2.4/1.2 system
Jan 13, 2016, 10:21 PM
Most of the resolution is false,We give you the truth resolution .just be patient ,We will make a video to compare it with others
Jan 14, 2016, 07:58 AM
Eachine VR-007 HD Goggles Screen resolution: 480x272
Name: Eachine VR007 1.jpg
Description:
Other Famous Brand Goggles Screen resolution: 600*480
Name: Other Famous brand .jpg
Description:
Name: Eachine VR007 2.jpg
Description:
Name: Other famous brand 2 .JPG
Description:
Jan 14, 2016, 10:59 AM
Attachment 8602236
Attachment 8602237
Attachment 8602238
Attachment 8602239
Seems pretty good to me.
