Sep 18, 2019, 10:17 AM
Originally Posted by rok_hunter
No, my takeoffs are usually 0 Flap.
If you do end up moving to a larger motor, Rocket_33 is a fan of the 1.25 and I've since moved to a VVRC 20cc gas, which is also outstanding.
Sent from my Pixel 2 XL using Tapatalk
I use the first flap position if I want little to zero take off roll
Sep 19, 2019, 11:23 PM
roversgonemad's Avatar
I’m running an RCGF 20cc and at 4700’ msl, it’s about right. I started with the 15cc evo engine, and it was definitely scale in power. I’m spinning a XOAR 16x8 wood prop and it’s much more enjoyable to fly. I haven’t even completely broken in the 20, but it’s definitely the way to go. On a cold day, at sea level, the 15cc might be good, but at higher altitude in the summer, it was bad.
Sep 26, 2019, 09:08 AM
Pr bushwheels struts size
Can anyone tell me the length between holes of the pr bushwheels struts?
Sep 26, 2019, 09:32 PM
Presume at static (neither compressed or extended)
Sep 27, 2019, 12:11 AM
I mean the length when it is out of the plane uninstalled
Sep 27, 2019, 07:27 AM
The length of the struts when static between holes, uninstalled
Sep 27, 2019, 08:36 AM
Ok sorry can't give you the length uninstalled as they are installed and have been for years. I can give you static with plane on the ground but sorry not taking plane apart
Sep 27, 2019, 08:45 AM
they are the same length as the stock rubberband struts when the bands are installed.
Sep 27, 2019, 01:00 PM
Can you give me that measurement with the plane on the ground?
Sep 27, 2019, 01:20 PM
AMA District VII AVP
PropsnWings's Avatar
I will look for mine as they are still NIB and measure later.
And no, they are not for sale.
Sep 27, 2019, 01:37 PM
Stock ones aren't rubber band, they are springs that are too stiff
Sep 27, 2019, 02:02 PM
So it'll be the length under spring tension.
Sent from my Pixel 2 using Tapatalk
Sep 28, 2019, 11:15 PM
Can anyone give me the measurement?
Sep 28, 2019, 11:26 PM
Sorry, we recently moved. I am trying to locate the box of PR stuff I had for it.
Sep 29, 2019, 01:56 AM
Ok thanks I would need the length between holes, the length between the ends and the diameter of the strut rod.
Thank you very much.
