Jun 23, 2019, 08:40 PM
Wingnutz
Bill Quantock's Avatar
Seawind’s a survivor...
Lost radio contact with my Seawind flying it from the pontoon boat this morning. Predictably, it crashed, doing a slow roll and dove in from about 40’ altitude. One wing hit first, the canopy flew off but floated. Model filled with water so that esc and battery were completely submerged. We fished it out with the “hooker” (my friend’s pvc pipe invention for fishing models out of the lake from the boat deck which is about 30” off the water). I would guess the model weighed 5-6 pounds with the fuselage completely full of water...the hooker bent to an alarming angle, trying to lift the model, but it held. Rx light was still on and solid!
Back to shore to begin the crash investigation and model assessment and then some huge surprises. One wingtip was hanging on the light leads, the wing had pulled away from the fuse, nose wheel was partly extended, but it still looked like an airplane!
The battery tested normal on all three cells! Left the fuse upside down to drain for 1/2 h and then turned it right side up to let the sun have a go.
Okay, battery’s fine, ...tx on, plug in battery, rx lights up, servos centre...and the motor ran! Hot damn...didn’t figure on being that lucky! Even the nav light and strobe on the torn off wingtip lit up! Only reason I can think of for the esc surviving submersion was being previously dunked in Corrosion X.
Here’s my theory about radio failure.
Rx used two diversity antennae and I stupidly oriented both longitudinally in the fuse. Signal loss occurred when the model was flying directly away from me...and the antennae were both pointing directly at the tx...but the model survived and will be back in the water and the air on the next calm day!...with a revised antennae configuration...
Watched a full size Seawind take off from a local airport last week...that makes two Seawind survivors!
Jul 09, 2019, 11:52 PM
Hello to all.
I just traded for a used Seawind. Everything seems to work just fine. It has been patched at the top of the canopy, where it attaches with the center "arm"to pivot when raised.
I plan on flying with an eflight 3s,2200 battery.
Any suggestions on setups,rates,expo,ect? Im using a Spektrum rx,no stabilization.
Thanks in advance.
Jul 10, 2019, 01:00 AM
I fly mine with 3000mah 3s. Works fine. Lipo goes in very tight I fly with a Horus and use the ways from the Manual. Works fine. But I use a rudder aileron mix. Because If you fly curves it looks like the ass falls from the heaven so give 10% rudder with aileron.
Gesendet von meinem VOG-L29 mit Tapatalk
Jul 10, 2019, 12:40 PM
Fire Marshall Bill
I will 2nd that. 2700 to 3k 3S battery. Also flying with Horus 12 and a S8R Rx. Beautiful plane in the air or on the water. Mixes or thumbs to keep the tail tracking when banked. I do not think it took much of a flap/ele mix tho. I did see one crash when the cockpit opened in flight. Becomes a giant scoop of a brake, and just would not stay airborne. Some tape or add a magnet or 2 more to the hatch. A bit of a complex plane to setup, but if already done, should be fine. PITA to replace the stock maingear servo, but these tend to go bad right out of the box, so yours is probably already done. I put red racing stripes on the hull to enhance visibility from below. Enjoy.
Jul 10, 2019, 08:06 PM
Okey Dokey.
2200mah,3s. My maiden. 7minutes,landing with 3.70 per cell. Battery cool. Esc also cool.
Needed lots of up trim. After i got her trimmed out, what a beautiful sight at 8:45pm. Strobes flashing,Nav lights visable.
Landin was great. Throttle to idle,glided like s gliger. I had to give her down elevator just to get the nose down. Belly landed into a field.
I may have just found my favorite "go-to "to fly in the empty field next door.
Jul 11, 2019, 05:46 PM
Fire Marshall Bill
Yep!
Jul 15, 2019, 11:42 AM
Build, crash, repeat...
lee292a's Avatar
Originally Posted by Mike14B25
Hello to all.
Thanks in advance.
From the manual:
Aileron - Low - 5/8" High 15/16"
Elevator - Low 3/8", High 1/2"
Rudder - Low 7/8", High 1 1/2"
Flaps - 3/8" for half, 11/16" for full
I fly mine on a Turnigy 2200 mah 3S 30C and get decent flight times, although I find the plane just a little sluggish getting off the water. I recommend half flaps. You can loop and roll it, but don't try anything extreme. I strongly suggest running tape around the canopy, as water can enter the plane around it. A little water will enter the plane because of the retractable nose gear, and they provide a plastic squeeze bottle to suck it out with the kit. I put a couple of strips of red packing tape on the bottom of each wing to make it a bit more visible in flight. It does tend to bounce a bit on water landings. I've found it likes the water better than flying off the ground. The gear is a little weak and the wheels are small, especially if you fly from a grass field. The most fun thing about the plane is taxiing down a boat ramp into the water, retracting the gear, and after the flight doing the same thing in reverse!
One more thing - I removed the servo slower from the plane, choosing to control the landing gear up/down speed with my transmitter, a Spektrum DX8 Gen 2. It's a little hard to get the gear to go down and lock, so you may have to twiddle with it.
