Jan 04, 2016, 09:30 PM
New Product
Vgoodrc ARM 32-bit ESC
32-bit ARM Cortex MCU @ 48Mhz
1 Special designed for multi drones.
2 STM32F051 48MHZ ARM 32-bit micro-processor.
3 Exact speed control, accurate signal acquisition.
4 Rapid response of gas changes, very fine linear.
5 Adaptive timing to compatible with much more motors.
6 Automaticly detect if it is the ordinary remote control signal(PWM) 50-500Hz or One-Shot125 Signal.
7 Having synchronous rectification technology( Active freewheeling enabled)to increase the working efficiency of ESC.
8 Anti blocking protection. When motor or propeller is blocked by something, ESC will stop the rotating of motor immediately to avoid the damage of motor. The motor will autamatically begin to rotate when detect there is no blocking.
9 Regenerative braking, active brake.
10 Output PWM frequency is 24KHz.
11 Throttle resolution is about 1480 steps.
12 No external electrolytic capacitor required
13Max. RPM: 450,000rolls(2 poles), 150,000rolls(6 poles)
Jan 06, 2016, 06:16 AM
Jan 06, 2016, 07:03 AM
Just another FPV addicted teen
EpicRC's Avatar
Does it run Blheli or own firmware? Gate drivers?
Jan 06, 2016, 10:02 PM
vgoodrones's Avatar
Own firmware. Using hardware driven PWM output to the gate driver.
Jan 08, 2016, 09:05 PM
Master Prop Breaker
Are these the same ones that are being sold at RTFQ's? Who designed / is manufacturing them. These ESC's are definitely being introduced at a time when the market is saturated with new ESC's. The more the merrier, I guess, its getting hard to keep up!
Having a common object next to the pics would be nice for a sense of scale.
You might want to edit your info to clarify that these come in a 18A version and a 30A version. It wasn't clear to me until almost the third time I reviewed the specs.
Jan 09, 2016, 02:00 AM
EpicRC's Avatar
Where are these available for purchase?
Jan 10, 2016, 09:39 PM
vgoodrones's Avatar
Hi, you can contact the sales person- Jane who is in V-good company. Her email is [email protected]
Jan 13, 2016, 10:14 PM
hardware PWM
Jan 14, 2016, 01:34 AM
EpicRC's Avatar
How do you change motor direction?
Jan 14, 2016, 02:07 AM
vgoodrones's Avatar
Hi! You can change any 2 of the 3 motor cables to reverse the motor direction.
Jan 15, 2016, 03:28 PM
maybe you can describe how to utilize the 1480 speed steps.
what is the timing to drive these esc's?
Jan 17, 2016, 12:55 PM
Firmware Fiend
The Quasar's Avatar
How do you change any of the settings/parameters on these ESCs? Is it the old annoying "listen to the beeps until you go nuts and smash everything with a hammer" method?
Jan 18, 2016, 03:02 AM
vgoodrones's Avatar
Right now we can't change the settings and parameters by programming.
We are going to release a programming card to program the settings and parameters before the end of this month.
Jan 18, 2016, 03:08 AM
vgoodrones's Avatar
Thanks for your great advice. We will think about it.
The ESC has auto timing.
Jan 18, 2016, 09:05 AM
What is the price for this 18A and 30A.
