Jan 05, 2016, 08:54 AM
Thanks for the pointer, Riverhill! I didn't realize that RMRC now had its own BLHeli 4-in-1 ESC. I'm a lot more comfortable trying that than the Chinese and RTFQ versions that seem to lack QC. Not cheap at $34, but I'll be ordering one for sure.
"A perfect solution for the new craze that is sub 250g multirotors!"
Mine should be at my house when I get home today.. I'll let you know what I think of it...
Jan 05, 2016, 09:19 AM
McSkies's Avatar
There is only one thing that you need to watch for when installing and that is the standoff or spacer that you use to stack with. Make sure its not hitting one of the small resistors or you may have to trim an edge off the standoff. I have it in the listing, but this item could not be moved in the schematic.
Jan 05, 2016, 10:17 AM
I did see that in the listing and will make sure to pay attention not to cause damage. Thanks for the extra warning!
Jan 05, 2016, 12:13 PM
McSkies's Avatar
The 122 is now live!
http://www.readymaderc.com/store/ind...oducts_id=5033
Jan 05, 2016, 12:21 PM
AMA 1051390
Says no stock. I can't believe it sold out in 10 minutes lol
Jan 05, 2016, 12:43 PM
McSkies's Avatar
Haha, stock will be added soon. Sorry about that!
Jan 05, 2016, 08:58 PM
Certifiable
Gregs04.5's Avatar
Ordered, now I have another project! good thing it's cold out, have time to build.
Jan 05, 2016, 09:45 PM
fly a LiPo a day...
Brainstorm's Avatar
McCleary: Can you please confirm which version of the 1306 3300KV motors comes with standard, CW-threaded nuts? Based on the images and color of the cone nuts, I suspect that the CW model is for CW-rotating props, but actually comes with CCW prop thread.
Latest blog entry: In lieu of a blog post
Jan 06, 2016, 05:58 AM
McSkies's Avatar
I'm not at the office of to confirm right now. Sitting in charlotte terminal waiting for the flight to Vegas for a race. I'll see if one of the guys at the shop can confirm for you.
Jan 06, 2016, 09:53 AM
fly a LiPo a day...
Brainstorm's Avatar
Thanks! Maybe you can ask the crew back in OH to clarify the item description, too, once they've confirmed threading direction.
Good luck with the race! Bet Vegas is going to be a zoo with CES this week. That said, the race was probably scheduled to coincide with CES, since it's been featuring an increasing amount of consumer drone technology.
PS: Since shipping for the 4-in-1 was less than $3, I went ahead and ordered one. Didn't want to risk the ESCs running out. Motors I'm more flexible, so would rather miss out than accidentally end up with 6x CCW-threaded motors.
Jan 07, 2016, 07:41 AM
Just checked for you: the motors that say CW have traditional threads / nuts on them - righty tighty, lefty loosey
Jan 07, 2016, 08:11 AM
fly a LiPo a day...
Brainstorm's Avatar
Thanks for checking, Zander! Good thing I didn't jump the gun and order up a half-dozen CCW-threaded motors.
Jan 07, 2016, 08:39 AM
brycej's Avatar
I just got one of these on order for a 3 inch triblade on 4s setup I'm working on. I'd been holding off using a 4in1 because I didn't really want to get one from RTFQ either.
I assume it has an atmel chip since it uses the dys20a hex to program them?
I got some 1407 RCX motors. They say about ~36k rpm at 16.8 with a 3 inch BN prop. The tri prop will probably be less rpm then that.
The motor is a 12N14P configuration. So
36000rpm*(14poles/2) = 252000 eprm.
So according to QuadMcFly with blheli, it is limited to 250k in software but start to run up against the wall earlier around 200k. The other option would be to flash simonk are you'd be good above that (312k).
It looks like some people are running the hellbender 122 with a similiar setup? Any issues?
Jan 07, 2016, 09:01 AM
no problem!
Jan 07, 2016, 09:05 AM
I'm interested in this 4-1 esc as well. Also running 1407 motors. I'm not too concerned with erpm limits as I'm hardly full throttle. I see it has blheli firmware, but my question is what bootloader does it have? I want to be able to flash it using naze running betaflight.
If this isn't possible, which flasher do I need? I have an arduino nano and an afro usb flasher. Any of those work?
For Sale Guys eagle tree vectors on sale 204.99 plus 15/percent off ..189.00 dallasftworth85 Aircraft - Electric - Multirotor (FS/W) 19 Oct 27, 2015 09:44 PM
Discussion Instructions on Grand esprit sail plane #204 MATT NASH Sailplane Talk 1 Mar 07, 2015 10:33 PM
For Sale Royal 25 size muffler #204 77-780 new! HD Hucker Aircraft - Fuel - Engines and Accessories (FS/W) 0 Oct 18, 2014 08:06 AM
Found RMRC-540 OSD and RMRC-600XV cameras (NTSC) Bonafidepirate FPV Equipment (FS/W) 0 Nov 23, 2011 11:07 AM
Discussion Hellbender Went Down Wingnut31 Foamies (Scratchbuilt) 1 Apr 22, 2007 09:10 PM
