Rant
Inexpensive home-brew winch? Is it possible? RRRr!
I've looked everywhere, and all I've seen are winch kits in the $500+ range. That's a little too steep of a price, and I think I could home brew something for far less. Does anyone know where I can get some help? what Kv motor should I use? What size motor should it be? How low ($$$) can I go? Anything would help!
BTW, is there any way I could come up with a proportional control system for the winch, rather than pulsing a solenoid? Couldn't I use something like a sewing machine foot pedal, and run a bunch of transitors (field effect? Note I'm a novice at electronics, however I'm very good at soldering! ![]() |
Here's one for kit for $285.00 http://www.superskeg.com/ And of course you could do a homebrew if you are a good wood worker and some creative metal working skills but when it's all said and done you would have invested a lot more in terms of time and material procurement. You can launch any plane on a winch without breaking it but you have to respect the limitations of it's design... tap, tap, tap..... ![]() Good Luck |
winch plans
Check this out I asked the same question about a month and half ago
https://www.rcgroups.com/forums/showthread.php?t=232331 this should get you going on something. Soar Dude |
did you start making your own winch yet?
Hi-starts are great! It's just that they can hardly launch a 3.4 meter and up scale ship to a real hang time altitude. Unless, of course, I build a super ultra high start! Maybe I'll do that instead. Tying knots is easier.
I have a NE Sailplane XL hi-start that is rated to 4M, I believe. It sends my 80 ounce 3M Airtronics Legend up with authority. 100' rubber and 400' line. Add the slightest breeze and I am competing with the winches for launch height.
I also use it to launch Spirits and Gentle Ladies. Just don't pull back as far. with a 150 foot pull I get a 12-13 pound pull and it sends the Spirit and the GL way up there with no problem at all. Not my first choice for a 2M plane, but they seem to be able to handle the launch with no problem. over 200 launches on thse 2M planes and no broken parts. Have broken several wings on the winch, however. About 50 3M launchs between my Legend and other 3M planes and everyone loves the power of this thing. They call it the big bear hi-start. NESail XL - $110 complet set-up http://www.nesail.com/detail.php?productID=872 Aerofoam also has hi-startes rated for 4M planes - $135 complete http://www.aerofoam.com/hosemonster.html I am not trying to discourage you from building your own winch, but if budget is an issue, it is hard to beat a hi-start if you have the room. |
When I begam flying sailplanes over 30 years ago, I couldn't afford a histart so I built a winch for less than $25 for a rebuilt Ford long shaft starter motor and a Ford solonoid. (I said this was over 30 years ago). A friend welded up a 2 inch winch drum from a 4 inch long section of 2 inch diameter heavy wall aluminum conduit tubing and some 0.092 aluminum from an old street sign. Frame was welded up from some flat iron salvaged from a scrap pile. A friend built a winch drum around a section of 2 inch diameter kitchen rolling pin and a section of aluminum street sign. Nobody does this any more but back then we couldn't buy winch parts so we rolled our own. Price of reebuilt starter motors has gone up a lot but you can build a winch for about $100 if you are a good scrounger and can do the hard work yourself.
Also, maybe the same australian boy, mentioned he made a High start from bicycle blades (the inner tube, don't know its name) cutting them in spiral and joining them with a knot. I'd like to see a picture o this too. Maybe the luck is with us... Ricardo. |
Thread Tools | |
Similar Threads | |||||
Electric Mod to a Home-Brew HLG | Balsa Hound | Electric Sailplanes | 3 | Aug 25, 2002 10:52 PM | |
400 Size CCPM Home Brew Copter | Foxtrot | Electric Heli Talk | 6 | Jan 22, 2002 06:08 PM | |
Home brew Hotliner. | Redster | Electric Sailplanes | 3 | Dec 24, 2001 09:23 AM | |
Home brew bee | K Ho | Electric Plane Talk | 0 | May 03, 2001 08:17 AM |
