Dec 23, 2015, 06:40 AM
Car Bashing
Jym73's Avatar
New Product
Basher RockSta 1/24 4WS Mini Rock Crawler RTR & KIT
BSR 1/24 Mini Rock Crawler RockSta - HobbyKing Product Video (1 min 36 sec)
Description: Name: 90518s(6).jpg
Description: Name: 90518s1(6).jpg
Description:
Description: Name: 90518s3(6).jpg
Description: Name: 90518s4(6).jpg
Description:
Description: Name: 90518s6(6).jpg
Description: Name: 90518s7.jpg
Description:
Originally Posted by Hobbyking
Basher RockSta 1/24 4WS Mini Rock Crawler is all the crawler you need if you want to tackle the wild expanses of your living room or the backyard rockery and it will attack these challenges with all the specialist abilities of a 1/10 or 1/8 crawler, just on a much smaller scale. This crawler is perfect for those days when the weather won't let you outside or your crawling space is limited, because you can set up a cool obstacle course with a few household objects that will keep you challenged for hours.
The RockSta can handle tough mini trails because it's packed with features like a low centre of gravity, four wheel steering with steering mixing, motor on axle both front and rear, fixed diffs and solid axle suspension just like the big boys.
Truly unique to the RockSta is the ability to change steering modes on the fly using the radio included in the box. It has four steering modes that can all be changed from the radio by simply pressing a button:
• Front wheels only
• Rear wheels only
• Front and rear wheels in opposing directions
• Front and rear wheels in the same direction (crabbing)
With these great features and its tough construction the RockSta Mini Rock Crawler is the best value crawler in its class and will make the competition green with envy.
Basher RockSta 1/24 4WS Mini Rock Crawler KIT
Description: Name: 90525s.jpg
Description: Name: 90525s1.jpg
Description:
Description: Name: 90525s4.jpg
Description: Name: 90525s5.jpg
Description:
The RockSta can handle tough mini trails because it's packed with features like a low centre of gravity, four wheel steering, motor on axle both front and rear, fixed diffs and solid axle suspension just like the big boys.
This kit version of the RockSta is for those among us who love to tinker and make their own versions with their choice of electronics. This will require a fair amount of RC knowledge and skill but we know there are plenty of hobbyists out there with the right stuff who will use this chassis to make some truly inspiring rigs. You may need to modify the chassis to accept different ESCs and receivers, but the results will be worth it. This little chassis makes for a great crawler but maybe you want more power, more speed, lower COG, lower weight, two wheel steering (both steering arms can be locked with a screw) or you could go the whole hog and convert this little beast into a micro rock racer. It's up to you.
RTR
Features:
• RTR with KIT version avaliable soon
• 4 wheel steering with 4 steering modes that can be switched while driving
• Motor on axle improve grip on both the front and rear tires
• LCG chassis design for handling steep inclines
• 2 in 1 ESC and receiver
• Uses 2S 7.4V Lipo batteries
Specs:
Height: 95mm
Width: 130mm
Length: 187mm
Wheelbase: 136mm
Weight: 250g (chassis only)
Battery compartment: 50 x 30 x 15mm (Max)
RTR Requied:
4 x AA size battery for transmitter
350mah 2S 7.4V Lipo battery
KIT
Features:
• Designed for 4 wheel steering
• Dual Motor on axle
• Water resistant battery tray
• This is a challenge kit
KIT Requied:
130 size motor
9g servo
ESC
Radio system
Tools
*Note: The kit version is for experinced hobbyists, some chassis modification will be needed to fit different ESCs and receivers. This is NOT a beginners kit.
RTR Intl WH
KIT Intl WH
Dec 31, 2015, 09:37 AM
Car Bashing
Jym73's Avatar
Kit version available now. See link on bottom of above post.
Dec 31, 2015, 05:04 PM
how does it compare to this guy
http://www.banggood.com/HB-118-2_4G-...p-1001667.html
Dec 31, 2015, 06:21 PM
Brake Weight's Avatar
It looks better than the HB one. Performance wise, I don't know.
The kit version isn't as good a deal for only a $17usd price difference unless you have the parts laying around your workbench. 1-2 servos, 2-3 channel Tx/Rx, ESC, and two motors will cost more a lot more than the difference in price.
But a pair of small heli/quad motors would be fun.
Dec 31, 2015, 11:34 PM
head designer at TEAM-D DESIGN
dogoman's Avatar
I'm considering getting the kit version and putting in a nice metal gear servo for the front. Then just add a small brushed esc, and two Tamiya plasma dash motors ($10 each) and that would make a great indoor and outdoor FPV setup. But i would wait till there's some reviews out, and see if its any good.
Jan 01, 2016, 07:25 AM
Car Bashing
Jym73's Avatar
+1, Main differences 1/18 and 1/24, HB is bigger but 4 wheels steering instead of 2 for the HB. Basher RockSta is smaller but seems a better rock crawler.
Yes, for 17$ more it worth the price.
Jan 01, 2016, 07:59 PM
Keep Looking Up
BWX232's Avatar
BASHER Rocksta 1:24th Scale Mini Rock Crawler first look -FPV (9 min 57 sec)
Will do more vids- running vids and some FPV DVR footage vids.
Jan 01, 2016, 10:06 PM
dogoman's Avatar
Originally Posted by BWX_
https://www.youtube.com/watch?v=cCd2Fb7vsaI
So how do like it?
Jan 03, 2016, 07:58 AM
Keep Looking Up
BWX232's Avatar
Originally Posted by dogoman
So how do like it?
I like it!
I don't want to cross post so here's a link to the post with the link to the running vid I just uploaded. Check it out.
https://www.rcgroups.com/forums/show...9&postcount=11
Jan 03, 2016, 04:03 PM
dogoman's Avatar
is that its max speed!? I like the idea of a small indoor truck but if thats its max speed well.. thats not really for me
Jan 04, 2016, 06:41 AM
It's a crawler and meant for low speed. If it went any faster it'd flip over every time you turned. You could put some lower turn motors on it and stiffen the springs up, but then you may as well buy another RC.
Jan 04, 2016, 09:18 AM
Keep Looking Up
BWX232's Avatar
Yeah it is very slow, LOL. But still fun!.
Hey I just noticed- it is in stock.
Jan 04, 2016, 11:26 AM
dogoman's Avatar
Yah I get that its a crawler, but in the video that HK put up, it looked quite a bit faster. Iv'e wanted a micro vehicle to do indoor Fpv rock racing. and this would make an excellent choice with some modifications. Such as, lower CG, higher speed Fpv. But my main concern is, is the motor adjustable to allow for different pinions?
Jan 09, 2018, 03:47 AM
Hi guys!
I've finished my very high-effort christmas project and I hope you might have some clicks for me, and maybe there are also some interesting things to find...
nearly 1,5 hours in 11 episodes about my Rocksta build + MOD project, also including a „Making of“
https://www.youtube.com/playlist?lis...-f6cZBalGXyyLT
pls just forward to others, if you think it's useful!
greets,
Jan 09, 2018, 10:15 AM
Car Bashing
Jym73's Avatar
Your link is broken.
