Mar 03, 2016, 04:39 AM
If someone made a mach3 driver, I think the Thermino would become very popular!!! Love the concept and design.
Mar 03, 2016, 05:48 AM
Doing that is a no-sense, as you lose than the best qualities of Theremino as the Theremino Cnc is freeware...
(my opinion, of course...)
Mar 11, 2016, 07:43 PM
Harpia's Avatar
Originally Posted by Søren Vedel
Wonderful tutorial, Pietro. Ande very well explained with a lot of pictures. Great job!
I wish I had seen your approach before I started out to go the Arduino way. Seems to be a lot easier. Anyway, I will continue my Arduino based cnc foam cutter, as I have got as far, as I am now.
I have a question:
Can you tell me, if I need DevWing Foam when I already have Profili Pro? I can generate G-code with Profili Pro, so does Dev Wing Foam make any advantage?
I think you can generate G Code with Profili Pro. Devwing Foam just have more features than Profili.
Edson
Mar 12, 2016, 05:47 AM
I don't know how profili works.
Devwing foam is a reality nice piece of software indeed.
Mar 15, 2016, 06:57 PM
Very nice build! I've been reading all I can about the Theremino and trying to put together a complete list of all components I will need for my build. I will be building wings for 116" wingspan Extra 300 model. 2 piece wings and stabs but will need to have wing tube holes cut.
Do you know of the DevFoam app allows for this?
I have been intimidated to build a system as I do not know any "coding" that seems required for Arduino and other systems. Theremino seems to remove that obstacle!
Thanks very much for sharing your build with such great detail!Rob
California
Mar 16, 2016, 02:33 AM
Yes DevWing foam can add holes to any panel you have in your wing.
Here an example of a wing I'm planning to cut with a circular (a tube) to make servo wires to pass trough.
Same situation if you want to cut a circular/rectangular hole to insert a spar
You can define shape and dimensions both for root and tip of your panel.
Then you decide if you want to cut it during the profile cutting (holes must be at the same percentage of chord on root/tip) or to cut in a second stage (you can remove shell and cut your hole)
Rob
California
Theremino is really simple to use. Just follow my wiring instrucions (ask if needed)
Then if you want to use ThereminoCNC you only have to add your pins and pin type in HAL and you're ready to go
With DevCNC Foam this is not needed. You enter preferences and set there your setup (motor rotation, step/mm ecc ecc.) super easy
Ciao!
Mar 17, 2016, 12:19 PM
Thanks for the reply. I'm in the early stage of creating a list of parts to build the machine. Trying to learn about linear vs. belt systems. Then order and assemble the system.
How are you connecting the actual "hot wire" to the carriage system? Are you using a spring to maintain tension for tapered cuts? I saw that Theremino has temp sensors and I'd be interested in having an automated temp control feature from the software.
What are you using as the power source for the Hotwire?
Thanks!
Rob
[QUOTE=pieri70;34272411]
Do you know of the DevFoam app allows for this?[7quote]
Ciao!
Mar 18, 2016, 05:57 AM
On the Y axis I have a V carved Aluminium support.
Look figure 2 here below under the arrow there is the wire (red spot) and the V carve.
I mave a sharp "V" with a rasp.
These two V are support for the wire, that is tighten by a light bow that must be as long as carriage Y position in the maximum extent on your sweep wing
If you use springs to tighten your wire you surely get unwanted cuts..
Yes it has temp sensor but temperature control isn't controlled by that..
You can set a pwm signal that move a potentiometer to dim your power, but I didn't use this..
A simple AC/AC power supply with a dimmer to control power output.
If you want to drive a 0.2mm wire 1m long you need at least 48V 150VA.
Mar 20, 2016, 03:52 AM
Here is a test with Chuwi Hi8 Pro windows 10 tablet
4 axis CNC Theremino and cheap 8" Win tablet (1 min 54 sec)
Mar 22, 2016, 04:17 PM
Warbirds Lover
Dreamcatcher's Avatar
great cnc machine !
thank you for sharing :-)
Mar 22, 2016, 04:56 PM
Hope you enjoy!
Apr 04, 2016, 10:09 PM
Awesome job!
10 Euro for the board?? Already purchased mine!
Do you believe the theremino free CNC softwares will be continously updated?
I have a RAMP 1.4 arduino shield board, I should be able to hook it up to theremino without problems, right?
As far as softwares go, do I really need Profili, or DevWing to cut wing or is it possible to draw my wing in any cad (I'm very good at SolidWorks) and generate the Gcode? I really don't want to spend the money...my cnc is already at USD140 without the frame (I already have the bearings and rails though) and I set a budget of USD200 maximum for this project.
Thanks!
Apr 05, 2016, 03:13 AM
Originally Posted by rasciodc
Awesome job!
Thanks!
Actually Theremino Cnc is updated on a regular basis, for the future I don't know as I'm not in the Theremino development team.
Creating GCode of a wing using SolidWork is possible, but requires some special skills if the wing is tapered, still more if you want to apply spars, holes, LE or TE. I suggest devWing Foam, my application
Apr 05, 2016, 06:32 AM
Hello
I can confirm what Durone said
I can suggest you to use a CNC Shield V3 that is proven to work on this setup.
You can find it starting at 4$ on ebay
I have no experience with Ramps 1.4 but I know it works only at 12V maximum.. and I don't know which are the exact pins to connect..
Bye
Apr 21, 2016, 11:41 PM
William_Sidney's Avatar
CNC Upgrades
Great Post!
Ordered a Master DIL to build the CNC adapter for my HobbyCNC board.
http://www.theremino.com/hardware/adapters#cnc
Will look at using DevCNC and DevWing Foam to replace jedicut.
