Dec 16, 2015, 04:25 PM
Car Bashing
Jym73's Avatar
Mini-Review
Wltoys - 1/24 A212 SAVAGE off-road buggy - Review
I get this WLtoys A212 from Gearbest.
Unboxing :
WLtoys - A212 1/24 Desert Buggy SAVAGE - Unboxing (Courtesy Gearbest) (7 min 1 sec)
Manual :
WLtoys A212 manual
Specifications from manual :
- Type : 1/24 Electric 4WD big foot.
- Product size : lenght 190mm, width 130mm, height 85mm.
- Wheelbase : 120mm.
- Minimum distance of front and rear wheel : 75mm.
- Ground clearance : 14mm.
- Transmission ratio : 1:5.97
- Tire diameter : 45mm, wheel's width :27mm
- ESC receiver server : Three in one circuit
- Motor : 180 brushed motor
- Remote control : 2.4GHz
- Remote control distance : greater or equal to 100 meters
- Remote control batteries : 4 AA/LR6 (not included)
- Battery : lithium 7.4v 500mah, strong energy strong explosive (lol, 20C)
- Charger : lipo balance (500mah)
- Charging time : 1 hour
- Use time : 15 minutes or so (and not 40min. like said on gearbest website)
- Servo : 5g with servo saver and steering sensitive
- Car shell : antiknock (^^) PVC printing car shell beautiful Crashworthiness
- Four wheel independent suspension system, sealed box (false, see photo below). Shape simulation, suitable for wide range of people.
Scale comparison :
Name: scale comparison.jpg
Description:
From left to right : 1/8, 1/10 (with big wheels), 1/16, A212 1/24, 1/58.
Transmitter comparison :
Name: Radio comparison.jpg
Description:
Small car, big transmitter.
Gears :
Differential :
In the video we can see that i had a little bit difficulty with front diff. . So i have inspected it :
Description:
These planetaries are so small but seems enough for this scale. I have added 1 big drop of thick silicone oil in both diff. . Now front diff. works fine.
For the fun, diff. comparison :
Name: diff comparison.jpg
Description:
A212, 1/10, 1/8.
Center drive shaft :
Name: steel center CVD.jpg
Description:
Steel.
Gearing housing :
Name: Gearing housing.jpg
Description:
Open, so dust and sand can go inside, must take care.
Plastic :
Front bumper, shock tower and body mount are quite soft, all the others are quite hard.
Plastic CVD :
Name: CVD Knuckle.jpg
Description:
There is ball bearing everywhere, except on steering but for this scale it is ok.
Front and rear knuckle are same. Front and rear a-arm are same.
Wheel's axle and wheel's screw :
Name: wheel axle screw.jpg
Description:
Steering :
At low speed (if you want to use it inside your home) it doesn't turn too much. Servo's arm has two adjustment holes, i have changed for the second, doesn't change too much :
Description:
Outside it isn't the same, as you can go faster the car drift a little or can turn on his back quickly, so steering is just enough.
A little bit disassembled :
Description:
First use :
Car works quite nice. Go fast for his size (i don't believe the 40km/h wrote on the box) and is quite nervous. Go straight, Good maneuverability.
Video :
WLtoys - A212 1/24 Savage - Tarmac, Gravel, Jumps Bashing (6 min 27 sec)
This car is strong!
Speed test :
WLtoys - A212 1/24 Savage - Stock Speed test (1 min 55 sec)
11 march 2016
First conclusion :
Quite suprised. This car is well built, well assembled, well designed. It look like quite same as bigger scale. The size is small but not too much. Tx/Rx seems smooth enough to use it as a crawler, with these big and large tyres it help also.
Pros :
- Strong.
- Stable.
- Fast.
- Well built.
- RTR.
Cons :
- Body clips fall with big crash ^^.
Motor modification :
I done a test with 2440 motor. It can be fitted. There are differents distance size for screws and 1 of them works. Only need to enlarge hole to pass M2.5 screws in holes.
Motor shaft diameter is 2.3mm so it is a little bit tricky to put the original motor pinion as it is for 2mm but with a hammer and patience it works also.
Name: WLtoys A212 2440 motor motor mount and pinion.jpg
Description: Name: WLtoys A212 2440 motor side.jpg
Description:
Name: WLtoys A212 2440 motor above.jpg
Description: Name: WLtoys A212 2440 motor without upper deck.jpg
Description:
As i thought, there is not lot of space between motor and center drive shaft but it will be ok imo.
Obviously 2440 motor is too long, but a 2430 will fit perfectly.
Brushless attempt :
With a 2430 7200kv motor :
• WLtoys - A212 1/24WD - Brushless attempt • (3 min 34 sec)
Shock absorber upgrade :
We talk about this shock absorber further in this thread, i finally bought them : HSP 1/24 Fuel Hydraulic Shock Absorber
Name: WLtoys A212 YDT oil shock absorber.jpg
Description:
I sanded bottom part of stock damper that it can fit part who hold spring on the new shock :
Name: WLtoys A212 bottom shock modification.jpg
Description:
I have kept bottom ball screw and used a simple screw on top, result :
Before :
Name: WLtoys A212 A232 wheels comparison before.jpg
Description:
After :
Name: WLtoys A212 A232 wheels comparison after.jpg
Description:
These shock absorbers are very nice and way better than stock fricton shock absorber. They are very small but built like for a more big scale.
As you can see i have also bought A222 wheels.
A222 wheels modification :
Here the rims and their tires :
Name: WLtoys A212 A232 wheels bag.jpg
Description:
Wheels comparison :
Name: WLtoys A212 A232 wheels comparison.jpg
Description:
With body shell :
Name: WLtoys A212 A232 wheels.jpg
Description:
Need a little more modification to do my second brushless test.
More to come, stay tuned
Dec 17, 2015, 01:09 AM
ultra cheap pilot
ican3d's Avatar
Sharing Part 1 review video of unboxing WLtoys A212.
Video:
WLtoys A212 - Part 1 Unboxing of 1/24 scale 4WD truck (15 min 50 sec)
Dec 17, 2015, 07:11 AM
ultra cheap pilot
ican3d's Avatar
Here my test drive review, looks fun:
Video:
WLtoys A212 - Part 2 Quick test drive of 1/24 scale 4WD truck (2 min 14 sec)
Dec 17, 2015, 07:51 AM
Car Bashing
Jym73's Avatar
On mine i don't feel the need to do a break-in. After have rebuilt front diff. and have added silicone oil it works fine. I have directly use it at full throttle before added oil, only rebuilt. It is really easy to do maintenance on this car. Unfortunately weather is too bad here to do a good video outside for the moment.
Dec 17, 2015, 09:55 AM
Low budget fun
Beaver_XT's Avatar
Looks really fast, maybe too fast for indoor use. But I'm gonna get one for indoor bashing anyway. :P
Dec 17, 2015, 10:13 AM
Car Bashing
Jym73's Avatar
Depend of the size of your house ^^. But yes, it is quite fast for indoor. But you're not in the obligation to always put full throttle. I have chased a little bit my cats with it indoor , but they are too afraid ^^. I already made it fall in stair, nothing broken.
Dec 17, 2015, 10:24 AM
its a very nice toy.
but the smaller P929 is also to fast for indoor bashing.
if you do full trottle.
Dec 17, 2015, 10:48 AM
Cool , I bet my cat loves it, he likes the MMT also, he chases it and then he hides so nobody can see him but me
Dec 17, 2015, 11:16 AM
Low budget fun
Beaver_XT's Avatar
Great to know it's durable.
Dec 17, 2015, 11:22 AM
Car Bashing
Jym73's Avatar
. Strangely one of my cat has already attacked 1/16 in the garden, and strangely with this smaller one, he flee ^^.
Dec 17, 2015, 04:50 PM
Soon he will attack this one also
Dec 17, 2015, 10:30 PM
Video:
https://www.youtube.com/watch?v=SqLsrD-HPXM
Is it have Differential in "both" gear boxes? Seems wheels always turn the same way in video 5:50s.
I have a P929(1/28) truck with Differential & metal CVD, really nice mini car.
Dec 17, 2015, 11:26 PM
ultra cheap pilot
ican3d's Avatar
Yes, Both gear box have differential.
Dec 18, 2015, 04:16 PM
So how would this measure up for a intermediate user?
Dec 18, 2015, 05:40 PM
what size is the wheel. how many centimeter high.
