Dec 17, 2015, 11:39 AM
serial scratchbuilder
Granted's Avatar
Originally Posted by Timbo383
I like the bread clip idea, but the wood and magnets have me a little lost.??
For holding foam while glue dries.
Dec 17, 2015, 12:05 PM
Allways the hard way!
georgy's Avatar
Talking about holding foam... i got this 6-pack of glass jars from my local bits-&-bobs store.. nice parrallel sides. Filled with sand they make nice hold-em squares while waiting for glue to dry...
Dec 17, 2015, 01:02 PM
I Look, Listen, and Learn
Timbo383's Avatar
Originally Posted by gpw
for easy and superlight control surface activation , we use Pull-pull cables (string) and no need for control horns , just a short piece of a bamboo skewer does it . Works remarkably well, weighs almost nothing ... cost almost nothing too ..
Ladies and gentlemen, I present the king of cheap and free......almost half of what I've learned has been from Glen.
Dec 17, 2015, 01:06 PM
Timbo383's Avatar
Cool, thanks Granted, a picture is always worth a thousand words.
Dec 17, 2015, 07:13 PM
Andrew Radcliffe
Andrew Radcliffe's Avatar
here is a super cheap lite 3d build made with dollarstore foam and dollar store tissue
XTRA LITE EXTRA! (2 min 26 sec)
we have a build log on here on rcgroups also
Dec 25, 2015, 04:04 AM
Timbo383's Avatar
Sandwich/freezer bags filled with sand make great flexible weights....
Merry Christmas everybody!!!
Dec 25, 2015, 06:18 AM
gpw
gpw
“There’s no place like Foam”
gpw's Avatar
Save those foam food trays , you can cut them into flat sections and glue them together to make a plane ... here’s a pic if the latest Foam-EZ , canard , made from grocery store foam chicken trays ... FREE .. Colored tape (Fast-pac) makes it pretty ....
Latest blog entry: Lost plans
Dec 25, 2015, 01:28 PM
IMO ( In My Opinion ) →
balsa or carbon's Avatar
Good one !
Dec 25, 2015, 04:16 PM
Kamikaze Ace
Glacier Girl's Avatar
I save all the old vacuum formed packaging from what ever I do buy.
Just used some from a couple 3 packs of CA tubes of glue to make servo protectors.
Used em for making air scoops, covers for esc's to direct airflow and water protection.
And don't forget the plastic Dixie cups, they make great engine cowls.
Dec 25, 2015, 07:10 PM
Timbo383's Avatar
Everytime I pick up something I see in the parking lots, my wife asks me what part of the plane is that trash going be for.
Old lead wheel weights or battery cable....cg balance
Broken driveway fiberglass marker.....spar
Stiff wires......landing gear, control rods
Used zip ties....cut off the unused end,still usable
Plastic caps....because Im always losing one, and this one might fit
Metal bolt washers.....flat cg balance, cut slit and insert
And many more that I cant think of at the moment
Dec 26, 2015, 01:30 AM
Btw, you can used a hot needle to make holes in those credit card control horns
Dec 26, 2015, 07:30 AM
flypaper 2's Avatar
Here's a good tool for your electric screwdriver.
Take your worn out Dremel and cut about 1 inch off the drive end. File the hexagon flats to fit in your screwdriver. Doesn't take that long as it's mild steel and easy to file. Also the outside diameter is the right size for your driver. Screw the drill chuck on the threaded end and your good to go.
It's handy for drilling wood and plastic where you don't want or need the high speed. I use it much more than my regular drill.
Gord.
Dec 26, 2015, 09:08 AM
treefinder
springer's Avatar
Fly, great idea for the screwdriver chuck! I wonder if I could turn down and thread a long disposable screwdriver hex bit? (Might be too hard, eh?) I have two of the little screw drivers like you show; harbor freight 4.5v type. When they wouldn't hold a charge anymore, I swapped in a 1 s lipo (850mah split in half) that worked OK, but I found I could squeeze a complete 2s 850 may lipo in the handle after a little trimming. I soldered motor wires and ran the balance wire out the back for charging. Running the little motors at 8 volts hasn't damaged them, and I get several weeks of use from packs that won't fly a plane anymore.
Dec 26, 2015, 09:20 AM
Timbo383's Avatar
Wow, now that's recycling to the extreme.
Dec 26, 2015, 09:27 AM
Exurban Countryside flyer
scotty909's Avatar
One of the easiest ways to change your thrust angles on smaller electric motors is to break off the end of an Exacto knife blade . Loosen the screw and slide it behind the motor mount. So much easier than washers and you don't have to take the screw out.
I also use plastic spoons for air scoops.
