homemade ideas for cheap and/or free - Page 152 - RC Groups
May 19, 2017, 10:51 AM
Chef Pilot: Planes vs Butter
ChinoDiablo's Avatar
Impressive to say the least.
May 19, 2017, 01:43 PM
Old foam wings work great for making racks.
May 19, 2017, 01:47 PM
222 km/hr Parkjet flyer
solentlife's Avatar
Nice one ... only trouble is - I tend to find another fuselage to fit and they fly on ...
Nigel
May 19, 2017, 06:26 PM
I Look, Listen, and Learn
Timbo383's Avatar
Using foam to hold foam.....um....never thought of that.
May 19, 2017, 06:46 PM
Build straight - Fly twisty
Whiskers's Avatar
I've noticed that boa2110 can do things with foam that I would not have thought possible.
May 24, 2017, 11:58 AM
Gravity is my enemy
Balloon Bandit's Avatar
Oh no, my favorite topic has dropped to the second page! Ok, you may not think it is genius, but as Whiskers pointed out, some people are just plane creative. (pun intended) So what is a good possible use for ummm... plastic solo cups, guitar strings? Or how about the nylon material that came with the $1 store kite (where we scavenged the CF tubes from) ?
May 24, 2017, 04:57 PM
I meant to do that. Honest!
JamesPotts's Avatar
Is that a trick question or are you really trying to find uses for that stuff?
May 24, 2017, 05:28 PM
Timbo383's Avatar
Put an edf in the solo cup, use the guitar strings to hook it up to the DT kite and have a very interesting rc kite.
May 24, 2017, 06:34 PM
Rapidly aging user
raw89's Avatar
Use the nylon kite material for the skirt on a small RC hovercraft......
May 24, 2017, 06:46 PM
Just another 62 year old kid!
graywoulf's Avatar
I thought about using one of those tiny blow up pool rings that are toddler size to build a hovercraft with.
May 24, 2017, 06:50 PM
Hot glue held together by foam
balsa or carbon's Avatar
You could make a fuselage with plastic solo cups .....
RC plane with plastic cups and plates by HaddadRC.com (3 min 55 sec)
May 24, 2017, 07:01 PM
looking up, down under
scruffy1's Avatar
the nylon is to cover your semi-scale r/c ultralight
May 24, 2017, 07:16 PM
Whiskers's Avatar
Nylon cloth can be used to strengthen and toughen a structure.
For example, say we have a piece of plywood glued to the bottom of a foamy fuselage to serve as a landing gear mount. A piece of cloth glued over the ply and extending a reasonable distance over the adjacent foam adds a great amount of strength for very little added weight.
May 25, 2017, 03:22 AM
Whiskers's Avatar
Clampy Thingo
I needed to replace an ESC's Deans plug with an XT60 and I had limited access to the job.
Pliers and a rubber band held the thing nicely for soldering and it worked well and got the job done easily.
May 25, 2017, 03:43 AM
Closed Account
Neat trick, I'll probably have to use this some day
