Dec 07, 2015, 10:44 AM
t00nz843z's Avatar
Syma X9 Flycar Drone Car Drive Flight Test Review
Here's something very new and cool. It's an RC car, and it's a drone. It's both! Find it here with free shipping for $33.99 with coupon code JRSM9. When on the ground, it's a car, and includes powered two wheel drive and proportional steering. But give its propellers some throttle, and it takes to the air as a six axis stabilized drone. It can even flip. Includes cool lighting, making it a great night flier also.
Pro's
- Well designed and well built. This is no contraption like previous car/drone attempts. This one actually works, and works well.
- Very stable flier. Should be easily flown by beginners.
- Transition between car and drone is very smooth. Can easily and repeatedly swap back and forth from ground to air.
Con's
- Battery is unusual, but can also use generic 350 to 380 mah batteries from micros.
- Flips can lead to the car settling to the ground.
and here's my flight with it:
Syma X9 Flycar Drone Car Drive Flight Test Review (14 min 17 sec)
Description:
Item name: Syma X9 RC flying car
Speed switch: Fast/slow speed lever for your choice.
LED light: Suitable for flying in the dark at night.
Color: Red, black, white
Frequency: 2.4Ghz
Channel: 8-Channels
Gyro: 6 axis gyro: Strong stability, stronger wind resistance, easier to control.
Charging time: About 100mins
Flying time: About 6mins
Control distance: About 50m
Flight battery: 3.7V 600mAh li-po battery
Transmitter battery: 4 x 1.5V AA battery ( not included )
Function: Sideward flight, Forward/backward, With light, Up/down, 360 degrees spin, Turn left/right, 3D rollover, Speed up
Package Contents: 1 x RC Quadcopter, 1 x Transmitter, 1 x USB Cable, 4 x Blade, 1 x 3.7V 600mAh Li-Po Battery, 1 x Screwdriver, 1 x English User Manual
Last edited by t00nz843z; Dec 10, 2015 at 10:42 AM. Reason: added coupon code discount
Dec 07, 2015, 11:05 AM
PALE OTAK KAU!!
KCreep's Avatar
Does the speed rate button work in ground mode, and I wonder if you could use the X8C transmitter to get better range as well as modding some rubber tires to give it more grip on the road since it uses foam tires.
Dec 07, 2015, 08:15 PM
btw ,Do you have any coupon?i want to buy one
Dec 07, 2015, 08:26 PM
Found it! Can save 12 USD with it...
The Coupon for Syma X9: JRSM9
Dec 07, 2015, 08:46 PM
t00nz843z's Avatar
Just flew it in the desert today with the X8C controller. Worked very well, and it flew very far (video to follow). But the rate button doesn't seem to change anything in ground mode. It only has an effect when in the air.
Dec 07, 2015, 08:52 PM
Azrak's Avatar
Sounds good, mine should be here in a couple of days.
If you could fly it with your x8c tx then my Devo tx should work too.
Can you tell what motors are in it?
Dec 08, 2015, 02:57 AM
How is the driving experience? It's more like a car or a quad?
Dec 08, 2015, 03:27 AM
Closed Account
Amazing! When it's a flycar, they have to get the lights right! Red at rear.
Dec 08, 2015, 05:07 PM
t00nz843z's Avatar
It's better and much smoother as a quad than as a car. The steering is a little touchy, and it can easily veer off course with a little over-correction of the pitch roll stick,
Dec 08, 2015, 08:31 PM
aka RCFlyer85
Irock1985's Avatar
How's the top speed.... On land?
Dec 08, 2015, 09:27 PM
t00nz843z's Avatar
Not very fast, about the same as on the concrete walk.
Dec 08, 2015, 10:17 PM
FAA is Sofa King We Todd Did
wavekatcher's Avatar
Fun toy!
$35 to ship though?
Dec 09, 2015, 03:39 AM
wow! its a pocket rocket!
Amazing quadcar! we can say
does it uses a Ni Cd battery? or lipo?
Dec 09, 2015, 07:25 PM
Azrak's Avatar
It's a lipo.
Speaking of batteries is there a good source of spare 600 mah or above batteries that will fit?
Dec 09, 2015, 08:11 PM
Originally Posted by wavekatcher
Fun toy!
$35 to ship though?
I think it's free shipping now on Gearbest....
