Mar 05, 2016, 08:03 PM
bassplayer1's Avatar
I thought I'd give the nose gear a bit of life instead of being an aluminum tube just sticking out and I came up with this! I'm going to add also the two landing lights just for fun!
Mar 05, 2016, 08:30 PM
Up-Out-&-Gone
demondriver's Avatar
Sir, now that's what I call a strong looking nosegear!
Latest blog entry: RC 737 Max 7 Maiden flight!
Mar 06, 2016, 03:23 AM
Wayne Lester
Awesome job. How many lipo cells and capacity would be required ? what flight time would you expect with lipo change.
Mar 07, 2016, 07:01 PM
Thank you sir!
Mar 07, 2016, 07:05 PM
Thank you! Now it flies on 2x4s 5500 and that gives me well over 12 min flight time. The two motors in series only pull 40 amps
Mar 09, 2016, 04:01 AM
Wayne Lester
Thanks for the info. I currently have 70mm edf units on my 787 but considering changing to 80-90mm units for increased static thrust. Would you know what static thrust you are getting with the twin 90mm set up please?
Mar 10, 2016, 07:22 PM
My set up is 2x wemotec midi fans with HP290-20-7 motors and that gives me 1100 watts(110watts per pound). Thrust is about 26N(2600kg).But you can get a lot more than that with todays fan and motors if you wish!
Mar 11, 2016, 06:46 PM
Up-Out-&-Gone
The HET and RC Lander and Dr Mad-thrust 90mm units I've used all gerenate atleast 5lbs or 2.26 kilograms of thrust.
Any 90mm fan unit that generates anything less are no good.
Mar 12, 2016, 06:17 AM
You can get a lot more thrust from 90 mm wemotec fans.
The four fans of this A340 produce 165 N (16.5 kg) or 36 lbs.
That's more than 41 N or 9 lbs. for one fan.
AIRBUS A340-300 LUFTHANSA GIGANTIC RC AIRLINER MODEL JET LOW PASS FLIGHT / RC Airliner Airshow 2015 (6 min 5 sec)
Mar 13, 2016, 04:20 AM
airliner-rc.ru
Airliner-rc/'s Avatar
Very interesting A340. It looks like no wing dihedral (no V angles)?
Mar 13, 2016, 04:59 AM
Airliner Builder
WAGliderGuy's Avatar
Yes, the lack of wing dihedral and wing flex really takes away the from the scale look of that A340. It would handle better with dihedral too.
Mar 13, 2016, 06:39 AM
Regarding the wing dihedral the builder of this plane was indeed totally wrong. One may also remark the missing center main gear. It's a shame because otherwise this A340 looks very scale-like.
From what I know this guy has started the build of an A330. Let's hope he will get the correct dihedral now.
Mar 13, 2016, 07:01 AM
Up-Out-&-Gone
I agree 1,000,000% Kap!
This A340 is a Rauch kit if I'm not mistaken and I think the builder probably never really thought about wing dihedral and thought "if it flies that's all I care about"
I'm getting ready to build an A340 and won't make that mistake. . . . But who knows I might add the wrong toilet seats in the 1st class bathroom. Lol
Mar 13, 2016, 08:54 AM
... This A340 is a Rauch kit if I'm not mistaken ...
You're right.
Pics of this A340 can be found on http://rauch-airliner.com/A340E.htm
Mar 13, 2016, 05:49 PM
Here is a video we shot today, kindly made by a fellow modeller and I thought I'd share it with you
Airbus A310 by Koutagiar (3 min 8 sec)
