Unleash the Kraken - Page 176 - RC Groups
May 15, 2017, 04:18 AM
Originally Posted by which.wabbit
Hi Guys,
I'm building up a K3 at the moment and have been having an issue with not being able to get the M2 screws that came with my T-Motor F20 motors to fit through the mounting holes on the arms as the tolerances seem to tight on the arms.
Just wondering if anyone else has experienced this issue?
I've tried forcing one of them through, but gave up before getting it all the way through as the amount of force I was needing to apply to get it to move was getting pretty high.
Any advice would be appreciated.
Thats a strange problem. Ive run RCX and Xnova motors on mine and never had a problem getting the screws through.
May 15, 2017, 04:30 AM
Sam Richard's Avatar
same with the BH 1407
May 15, 2017, 06:02 PM
Think I might have figured out why I'm having problems with the T-Motor F20's. Seems like some of them use M2.5 bolts for mounting, still trying to confirm if that is the cases with me. Looked like M2 when I checked against a ruler, don't have any calipers unfortunately so maybe I just got that wrong.
I checked the mounting holes on the K3 against a couple of 2mm drill bits and the drill bits fitted fine.
Guess the only option I can see is to either use different motors or drill out the mounting holes to 2.5mm.
Anyway warning on anyone thinking of using the T-Motor F20's with the K3 to check if it's M2.5 or M2.
May 15, 2017, 09:38 PM
JefFPV
In order to get 5v from the pdb what polulu goes with the 5x pdb? And how is it wired in? Thanks so much.
May 18, 2017, 06:17 PM
https://s3.amazonaws.com/cdn.freshde...lication%2Fpdf
May 18, 2017, 06:52 PM
Link was broken, try https://boltrc.freshdesk.com/helpdes...nts/9014085129
Although I think the document might be a bit out of date.
May 19, 2017, 07:52 PM
JefFPV
Thanks.... But do you have a link to the actual regulator? I'm not sure which one it is and also it says on some of the polulus to not to use one of the pins but instead jump it out in order to get consistent voltage. Is that correct? Thank you so much for helping!!!!
May 20, 2017, 06:52 PM
https://core-electronics.com.au/polo..._0caArcm8P8HAQ
May 24, 2017, 11:00 AM
BlackR0ck's Avatar
I've got tons of build pics, crash pics and new rebuild pics. I gotta get them up. I built my Kraken Worx, crashed and destroyed it and just finished a rebuild. Awesome little frame. Just picked up a big set of original arms for cheap too
Here is my first build. I didn't like the soft mounted body so I'm using button head bolts on the arms cranked down solid and then I reamed out the body to pop on over them. A couple micro zip ties and it's fixed solid. I don't race so the splat on the checkered flag seemed appropriate
May 25, 2017, 03:22 PM
JefFPV
Kraken 5x for sale
Hey guys figured I'd post here first. Selling my 5x frame. With two pods. One painted red. The other not painted. Also a spare arm. $50 shipped. PayPal only. Pm me if interested. Thanks.
May 25, 2017, 08:04 PM
Hi,
would you send to Germany.
Regards
Nils
May 28, 2017, 02:02 PM
Gotta love my Krakens, somehow manged to win at the Power Of Video race in Belfast this weekend, was an awesome track but had a lot of quad destroying obstacles around the place. First time I've snapped a pod in half (yet somehow the camera survived!).
Finals were DRL style, so 3 rounds. I got 2nd, 1st, 2nd which got me the overall, here's a video of round 3:
T13 Finals Round 3, with commentary and split screen (2 min 22 sec)
May 28, 2017, 08:23 PM
ATM0's Avatar
Worx arms look soo good sanded down and prepped. Niiiceee.
FYI: I and others actually bolt the arms and plates tight then stack the pod on top. This allows fast pod removal without having the arms go limp. It also raises it for more internal room inside. Old picture of my setup attached.
May 29, 2017, 03:36 AM
miTo82's Avatar
Just raped my Kraken 5R this weekend...
Knowlege of this day: Krakens dont like aluminium poles of a soccer goal
Results of this little contact (nearly full throttle):
- Completely damaged 2mm Pod
- Destroyed Motor (Emax RS2205-S)
- All 4 steel screws of my "flight tower" (with all the electronics) were bend backwards
- Aluminium bracket / Camera holder damaged/bend
- Camera lens is still missing
- Ripped off USB-Port of my KISS FC
But all the carbon fibre has no scretch. The 5R Arms are pretty durable =)
PS: A friend of mine broke his 5 Worx arm the same day (see Kraken in the back with the white propellers)...
May 29, 2017, 11:39 AM
BlackR0ck's Avatar
That's exactly what I've done. I've just bolted the base of the frame solid and pop the pod right on top. I use button head bolts for those outer bolts which allows the pod to literally snap in place on top. So I still reamed out the holes on the pod but just larger so they fit perfectly over the button heads. Keeps it just as low as if it were under the bolts and holds it rigid in place still. There is still so much room under the pod there is no need to get it any higher. Only thing I have under the pod us a 4in1 ESC and FC. The new XM+ Rx's and Eachine VTX03's are so tiny you don't need anymore room under these things
I still have to zip tie the pod in place to keep it solid but I like the solid X-Frame a lot better with the pod just strapped on top like a normal RC body.
I've snapped a couple arms already but I ordered up another 10 of the old style because they were so cheap. I don't race mine, but stick to freestyle and proximity for personal flight enjoyment I still prefer top mounted batteries for flight characteristics but my frame setup is just barely ticking over 200 grams which is really hard to beat for performance even with a battery slung on the bottom. I can see for racing it must not matter too much since all you do is whip around and aim for gaps and smooth video is never much of a consideration anyway.
