Tweagle td. The best even better - Page 9 - RC Groups
Aug 07, 2016, 01:09 PM
Alex Hoekstra's Avatar
Originally Posted by marcwv
Anyone have the setting for the older standard Tweagle?
Or are they the same as published earlier in this thread by Reto?
http://europeantopplanes.nl/?page_id=267
Settings at the bottom of the page.
Aug 09, 2016, 02:07 PM
Alex would the original Tweagle benefit by replacing the horizontal and vertical fin from the TD version?
Aug 09, 2016, 03:47 PM
Marc,
I tested the hor.stab by cutting the original tips smaller and smaller until i went to far. Same with the vertical. So yes the original Tweagle would benefit from the Tweagle td tailplanes.
Aug 09, 2016, 09:05 PM
Transplant Chey WY from Reno
Thermaln2's Avatar
Alex,
The pegtip of my Tweagle TD is flexing. How solid underneath the recommended positioning is the CF to the spar? I see very minor flexing but want to make sure that nothing unexpected can happen.
Chris Adams
Aug 10, 2016, 06:27 AM
Chris,
Spar is running about 1/2 inch in front of the peg position. From the spar it has some unidirectional carbonfibre triangels top and bottom with layer of spread tow on top. A hard point in between. Normaly nothing should happen but if the skin flexes an injection of thin CA might help.
Aug 10, 2016, 09:27 AM
Thermaln2's Avatar
Originally Posted by Alex Hoekstra
Chris,
Thanks, I'll watch it. Not enough buckling to get CA in right now.
Chris
Aug 10, 2016, 11:50 AM
Alex..the original Tweagle will still fly best at 68mm or are you finding 74mm working better as used on the TD version ?
Regards,
Marc
Aug 10, 2016, 12:32 PM
Marc
The original Tweagle is best at 67/68mm. Even with a smaller stab i never felt to go backwards with the CG.
Alex
P.S. I fly the td now at 71 with slightly increased incidence.
Aug 10, 2016, 01:50 PM
Alex....thanks so much for all the information !
Dec 24, 2016, 02:12 PM
I apologize if this has been explained already and I have not seen it. I am curious about the meaning of the name "Tweagle". Is that something from the Dutch language? Or is it a name without any relation to anything?
Apr 25, 2017, 07:38 PM
Oleg Golovidov
olgol's Avatar
Build pics
This plane was built about a year ago. But I never posted the pics.
Here they are...
Since building it, I had to do some repairs and replaced the fuselage and used a Flitz2 vertical tail (for cosmetic reasons mostly). I may post more pics of the current state of the plane later...
Tweagle TD is a very nice pane overall. As all of the planes, it takes a little getting used to, but performs quite well.
Apr 26, 2017, 10:35 AM
One more flight...
n00ber420's Avatar
That thing is beautiful
May 27, 2017, 11:57 PM
Alex,
Is the Tweagle TD still in production? I posted an order for a fuse and a vertical, so far no response.
Gary
May 28, 2017, 03:33 AM
Originally Posted by GaryO
Alex,
Gary
Gary,
It is stil in production. I checked my emails and RC group messages but i didn't receive any mails from you since Januari 2016.
I will send you an email.
Alex
