Nov 23, 2015, 05:49 PM
Question
need power/prop recommendations
I have a reptile 500 AUW- 1.66kg . I run a 3000mah 4s 20C Zippy and currently have 9x4.7 props on it. i get about 8 minutes of flight but quad is sluggish ... 3s won't even last 4 minutes before it can't hover
I just bought some graupner c-prop 10x4 to see if i can get total jello free video and better performance .
the next step are better batteries .. .but i'll have to weight them and make sure the weight difference negates the added capacity.
does this seem like a flyable setup ? or do you have better recommendations?
thank you!
Nov 23, 2015, 09:54 PM
FPV Stig
FLDataTeK's Avatar
Those props are a bit aggressive and probably making your current draw a bit high. And those slow fly props are notorious for jello.
If your flying 4S I would suggest trying some HQProps 9x4.3 carbon composite props. They are well balanced and really efficient props and should bring you down to around 4-5 amps of draw per motor giving you a total draw of around 16-20 amps depending on flying style and wind conditions.
I run this setup on my XuGong v2 Pro quad and get around 20 minutes flight time on a 5200mah 4S with a similar AUW. So on a 3000mah I would expect you to be getting in the neighborhood of 10-12 minutes or better
Nov 23, 2015, 09:56 PM
FPV Stig
FLDataTeK's Avatar
Also just to check.. Those are SunnySky 2212 980kv motors on there isn't it? They look like it.
Nov 23, 2015, 10:00 PM
Closed Account
Actually, I get 1- 2 minutes more flight time with The hq10x3.8 than the 9443.
Also a 4s 6000 could get you 20 minutes or more
I just realized you already said a larger 4s would give more flight time, sorry.
Nov 23, 2015, 10:21 PM
no these are the 900kv's
Nov 23, 2015, 10:26 PM
FPV Stig
FLDataTeK's Avatar
Then maybe try the 10x3.8 HQProps. They should have no problems swing it on 4S.
If that doesn't solve it then I would definitely start looking at your batteries as the possible problem.
