This thread is privately moderated by addz, who may elect to delete unwanted replies.
Nov 21, 2015, 05:05 AM
no fate but what we make
addz's Avatar
combat plans
Here are the plans for the full contact combat plane I designed back in 2012.
After going through a few prototypes I ended up with this simple strong great flying little plane, it has a good balance between pitch and roll, it can fly quite slowly and remains very stable at high alfa.
5mm and 3mm coreflute
turnigy d2830/11 1000kv motor
18-20 amp speedy
hextronic mg 14 servos (any 12-15g mg servo)
3s 2200 batt
9x5 gws DD style prop
motor mount is 18x40x50 light pine
the main delta is 5mm with a 3mm dowel spar glued in the flutes
the fins and fuz sides are 3mm
and the cg is approx 25cm from the nose.
The bow tie prop slot is an attempt to reduce the noise a little, a 4-5cm straight slot is fine though.
To finish off the nose a block of epp rounded at the front and covered in fiber tape is proving to be quite durable and provides a little battery protection.
An inverted U fuz cover isn't a bad idea to protect the gear, just glue to one side and Velcro the other.
Nov 21, 2015, 05:38 AM
Happiness is a warm ESC.
Stretch1's Avatar
Hmmm
Looks a bit like my DTANC CCT. (The Tank Corflute Combat Triangle)
(Still under development. Toying with a KF step to improve the glide ratio.)
Towerpro 2409-12 outrunner
Turnigy Plush 25A ESC
APCE Copy 8 X 4 prop
2 X Hextronik HX5010 twin bearing standard servos
Spektrum AR6100E 2.4G Rx
Turnigy 2200mAh 30-40C 3S Lipo
Use the off cuts from the fins to set the fin angles.
Box tube carbon fibre to stiffen the push rods.
Nov 22, 2015, 06:24 AM
addz's Avatar
Yeah they did look similar, you can't go wrong with this planform.
Are you going for streamer or full contact?
Nov 23, 2015, 04:11 AM
Stretch1's Avatar
Whichever I can convince people to have a crack at. ( I'm happy with either.)
A lot of the members of my club are retired and not interested.
I used to fly full contact slope combat quite a bit.
I get enthusiastic every now and then, then get distracted with other rc projects.
I'm working on a new .46 powered SPAD combat plane at the moment.
It's like a SPAD GNAT but .46 powered with a simple KFM4 wing.
Too many projects, not enough time.
Help! PICA 1/12 Combat Corsair Plans captnemo34 Combat 10 Nov 14, 2018 01:08 PM
Sold Vintage double VooDoo, Combat Ace and Ambird Sportsman plans artist2 Aircraft - Fuel - Airplanes (FS/W) 1 Sep 26, 2016 07:36 AM
