Nov 19, 2015, 10:52 PM
Bind n' Crash
Question
variable pitch on a plane
How do I put variable pitch on an rc plane?
Nov 19, 2015, 11:25 PM
You need a special prop hub and prop blades which usually also requires a compatible hollow shaft motor. They are very rare and difficult to find except for some tiny, flimsy, poorly built types for smaller planes.
Apparently they aren't as efficient as the fixed pitch ones, even though they are supposed to be, because they use poor propeller blades (i.e. flat), unless you get a custom setup.
Nov 20, 2015, 12:42 AM
Greediest Suer
Ron H's Avatar
Just put a thingy on it that can change the pitch. Interesting new idea!
Nov 20, 2015, 06:43 AM
ggcrandall1's Avatar
Hobbyking lists several variable pitch prop set ups.
Glen
