GitUp Git2 - 16MP Sony CMOS, Gyro, RC, Ext. Mic, Wi-Fi, GoPro size **Owners Thread**GitUp For Action Git2 PRO The new Git2 made by the GitUp has been just released. As we were expecting from the Git1 then new Git2 also uses a top quality back-illuminated 16 Megapixel Sony CMOS sensor. The technical platform has also been revamped and it's now based on the new and powerful NTKNTK96660 Novatek chipset. The form factor has remained the same like on the Git1 and it's 100% GoPro size which yet again makes it compatible not only with a huge array of accessories like waterproof cases, frame mounts and flexible joints but also with most gimbals thus making it a worthy candidate for aerial videos. SONY Exmor 16MP Image Sensor The Git2 was built without compromises so a back illuminated 16 megapixels Sony Exmor IMX206 was chosen for this compact action camera. The sensor has seen vast implementation on digital still cameras and camcorders. The newly developed sensor package had realized a approximate reduction in volume ratio, making it about 53% smaller and thinner compared with the existing products of type 1/2.3", with a 16M pixels resolution. Also, the revised technology used enabled 33% lower power consumption at full HD 1080p output compared with the existing products on the market which translates into better battery life. Gyroscopic Stabilization The Git2 uses hardware digital image stabilization with the help of a gyroscopic (accelerometer) senor. When this feature is enabled, the working technique is based on shifts of the electronic image from frame to frame of video, enough to counteract the motion or at least minimize it's presence. This is done by using pixels outside the border of the visible frame to provide a buffer zone from which to crop the motion but this will also reduce the resolution in some cases. To have noticeably good results this systems uses the input of a accelerometer to "measure" the needed movement and thus selecting the correct regions for cropping based on the movement or shaking of the camera. In most of the cases the gyro works so well that even hand holding the camera without any kind of monopod or handle generates much more steady images and prevents annoying shake External Microphone A lot of people request this feature from an action cam, either you want to record an engine sound from under the hood, or your voice when cycling this feature is only found on expensive GoPro's. The most budget cameras only have a internal microphone that has a limited quality. The new Git2 not only has an external microphone but it also supports twin microphones or a stereo microphone for capturing really immersive sounds. Remote Control Using a mobile phone or tablet for remote functions is not always convenient. The Git1 will have an optional purchasable wrist watch size remote controller that will have the the basing start / stop recording functions. This remote control is also useful for taking selfies without using a timer and it will be easy to use you are moving. Hands-on. Unboxing Review
Pro packing and optionals - GIT2 Camera (950mA Battery included) - 30M Waterproof Case - Frame Mount - Bike Roll Bar Mount - USB Data Cable - Curved Adhesive Mount - Flat Adhesive Mount - Long Screw - Short Screw - Long Connector Pivot - Short Connector Pivot - Tripod Mount - Screw Adapter Optionals - Wrist RF Remote Control - External Microphone Full Specifications Chipset: Novatek NTK96660 Lens: High quality all glass 7 elements Angle of View: 170°,120° CMOS Sensor: Sony Exmor IMX206 16MP LCD Display: 1.5 inches LCD screen Video Resolutions: 2160P HD video (2880 x 2160 @ 24fps); 1440P (2560 x 1440 @ 30fps); 1080P (1920 x 1080) @ 60fps, 30fps; 720P (1280 x 720) @ 120fps, 60fps, 30fps; WVGA (848 x 480) @240fps, 30fps; Video Format: H.264 encoder, MP4 video container Video Loop Mode: Supported Photo Resolutions: 16MP(4608*3456), 12MP(4032*3024), 8MP (3264*2448), 5MP (2592*1944), 3MP (2048*1536) Time Lapse Photo: 2 sec. / 5 sec. / 10 sec. / 30 sec. / 60 sec. Microphone & Speaker: Built-in microphone, Monaural speaker External microphone: Supported, mono and stereo HD Video Out: Micro HDMI (HDMI cable sold separately) Analog Video: Mini USB (AV-Out composite cable sold separately) Quick start recording: Supported G-sensor: Supported Wi-Fi: Supported Remote Control: Supported (sold separately) Ports: Mini USB, micro HDMI, microSD Storage: microSD memory card with a Class 10 or UHS-1 rating up to 128GB capacity supported, record times vary with resolutions and frame rates Battery: 950mAh Lithium-Ion rechargeable battery Battery life: up to 90 minutes in FullHD mode and up to 135 minutes in economy mode USB Charging: DC 5V 1000 mA Camera weight: 64g Camera with housing weight: 154g Dimensions: 59 x 30 x 41mm Low light to progressive night light (city) drive compilation. 2K resolution, Gyro Off, FOV: Wide, AE:0, WDR: OFF White Balance: Auto Color: Normal
Low light, Gyro: ON, WDR: ON, Colors: Vivid The Git2 put to the test against darkness, incoming headlights, potholes filled with water, copious amounts of rain, bad and under construction roads. It seems that it manages just fine.
Hand held camera Gyro toggle during recording test
How to cut, join and even repair broken MP4 or MOV videos with free tools:
Use Registrator Viewer menu> File > Repair broken file, look in attachment I will post my short videos here, I have some from pre-production sample. In video description you can find many original GitUp video download link. Underwater video, 2160p:
Gyro stabilization compared to SJ5000X Elite and YouTube image stabilization and Git2 with Gyro Off.
Comparisons:
Other great features:
enjoy, Mtz |
Reason: Added MP4 repair
GitUp Git2 FPV Live
What it means ? Enables automatic video out when the Git2 camera is powered on and it's also possible to automatically enable video recording. So you will avoid messing with the camera when it's on your gimbal, no need to power on, enter menu, enable video out or start recording. Just power your multi rotor and let the Git do it's job How it works
Git2 + 250 mini racing quad footage
What's inside the Git2 and how well it is built
Full menu features and options explained Featuring the "Christmas" edition firmware with new added goodies like: - manual ISO - manual shutter control - raw pictures capability - color modes - and a lot more other
External Microphone Test Test done with 3 different microphone - control MIC: Panasonic V520 internal mic - Git2 internal MIC - Git2 external MIC
New 72° and 94° distortion free (no fish eye lens) The Git has received optional lenses that are not 170° wide and do not have barrel distortion Git2 72° Standard Packing Unboxing:
94° Samples
72° Sample
Finally a dedicated GIT2 thread; about time as the GIT2 discussion was really starting to cloud the GIT1 thread.
Nice robotarm there at the end! |
Great to know there“s an own thread for Git2, and thanks for first impressions.
Thanks for choosing the Git2. I have sent PM to you for beta firmware download link. |
Updated to the website - cheaper than Gearbest and same time frame for delivery. Best for UK and Europe.
http://www.action4cameras.com/product/git2pro £84.99 or http://www.gearbest.com/action-cameras/pp_254191.html £92.03 |
Like Git1 it won“t fit to any GoPro-Gimbal which is using the GoPro rear system connector. In other gimbals for GoPro 3/4 it should fit (like Git1 also)
GoPro Hero 4 Black weight is 89 grams. |
