Aug 01, 2019, 08:02 AM
stevea3342's Avatar
I think they technically support 4s but at one one point, or maybe early models it was burning them out. It might have had something to do with quads and regenerative braking. Maybe someone else has more recent experience with it here.
Aug 06, 2019, 12:20 AM
It's common practice to use capacitors to absorb the voltage spikes that come about due to active braking in quads, so your explanation makes perfect sense. I wouldn't be pushing it by running a RC2 off 4s directly.
You can get (transient) spikes up to 25V in some cases, depending on how you fly. Some people even use 35V caps on their ESCs just to be sure.
Aug 06, 2019, 12:41 AM
Mr Birdie ~ Flight Expert
2StrokeMatty's Avatar
I will use a lower voltage then, I havent used it yet but dont need to take the chance when 12v and 5v is available onboard.
Aug 06, 2019, 12:44 AM
I think that would be a very sensible thing to do.
Aug 10, 2019, 02:00 PM
Gahspidy's Avatar
Hey all, just got the RunCam 2 and it connects fine to the iPhone XR via the app. I downloaded the latest firmware 2.6. All went well.
I intend to use it for recording on board flight video on top of the wing.
Do you suggest I turn on digital IS? I tried two sample videos one with it on and one with off holding rhenxam in my hand and shaking around a bit.
Both seem very similar in that there is not much shaking
Does having the digital IS turned on degrade the video quality?
Thanks.
Aug 11, 2019, 03:19 PM
AH-56's Avatar
Does anyone know where I can obtain one of these?
Itís a RunCam 2 mount connector to a GoPro type mount.
Any help will be greatly appreciated.
Thanks...
Aug 11, 2019, 03:53 PM
Thanks...
Amain Hobbies has them in a mount kit ..$4.79
AH-56's Avatar
Deleted post.
Aug 11, 2019, 03:59 PM
AH-56's Avatar
Thanks much 👍
Aug 16, 2019, 05:24 PM
AH-56's Avatar
Deleted post.
Aug 19, 2019, 12:13 AM
AH-56's Avatar
Rustler with RunCam 2 @ HD (1 min 40 sec)
Aug 20, 2019, 04:07 PM
Doing it in the Lateral Axis
modfly's Avatar
Here is a runcam2 video from my GWS Super Cub..
GWS Cub Camera plane over Lake Erie (2 min 0 sec)
Sep 05, 2019, 09:25 AM
pumuklis's Avatar
Runcam in 2 Av mode powered from 5V BEC.
After 3 minutes, it automatically shuts off.
The battery is in the camera.
How can I prevent a shutdown?
Sep 05, 2019, 09:55 AM
stevea3342's Avatar
Does it stay on more than 3 minutes if you just run it off the battery and no BEC?
If not, download the wifi app and take a look at the time out configurations. Also, it's recommended not to use the camera (on) and charge the battery at the same time. You may want to remove the battery if you powering external.
