Nov 16, 2015, 08:49 PM
Born for RC Fanatics
All about RunCam 2
New features of RunCam Firmware V2.2: http://runcam.com/download/runcam2/
1. All the parameters, including digital IS, can be set via APP (with Android App V1.8.0/IOS APP V1.3.0)
2.When the camera is connected to APP, you can still use physical buttons to shoot or record (with Android App V1.8.0/IOS APP V1.3.0)
3.Firmware upgrade can be done via App(with Android App V1.8.0/IOS APP V1.3.0)
4.Fixed the bug of time not synchronized after removing battery
5.Fixed the bug that IS turns on unexpectedly after shortly pressing on WiFi button
6.Fixed the bug of Image Flip
New features of RunCam 2 Firmware V2.1: http://runcam.com/download/runcam2/
With Android App V1.7.0 you can:
1. Set more parameters: automatic shutdown, feedback beep, USB mode, auto-recording, loop recording, Wi-Fi auto-deactivation.
2. Restore Factory Settings.
3. Record video in recommended bitrate for Youtube upload.
4. Set automatic mode for Image Flip.
Other updates:
1. Fix the bug that there is no beep when recording in time-lapse.
2. Change back time watermark text color to white.
New features of RunCam 2 Firmware V2.0: http://runcam.com/download/runcam2/
1. Added File Protection feature: Under loop recording, it can save the recorded file if the camera loses power/battery runs out.
2. No black bars on TV-OUT.
3. OSD menu modified into three-level.
4. Image quality optimized.
5. REC blinking icon replaced with a red point.
6. Fixed the bug that the camera shuts down when USB unpowered under loop recording.
7. G-sensor sensitivity optimized.
8. WiFi standby time modified into 3 minutes.
9. Translation errors corrected on OSD menu.
New Features of RunCam 2 Firmware V1.5 : http://www.runcam.com/download/runcam2/
1. USB function added,enables photos taking and start/stop recording remotely. A remote control module cable is necessary for this fonction.(Please click http://shop.runcam.com/runcam2-remote-cable/ to buy the cable.)
2. Modify OSD wide-angle setting to wide, medium and narrow.
3. More parameters settings are available with the latest version of App(Android V1.6 and iOS V1.2).
4. Renamed Button Beep on OSD menu to Feedback Beep.
HOW TO UPDATE? http://www.runcam.com/download/runcam2/
Firmware Upgrade It would be better to upgrade under OSD menu; press power button to select down and WiFi button to confirm; upgrade when the battery is fully charged
1. After downloading the firmware, put it under the root directory of micro SD card.
The firmware name is recognized as RUNCAM2.BRN
2. Turn on the RUNCAM 2 with the micro SD card inserted,then the camera will start searching the firmware. When the firmware gets checked, you will get a solid orange light.
3. One quick press on the power button.
4. One quick press on the WiFi button.
5. Orange light blinks slowly while firmware is upgrading.
6. After 3.5 minutes, the camera will automatically shut down. And upgrade is completed.
If you fail to update firmware and can not turn on the RunCam 2 any more.
No need any more to contact us for a remote reset via Teamviewer, you can reflash the firmware yourself
Just check it out http://www.runcam.com/download/firmware-reflash.pdf
Nov 16, 2015, 08:50 PM
RunCam 2 Unboxing (4 min 29 sec)
Nov 16, 2015, 08:51 PM
Runcam 2 - Unboxing/First Look (11 min 9 sec)
RunCam 2 On Screen Menus / Settings (4 min 51 sec)
Nov 16, 2015, 08:53 PM
Runcam 2 Flight Footage (7 min 22 sec)
Nov 16, 2015, 08:54 PM
Runcam 2 Flight Footage #2 (8 min 39 sec)
Nov 17, 2015, 12:41 AM
ultra cheap pilot
ican3d's Avatar
Looks cool, i see there's a side ventilation on runcam 2 on the case. Is this camera generating heat?
Nov 17, 2015, 01:27 AM
Demo7's Avatar
RunCam V2 First Flight - Sample Stock Settings (4 min 38 sec)
Nov 17, 2015, 02:06 AM
recursion's Avatar
Is there an approximate release date? Next year?
Nov 17, 2015, 03:29 AM
Before December
Nov 17, 2015, 03:30 AM
Yep
Nov 17, 2015, 04:46 AM
deno6031's Avatar
Definitely need one any pics how it's mounted on a mini quad yet, need to draw some mount for it
Nov 17, 2015, 07:09 AM
Fly,crash,glue,repeat!
Jake Bullit's Avatar
How much?
Nov 17, 2015, 03:24 PM
Cruising at 399ft AGL
Bonafidepirate's Avatar
Here's a UHF noise test with the RunCam 2 and a Foxeer Legend. I compared them with a Mobius since it's known to be a noisy camera, just to have a "bad example"...
UHF Noise Test - Foxeer Legend 1 and RunCam 2 (7 min 24 sec)
Nov 17, 2015, 04:15 PM
SilverLine's Avatar
https://www.youtube.com/watch?v=VeR8wbJGshg
What hardware are you using together with tour phone ?
