Nov 15, 2015, 09:02 AM
Spektrum Telemetry Log Viewer (one more)
Hello,
My friends who faced problems with TLM files from latest Spektrum firmware asked me to take a look on it. They told that no one software can read those files correctly. So I decided to write my own.
Here it is: www.btframework.com/spektrum.htm
But:
1. It can read any kind of TLM files (old, new, damaged, partially damaged).
2. It works faster than others (I hope).
3. It is absolutely free.
Full features list can be found on the software page.
if you have any ideas or bug reports do not hesitate to contact me at [email protected]
I hope it can be usefull for you.
Nov 15, 2015, 01:31 PM
ragge1's Avatar
Originally Posted by ragge1
no not the powerbox module but the flight pack capacity module
using this sensor :
http://www.horizonhobby.com/radios/t...ensor-spma9605
copi this in your thread , as from spektrum update 1,07 ( DX9 ) we could not use powerbox for mah used on the flight pack
Nov 15, 2015, 03:40 PM
your program is fast.
you detect i have a AR8000 receiver, so you can skip showing the fades of B and R which are not present on AR8000.
no graph yet?
i use now telemetry file reader of Kevinww , works perfect only bit slower then yours
Nov 15, 2015, 05:00 PM
If you sen me your TLM file with data from that sensor I will add it support.
Nov 15, 2015, 05:01 PM
no graph yet?
Ok, will do.
Adding graphs. Do not want to slow down the app so ading the graphs takes some time.
Nov 15, 2015, 05:57 PM
ragge1's Avatar
I send to your email , couldn't attach it here
Nov 15, 2015, 07:28 PM
Hello,
Flight Pack Sensor reading has been implemented. The application updated.
Nov 16, 2015, 01:13 AM
ragge1's Avatar
Hello,
nice thanks
Nov 16, 2015, 03:43 AM
Keep Looking Up
BWX232's Avatar
Already fixed.
Tested new version and it did same... hmm...
Nov 16, 2015, 07:41 PM
It opens the file but really slow cause of long log fine (lot of records). I thought about such case and possible optimization and will do it but a littl ebit later.
Any way I implemented a Data Graph function and now going to work more on speed optimization. There is a way but I afraid sorting will not work correct so need to think more.
Nov 17, 2015, 01:10 AM
Updated. Now your file opens in just a second or so.
Nov 17, 2015, 11:30 AM
Keep Looking Up
BWX232's Avatar
It did work this time.
Is it not supposed to read altitude and stuff like that?
I didn't see altitude or delta data anywhere.
Also it graphed something, but no lines showed up.
Nov 17, 2015, 11:45 AM
I used third party graph code but it does not work correctly so now I am workng to write my own or use other.
The Vario sensor has been just added. Will upload updated version soon.
Nov 17, 2015, 12:27 PM
Keep Looking Up
BWX232's Avatar
Ok, just wondering.
Nov 17, 2015, 12:31 PM
ragge1's Avatar
good work
on the graphic , it will show one of the sensor ( rpm ) but the others are way down on the page
on the FP sensor menu , the same and the temp in that menu is like @ 24 below the actual value
at 14 it shows -10
