This thread is privately moderated by billpa, who may elect to delete unwanted replies.
Dec 29, 2016, 08:22 AM
because rust never sleeps....
HugoRogers's Avatar
Originally Posted by twinturbostang
What is the minimum required separation between the GPS sensor and a 1258/1280 MHz video Tx? I'm installing a Vector on my TBS Discovery and am hoping that it will have enough distance. GPS will be on the back, and the vid Tx antenna will be up front, which equals about 9" of separation. Maybe 10"-11" if I re-drill a hole for the antenna mount. Video Tx is an ImmersionRC 200mW.
I can't locate the source, but I think you should be aiming for 18 inches minimum.
Dec 29, 2016, 01:05 PM
Fly FPV, sleep; repeat
twinturbostang's Avatar
Well that's a bummer.
Dec 29, 2016, 01:36 PM
HugoRogers's Avatar
Well I have had another look, and although I am sure I have seen this written down somewhere on the web, I cannot find it. So if I were you I would treat it as unverified until you get some more input on your question.
This filter is supposed to help though if you do have problems
http://www.dpcav.com/xcart/Low-Pass-...1.3GHz-TX.html
Dec 29, 2016, 03:11 PM
I have one of those actually and planned on using it. I can, if necessary, swap to 5.8 GHz for video. But I really was trying to build this for long range. So 1.3 GHz is the logical choice. But I'll have to see if the separation is enough for GPS lock or not.
Thanks for the suggestions.
Jul 13, 2017, 08:01 PM
Originally Posted by paulskyone
Hey guys,
Does anyone know what GPS chip the GPS/MAG V2 uses? We are conducting a high altitude project and want to make the switch from our old OSD system to the Eagle tree OSD system. Our projects typically fly up to 100,000ft so we need an unrestricted chip. Does anyone know the altitude limit of the Eagle Tree GPS?
Thank you!
I'm looking for the same information....or at least somebody who has gotten a different gps unit to work with the Vector (ET said only their GPS would work with the Vector)
Jul 19, 2017, 05:07 PM
Im running the RMRC 1.3Ghz 800mW on my mini Talon.
VTX on the nose and GPS at the rear, no problems so far.
Oh and my GPS is a v1.
Apr 02, 2018, 01:00 PM
GPS Programming for use with Vector
Hi,
Does anyone know the programming needed to use other GPS units with Vector? I have several of these nice GPS units and would like to use them with my Vectors but don't know what Vector needs from it.
https://store.mrobotics.io/product-p...-samm8q-01.htm
These can be programmed with the u-center GPS Evaluation Software, just need to know what to program to.
Thanks for any insights.
Best.
Todd
Apr 03, 2018, 07:30 AM
The Vector GPS v1 & v2 talk to the Vector on a I2C bus, same with the other Vector sensors daisy chained together.
So that GPS module is not going to work with the Vector without a lot of work.
Geoff
Apr 03, 2018, 08:49 AM
Geoff
Thanks for the reply, I honestly wasn't expecting one.
That GPS unit does have an I2C port. Is there something different in the I2C protocol that would make it challenging?
They are great little GPS units, would love to have use for them for my Vector fun.
Thanks again!!!
Todd
Aug 06, 2018, 06:41 PM
Koki
omesen's Avatar
Hi John
I have lived the following experience with my GPS, I have entered to vary the configuration of the OSD by means of software 12.6 and the GPS does not work for me, the legend appears that it is trying to fix the satellites and its active yellow light does not work. What I have done to correct this problem is to vary a detail in the configuration of the OSD to apply it and ready to work again. This has happened twice now.
Which may be _
