Apr 27, 2016, 08:56 AM
Ah, thanks
Apr 27, 2016, 10:06 AM
Originally Posted by JulianGoesPro
the sn20a is a really bad ESC well... not bad like really bad but outdated like not one generation behind but several (two )
Really bad ESC...
Apr 27, 2016, 10:11 AM
Originally Posted by RcfanJapan
Ah, thanks
Don't replace them yet though! Wait for blheli_s escs. That's my plan at least.
Apr 27, 2016, 10:54 AM
AMA 1033652
mnemennth's Avatar
Agreed. a good "entry-level" ESC, but definitely not even bottom end "race-ready".
No idea how it is those horrible EMAXX 12A ESCs keep coming... they must cost more to make by now than the SN16A/SN20A.
mnem
Nice pants.
Apr 27, 2016, 11:08 AM
Woohoo!
RS2K's Avatar
SN20 doesn't officially support MS since it's on a 16MHz Atmel. MS makes quads much easier to tune and everything runs cooler. I can't recommend them at all anymore unless you need to replace a bad one. I only can recommend ESCs that support MultiShot. It makes a big difference, even over OneShot42.
Apr 27, 2016, 11:15 AM
JulianGoesPro's Avatar
mnem
Nice pants.
They are actually not bad xD I still have the EMAX 12A... they are still supported with BLHeli... (only downside is no dampend light)
Apr 27, 2016, 11:17 AM
N'a qu'un oeil
papayou's Avatar
Hello
First try with cyclone and XM20A...
Flashed with Multishot XB20
8 khz/4 khz
pid_process_denom = 2
Entering CLI Mode, type 'exit' to return, or 'help'
# status
System Uptime: 18 seconds, Voltage: 0 * 0.1V (3S battery - OK), CPU:12%
CPU Clock=72MHz, GYRO=MPU6000
Cycle Time: 125, I2C Errors: 1, config size: 1292
# tasks
Task list:
0 - (SYSTEM) max: 3us, avg: 0us, rate: 9hz, total: 0ms
1 - (PID) max: 144us, avg: 48us, rate: 4032hz, total: 7sec
- - (GYRO) rate: 8064hz
4 - (SERIAL) max: 688us, avg: 2us, rate: 98hz, total: 14ms
5 - (BEEPER) max: 10us, avg: 0us, rate: 99hz, total: 2ms
7 - (RX) max: 74us, avg: 43us, rate: 66hz, total: 84ms
I will fly tomorow
Apr 27, 2016, 11:31 AM
Tree Basher
prokreat's Avatar
Is there a list? Or just known by hex files in the Dropbox? I have LB20 and RG20 I would like to try MS on. From here on out will only be getting F39x ESC or better.
Apr 27, 2016, 12:16 PM
Originally Posted by papayou
Hello
8 khz/4 khz
# status
# tasks
Task list:
I will fly tomorow
put your pid_process_denom to "1" (it will give you 8K pid) and check your CPU again it looks like you might have some room.
Apr 27, 2016, 01:05 PM
SadLeprechaun's Avatar
Getting this with Cyclone 8k/8k/multishot, is 26% ok for CPU? Just changed to pid_process_denom = "1" after I added MS, before I had 8k/OS with pid denom at "3".
# set pid_process_denom = 1
pid_process_denom set to 1
# tasks
Task list:
1 - (GYRO/PID) max: 156us, avg: 88us, rate: 7751hz, total: 21sec
4 - (SERIAL) max: 501265us, avg: 2us, rate: 99hz, total: 523ms
5 - (BEEPER) max: 8us, avg: 0us, rate: 99hz, total: 6ms
6 - (BATTERY) max: 40063us, avg: 1us, rate: 49hz, total: 47ms
7 - (RX) max: 94us, avg: 42us, rate: 49hz, total: 150ms
# status
System Uptime: 49 seconds, Voltage: 119 * 0.1V (3S battery - OK), CPU:26%
Cycle Time: 128, I2C Errors: 1, config size: 1292
I will fly tomorrow too can't wait!
Apr 27, 2016, 01:15 PM
mrmurder19.75's Avatar
# tasks
Task list:
# status
26% is fine
Apr 27, 2016, 02:54 PM
Quadaholic
--Oz--'s Avatar
Originally Posted by mrmurder19.75
26% is fine
What cpu% is borderline?
Apr 27, 2016, 03:10 PM
Woohoo!
RS2K's Avatar
That's a hard question to answer. 5% CPU usage on a single core might be too high if you need to do 10 things that take 1Ás to do all within the same 1Ás.
Apr 27, 2016, 03:12 PM
Woohoo!
RS2K's Avatar
All SiLabs based ESCs are capable of running MS. I've compiled all of those ESCs' firmware into the dropbox. I personally prefer F39X based ESCs since they can run at 32 KHz.
Tree Basher
prokreat's Avatar
wow, i dont know if its placebo... or the Imperial March, but i am loving my quad running 4k/4k and its on SPRF3/LB20 setup. the motors even sound different. everything is so smooth. cant thank you enough. less prop wash on drops and 180s.
