Nov 08, 2015, 09:09 PM
AAA100's Avatar
Futaba T7C w/ R617FS help Mixing
Been in and out of this hobby since the 70's....old guy. Need help setting up a mix., if possible, on my glider which I'll have flaps on channel 6 (VR knob) and 7. I assume this is possible. I have tried with no success. If not possible I'll have to install them both on the same channel, but will have to reverse a servo.
Any help will be appreciated.
Thx, Brian
Nov 09, 2015, 02:22 PM
S.A.D. member
ivanc's Avatar
Brian,
Can you provide a detailed information of the glider setup and what do you want to control the flaps with?
What channels are used for each control surface, flaps included?
I may be able to help you but will need specific information.
Ivan
Nov 09, 2015, 08:03 PM
AAA100's Avatar
I had success P-mixing
Originally Posted by ivanc
Brian,
Ivan
Ivan, thanks for the response. I'm new at gliders so I just wanted to have a variable degree of flaps. I was able to solve my problem. Others might be able to apply my settings to there TX....
Channel 1: Y cable to both Ailerons
Channel 2: Elevator
Channel 3: Throttle
Channel 4: Rudder
Channel 5: APM 6 position switch
Channel 6 and 7 Flaps
Steps taken to install 2 flaps servos on separate channels:
Using channel 6...(VR knob) and channel 7
Parameter: Change CH7-SW to --- (No Switch)
P-Mix: "ON"
MAS>CH6
SLV>CH7
SW> --- (No Switch)
RT> +100%
RT> +100%
Reverse: the (a) channel as needs
Thx, Brian
