Jul 19, 2004, 07:07 AM
Charleyh's Avatar
When's this Little PIGI coming to market?...p.2
Continuation of part 1 which can be found here: Part 1
Carry on
Jul 19, 2004, 08:25 AM
Got H2? Fuel Cell R/C Car
Keith43221's Avatar
I found this charger (Plantraco Li-Po Charger) and it looks like a it would be enough for me is it any good? chagers 1-3 cells for 60 bucks.
http://www.hobby-lobby.com/chargers_lipoly.htm
I have A LOT of 30 min. expoy, will this work? or should i get some 5 min. or goriile glue?
Jul 19, 2004, 08:30 AM
Charleyh's Avatar
That charger only charges at 400mah. This means for a 3000mah pack it would take over 7 hours to charge
You need to get something that charges up to 3 amps. Or at least 2 amps.
Gorilla glue is ok but I used Shoe goo on mine and it hold very well.
Jul 19, 2004, 08:39 AM
Keith43221's Avatar
Ok Thanks for the info i will look around.
Jul 19, 2004, 08:51 AM
Keith43221's Avatar
Do I need a charger that does up to 6 cells if i am putting 2 three cells together or do I only need up to 3 cells. i am new to lipos so i am kind'of confuesed
Jul 19, 2004, 09:03 AM
Charleyh's Avatar
3 cells. The cell count is figured on how many series cells. The parallel cells are just for more capacity.
You do NOT want to charge a 3s2p pack as 6 cells. It will ignite very quickly. Ask me how I know.
Jul 19, 2004, 09:05 AM
Keith43221's Avatar
Thanks!!
Jul 19, 2004, 09:09 AM
Keith43221's Avatar
ok Found this:
ETC2500 Li-Poly Smart Charger for 1-4
Cells ..... $ 49.90 Max 2 1/2 amps
http://www.hobby-lobby.com/chargers_lipoly.htm (second one down the page.)
Jul 19, 2004, 09:13 AM
Charleyh's Avatar
Only problem is it has a jst connector and you will need a deans with the bigger packs.
May work but you'd have to change the connector.
Jul 19, 2004, 09:17 AM
Keith43221's Avatar
No probluem i will pick some up
Also: Do the aileron servos each have there own slot in the RX when using the 555 hitec RX recomend by HL? I have a 4 ch. futaba RX that i would like to use so i would need a Y cord for the ailerons right? (The RX has 4 slots)
Jul 19, 2004, 09:20 AM
Charleyh's Avatar
Yea, with a 5 channel they get their own slot.
With a 4 you need a y cord.
I suggest getting the 5 channel though. It gives you the ability to control them independantly so you can have flaperons or spoilerons mixed in for fun.
4 channel will work but leaves no options.
Jul 19, 2004, 09:30 AM
Keith43221's Avatar
ok I will get the 5 ch. What will i be able to solder the motor wires right to the speed cotrule? then use deans ulta on the speed contrune to the battier? (they come on the battier already)
Jul 19, 2004, 10:06 AM
Charleyh's Avatar
If you get the outrunner that HL puts in the package, it doesn't have wires, just solder points so you solder the esc wires directly to it.
The deans male will go on the battery leads on the esc.
If you get the 2 kokam packs you will need a way to put them together. If you are very confident in your solder skills you can make them into one pack. If not you can make a small adapter from some deans con and a little wire. Or you can buy the parallel circuit from HL which they just plug onto.
I soldered my packs directly into one pack to save weight, but it can be risky.
Jul 19, 2004, 10:07 AM
Charleyh's Avatar
what type of transmitter do you have?
If it doesn't have the mixes I spoke of there is no use getting the 5 ch receiver.
Jul 19, 2004, 10:15 AM
Keith43221's Avatar
I have a Futaba 7C it has lotssssss of mixes.
I am still working on my soldering skills (I suck) could you tell me a little bit more on how to make a small adterper from the conneters?
Thanks, Keith
