Dec 05, 2016, 03:04 AM
jofro
From original 12 S going down to 6 S, slightly longer take off but still lot of fun. I'm stuck now with so many 6 S power plants I don't know what to do with it, great model to test it on.
GOPR1275 (5 min 24 sec)
Dec 06, 2016, 01:31 AM
jofro
Testing the battery in extreme hot conditions, 40 degrees and hardly a breeze, love it!
GOPR1281 (5 min 54 sec)
Dec 07, 2016, 11:52 AM
Classic jets rule
AIR SALLY's Avatar
Great little test bed.glad she is still being a work horse. Enjoy
Dec 07, 2016, 10:01 PM
jofro
Hi Rog, certainly different plane to keep it up with only some 1/2 power compare to 12S I use to run it on but at same AUW. I'm stuck now with so many 6S set ups after all the upgrades over the years, I'll better start using them, Cheers.
Dec 19, 2016, 02:57 AM
jofro
Pretty decent flight time at 5 minutes on full stick to keep this 4 kilo, almost 7 feet long model up on 90mm/6S set up.
GOPR1309 (6 min 26 sec)
Jan 01, 2017, 03:39 AM
jofro
Today flying it with lighter 6S/6000/65+C at 1250 grams pack, lighter but shorter flight time.
GOPR1321 (3 min 19 sec)
Happy New Year, I had a great one.
Jan 17, 2017, 04:14 AM
jofro
Just received the latest Stumax fan unit still at prototype stage so I pulled out my recently fitted FW 6S power set up in this model and going back to 8S to check it up. Sounds and runs great after few static test runs to see few figures.
Apr 25, 2017, 12:51 AM
jofro
My way of celebrating the ANZAC Day at the beach today, running on 8S with SM89, smooth as a silk.
GOPR1462 (3 min 58 sec)
Nov 14, 2017, 03:26 AM
jofro
The fan is now well run in.
M4H00788 (3 min 22 sec)
M4H00790 (2 min 54 sec)
Jun 26, 2018, 04:06 AM
jofro
Took it out for few more flying sessions today, perfect cool conditions, but this thing sucks amps just like if there was no tomorrow! Little too large and heavy for the multi blade power unit.
Jun 26, 2018, 06:52 PM
jofro
Proto in action.
2016 0916 214413 026 (4 min 2 sec)
Jun 28, 2018, 03:27 AM
jofro
Time for a change again, Stumax 8S fan is out and back to the Freewing 12b/6S. The good thing is I can use in this model some huge capacity batteries. After quick check run the amps are pretty high on 6S @110Amps but pretty good thrust on this low voltage peak at 3.2 kilos. At 4+kg, AUW it's not to bad for more action off the beach.
Jun 30, 2018, 02:43 AM
jofro
Back in the air with the 90mm, Freewing 12b, unit on 6S. Still under high current draw but lover voltage. While having 6 times more 6S packs than 4cell ones, this power unit will be more practical.
2016 0920 205614 027 (2 min 46 sec)
Jun 30, 2018, 11:31 AM
Lynxman's Avatar
How fast are your planes? They don't seem super fast compared to how much power you're putting in. I bet you could get away with half the power and the same performance if you hade bigger fans, like 160 mm.
